Better to bring your printer to computer shop becoause it needs to open ang remove excess ink in the ink absorver to make it empty it needs to open a whole printer by removing all cover only the technician can make it...
You have to reset waste ink counter using MP Tool. Try to find at indoreset.blogspot.com. Or you can do it manually.
Try this.
1. Unplug power
2. Press and hold ON/OFF button
3. Press and release Stop/reset button
4. Release ON/OFF
5. Press Stop/reset 4 times
Turn off printer and turn on.
Inkjet printers have a fibrous pad inside them that collects the waste
ink from cleaning the print head. Over time, this pad fills up with ink
and can no longer hold any more. When this occurs, the printer
indicates a "waste ink tank full" error.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced,
it'll be functional again.
Just press the resume button for about 5 seconds if your printer doesn't print. It's ok if the monitor tell you that the ink empty, its just about the ink catridge counter
hi, CANON PIXMA MP160 All-In-One InkJet
Printer has few common problems. Such as Driver CD
lost, Scanner does not work, Connection problem etc. For find all these software solution
just click here....
E27 = Waste ink absorber full or platen waste
ink absorber full
Reset Your printer.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Turn off the printer ( "Power"
button).
Hold the button "Resume" (red circle in the triangle), add a printer
(click "Power") - an indicator light green.
Hold the "Power" button, release the button "Resume".
Not releasing the "Power" button, double click "Resume" and
release both buttons.
Four times click "Resume"
Once you click "Power", to confirm the selected action (reset counter
absorber). To disable the printer "Power" button to click again.
