SOURCE: Lg washer oe error
On LG washing machines, the OE flashing code means there is a drainage problem. hope that helped.
Please Rate Me
George
SOURCE: MY LG WASHING MACHINE SHOWS AN ERROR MESSAGE (OE)
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: OE Error
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!!!!!!!!!!!!!!
SOURCE: My LG intellowasher 7,5kg WD-
An
OE error presents if the washing machine has not successfully drained
the water in ten minutes. However, the OE error code does not always
mean that the washer requires a service call. If periodic maintenance
has not been performed on the washer, there are a few simple steps to
take before calling for service.
LED display models
LCD Display Models
Step 1: Check the drain pump filter.
Step 3: Confirm that the washer is leveled properly.
Items caught in
the drain filter will prevent proper drainage. Over time build up can
occur from detergents and additives used in the machine. Manually drain
unit through the drain hose, then lay a towel down to catch the water,
and remove the filter. Clean the filter thoroughly and restart the
machine.
If the unit is not
leveled properly, it will not drain properly. The front of the unit
cannot be higher than the back or vice versa. If not properly leveled,
the water can flow back into the machine. If this is the cause of the
problem, please level the machine using the supplied leveling wrench.
When you place a LEVEL on the washing machine, the bubble should be in
the center. Confrim that the washer is leveled from side to side and
front to back.
Step 2: Check the washers drain hose.
If the drain hose
is not installed properly, the washer will not drain properly. The drain
hose should not be installed more than 1 meter higher than the bottom
of the washing machine.
NOTE: Perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
SOURCE: My WD-80490TP LG washing machine
'CL' for LG washers stands for 'Child Lock'.
To release hold down 'temp' and 'eco/rapid' together, then release!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
