Question about Pure Digital Pure FMDAB Radio
Dab zonosound zds21
Dab zonosoud zds21
The time does not automatically set on my sony alarm clock XDRC706DBP
Afraid I have the same problem and I have to manually set.
good luck !
Jul 07, 2014 | Sony Xdr-c706dbp Dab / Dab Digital Alarm...
Zonosound manual
http://www.radiolabs.com/downloads/manuals/sony/ICFSW7600.pdf
Jun 11, 2014 | Sony ICF-SW7600 AM/FM/SW Radio
Dab signal
I suggest you scout around the neighbours for a DAB you can borrow to test the signal in your usual place. Your own radio could be faulty.
One of my DAB radios worked fine on FM even though one day it just stopped working on DAB for no apparent reason. The board to repair it is priced not to sell...
Sep 17, 2017 | Audio Players & Recorders
Fm radio works fine but the dab will not find any stations, I have tried different aerials and still no good
What's the make & model of the radio?
Most DAB/FM radios work from the same antenna, so if you receive FM stations, you should receive DAB stations in your area.
It should be noted that DAB transmitters work on lower power than conventional FM transmitters, and so you may be in a weak reception area (for DAB). It should also be noted that DAB uses different frequencies than regular FM stations and household appliances such as laptops,WiFi, microwave ovens, etc can affect DAb reception.
Nov 18, 2013 | Audio Players & Recorders
Philips MCB204 problem with tuner , DAB and USB
Is the MUTE button activated? Press once to ACTivate or INactivate
Apr 07, 2010 | Philips Audio Players & Recorders
Can a hitachi ax-m133 be upgraded to dab +
if the hitachi unit has a line in socket, you can plug an additional DAB tuner in to give you dab.
Sep 20, 2009 | Audio Players & Recorders
Tivoli DAB radio after working fine for 2 years suddenly giving message station not available?
  • August 3 - Xfm is now available on DAB in the South Wales & the West region.
  • August 3 - Choice is no longer available on DAB in the whole South Wales & the West region but is still available in Cardiff and Bristol & Bath.
  • August 3 - Chill is no longer available on DAB in Cardiff, Bristol & Bath, Plymouth and Cornwall.
Aug 04, 2009 | Audio Players & Recorders
Lodik dab 3006 radio
how to install a driver
Apr 30, 2008 | Computers & Internet
Pure Digital Pure FMDAB Radio Logo
212 people viewed this question
Top Pure Digital Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Pure Digital Audio Player and Recorder Expert? Answer questions, earn points and help others
