Answer to the protect system on sony HCD-EC79i Check the fan for dust build up and and speaker leads for shorts and impedance etc. If ok then open up unit and unplug the 5way ribbon connector and 7way cable to the power amp moudle, thenb turn on power and the protect with will gone and you will have a normal; LCD functiion back again power down and refit the the leads and repower and all should be well now. no need to buy new power amp module!!
  • 3 Answers
SOURCE: Protection displayed and shuts off
Hey guys! Im glad you found my solution on my blog, and posted it here. I hope you ccan fix yours, or get it replaced on warranty. Im happy to help you with anything, the capacitors i think was 4,7 uF, 100volt, not sure.
Here is the link to my solution: http://lemurt.wordpress.com/2008/08/18/defenition-of-waranty-void/
:D
/ lemurt
Posted on Sep 22, 2008
SOURCE: Sony speaker connectors
Try this guy on eBay who is selling 2 varieties of Sony connectors, plus a ton of others
http://stores.ebay.com/BOGUE-ENGINEERING-GROUP
I'm about to pull the trigger on a set of his 4.2mm connectors for Sony HCD-HDX500 for $26
Posted on Oct 11, 2008
welcomejee
  • 10594 Answers
SOURCE: SPEAKER WIRE CONNECTORS
You need 5 Cord (wires) Connection to attache all speakers.
You can have all 5 cords in one package or each cord individually at Sony Accessories.
Please write model number DAV-FR1 in search box to get result on above web page.
Details of wires required.
182724411 1 BAG = 5 CORDS approx $43
179146811 CORD, CONNECTION approx $10.30
Posted on Nov 10, 2008
  • 104 Answers
the solution is get rid of it fast , i had a samsung dvd player that did that then it caught on fire , pretty scary,lucky i was there when it started to smoke up
Posted on May 23, 2009
SOURCE: "Protect" and "Push Power"
i have a sony component push power protect, i have already replace IC but still protect push power
Posted on Jun 21, 2009
My sony mini hi-fi deck continue to tell me to i quote 'PUSH POWER;PROTECT' what do i do?plss help.
You PUSH the POWER control (OFF) because it is self protecting.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or
marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is
running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Sep 03, 2011 | Sony Electronics - Others
SONY HCD LX-50 msg: "Power down to Protect"
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it '*****'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Aug 03, 2011 | Sony Audio Players & Recorders
WHEN THE POWER IS TURN ON GETTING A MESSAGE SAYING PROTECTOR/ PUSH POWER ON MY SONY HCD-HDX285
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Jul 13, 2011 | Audio Players & Recorders
I have a Sony HCD-ZX6. When I plug it in the power light comes on. When I press the power button, the stereo turns on for about 3 seconds. At that time all the lights flash and the power shuts off.
Check for loose speaker connections at the speaker as a possible root cause for intermittent shutdown.
Jun 06, 2011 | Audio Players & Recorders
My hcd s300 has stopped producing sound. I have tried muting and unmuting. Any help would be helpful.
Have you looked at page 57 of the manual?
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
May 28, 2011 | Sony DAV-S300 System
Hi i have a sony hcd-xb500 and the power protect won,t switch off can you please help as i miss my hi thanks
Check for loose speaker connections at the speaker as a root cause for ntermittent shutdown.
May 26, 2011 | Sony Audio Players & Recorders
My Sony mhc-ec79i is displaying PROTECT on the screen can't do anything while this is up, please help
Open the back of the unit and remove the 5way ribbon and 7way cable plug from the main amp module and turn on power the LCD should display normal operation, then power doen and refit those plugs and repower again and all should be ok now, simlpy by turning of the power does not reset these units you have to remove these leads to force reset, check theat the fan is not blocked with dust and thbe speakers are ok and no shorted wires etc and the impedance is ok.
May 25, 2011 | Audio Players & Recorders
My sony mhc-s9d goes to 'push system protect;
May 18, 2011 | Sony Audio Players & Recorders
What does it mean when your sony 60cd stereo system display screen says push protect
May 11, 2011 | Sony MHC-GS300AV CD Shelf System
Appears PROTECTOR, push power button, on my sony DAV-HDX265
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Apr 14, 2011 | Sony DAVHDX265 System
 Grubhead
Grubhead
