Question about Sony FD Trinitron WEGA KV-21CL10 21" TV
I have renew a fuse,Transistor D 1878 7G1 on a TV make Sony Model j21mf2,but the Tv not starting.Fuse..OK,Transistor..OK,Power switch..OK.The TV not started..Can you tell me why??
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Check horizontal oscillator and driver section of TV. Use oscilloscope to observe horizontal pulse waveform.
Probably PTC in power supply faulty
Posted on Jun 13, 2009
    Problem Solver:
  • 11 Answers
Have you check power ic if okey your volteage is below 90v ac
Posted on Apr 23, 2009
The fuse of my Sony KV-27s42 somehow got burnt.Can anybody tell me what is the fuse model and where to buy it?
The fuse rating is printed in the main board beside the the fuse terminal, to purchase the fuse it is available in all electronics shop.
Sep 03, 2011 | Sony KV-27S42 27" TV
My Sony Bravia LCD TV Got 220v Wile It Should Get 110v,And Went Off
hi...if you have plug the TV in 22oV instead of 11V..it automatically blown the fuse..the power supply has this Varistor it will shorted and blown the fuse if detected high voltage....I suggest you replace the fuse and check for any other defective parts in the power supply section....check for bloated capacitors.. shorted power switching transistor... if none TEST RUN..let see if your TV will switch ON...please rate and vote...
Feb 17, 2011 | Televison & Video
What is the first step in troubleshooting color television? dead set..blown fuse..
Hello
You haven't specified anything about your Sony Tv. No model number or anything to compare. Although I hereby giving you a general trouble shooting method, first adopted by technicians like me. You have stated that the fude has blown out. Fuse will not burn out without any reason. it is a protective device used in every telivisions,as if any internal components inside it gets shorted, especially in power supply section, the fuse will get burned and protect the other components from further distruction. Therefore you have to trace the reason for the failure of fuse first.
You must beging it from power supply regulator section itself. Chech the resistance accross the main filter capacitor first. Set the multimeter in Ohms range, and the resistance must be above 250Ohms in one direction, and upto infinite in the other direction. If both readings comes below 20Ohms or so, suspect the power regulator Ic; usually sony sets udes STR type regulated power supply, and this STR will get shorted. As you haven't specified your sets model, I can't make sure whether it is circuted with STR or a switching transistor. As both cases, this regulator has a chance to get shorted. Desolder it out and check for short. if it finds shorted, check the rlated components also, such as zener diodes and resistors, for open and short,as they also will get damaged due to this main switching transistor, or STR; whatever may be.
Check the degaussing posistor for short. Check the rectifier stack for short. Check the mains filter capacitor for short. Check each and every diode for short. you must measure the forward reisistance of diodes with multimeter set in 100KOhms range. There shouldn't be any slight leak with this test. If it shows a slight leak, replace it. You just do these and inform me the result through Fixya. I'm ready to assist you furthermore. When you reply to me; please include the model number of your Sony Tv. Ok.
Dec 12, 2010 | Sony Televison & Video
We have a Sony Bravia lcd tv model KLV-S40A10 - no power
Hi,the problem is from the fuse in the tv,it's blown and it's a means of in-built security against power fluctuations from damaging the unit,so the solution is to replace the fuse of the TV to restore your unit back to a normal working condition.
Be cool.
Jun 13, 2010 | Televison & Video
Tv wont switch on
This could be a problem with the power supply. Yes there is a fuse on the power supply & if you have a multi-meter & are competent with electrical safety, you could test it. However, if it has blown then almost certainly something else will have caused it. You might have a short circuit bridge rectifier or faulty chopper transistor. If the fuse is ok, then you will need to check voltages from the power supply to find out what feeds you have. There may be a start resistor open circuit for example. If most of the start up voltages are ok, then you need to look at the line output stage & check if this circuit is getting any voltage supply.
Jul 15, 2009 | Panasonic CT-32SL13 32" TV
Had power outage while tv was on. When power restored I turned on tv with remote. TV sounded like it went on but no picture. Only timer light lashing. Sony Wega older model 27" Please help, thanks
next time dont leave your tv pluged on power, the power supply got burnt, check your power supply on the following components
fuse, power transistor, zener diodes,also rectifier diodes
if you can manage do it at home
or take it to a w/shop
Apr 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony TV Problem model # KV-27V42
your tv has a  short  circuit, the power supply see that and put away the polarizatio n , you have to check  if transistor of power on flyback transformer is  good
or bad - delfo
Mar 12, 2008 | Philips Magnavox 27MS343S 27" TV
TV - worth fixing or pitch?
Horizontal output and regulator transistor often short out on this model causing a dead condition. Also the resistor right next to the regulators goes open as well. Electronix.com has a sony repair kit to fix the power supply. You just have to check the numbers on your Horizontal output transistor to make sure you get the right kit for your model.
Feb 03, 2008 | Televison & Video
No Power on
Hello, please check the transistor 2SD1878 near flyback transformer and fuse PS801. Best regards, Arpi
Jul 18, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony FD Trinitron WEGA KV-21CL10 21" TV Logo
379 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
