Question about Brother MFC790cw All-In-One InkJet Printer
Mfc 790cw error code 70
Have error code 70. Have cleared paper jam. What is error 70 and how do I get rid of it? Help?
  • 13 Answers
SOURCE: How to clear a Machine Error 76
Error 76 is fuser error, you need to change the fuser but first just in case try to reset settings to factory defaults.
Posted on Nov 30, 2007
SOURCE: I can't find the back door sensor on Brother MFC-7420
I have the answer. I just fixed mine. The sensor is not really on the door. You have to remove the door by openning it all the way and carefully sliding it out ( one of the pegs holding the door is hourglass shaped. This will slide out first. The other is round. You will see a black flap that covers a red drum. Pull the flap down carefully. There will be a six inch long rod it's about 1/8 of an inch in diameter. It extends from the middle of the flap all the way to the right side. This probably popped out of place. Make sure that it is all the way to the right as this is where the sensor is. There is a little spring on the bar on the left side. This should be straight up and down. if it is not, then you need to fiddle with the bar.
The trick was that the sensor is NOT on the door, but on this inner flap. When the door closes it pushes this flap agains the drum and the little bar activates the sensor.
Please do not applaud so loud, you are ambarrazing me!!! hehehe. Good luck!.
Posted on Aug 11, 2008
SOURCE: paper jam, and I don't
I had the same problem.  I had removed all the visible paper and when it came back on made some awful noises and flashed "paper jam".
I even moved the roller forward and backward (after having uplugged the device.  I did this repeatedly and the "paper jam" alert continued (along with the awful noise).
As a last resort I thought I would just take it apart and hope to get it back together but figured it was a sensor or something along that line if I could not find any paper anywhere
with the machine unplugged (it would not shut down), I opened the lid I used a flashligt to look around trying to figure out how to take it apart.
It then dawned on me that I had not moved the print head over and using a screwdriver I gently pushed it to the center of the bar.  When I looked inside with a flashlight, there was the paper jam way inside under the cover.
I used some needlenose to reach in and took the paper out and it is now working fine.
I hope this helps, but you may have to search really deep into the device.
Posted on Dec 10, 2008
  • 265 Answers
SOURCE: paper jam in brother MFC 240C
Usually small pieces of paper are jammed at the print head area. Lift up the scanner and see if you can find the paper at the print head parking area, clear the paper . If you can't find the paper, remove the scanner cables, then the scanner. You will see 2 screws at the rear and one near the USB connection. Another 3 screws towards the front will remove the front panel. Under the panel remove 4 screws and the two panel harnesses. The is a speaker harness which you must remember to attach back later (most people don't remember to put back). Lift up the top cover and you can see the whole engine. Clear any pieces of paper that might be there.
Posted on Dec 12, 2009
  • 51 Answers
SOURCE: paper jams??
click here to download yor required drivers
Posted on May 12, 2010
PRINT UNABLE 70
You would need to remove jammed paper opening back cover.
Nov 18, 2013 | Brother Mfc 250c Clr Inkjet P S C F Usb...
Unable to print 50
Error 50: The machine does not work due to a paper jam or some sensor problem.
Clear the paper jam.
See here for illustrated instructions on how to clear a paper jam.
If the problem still continues after clearing the paper jam it could mean a problem with a sensor and you may need to contact a service representative.
For future reference a list and explanation of Error Codes can be found here.
Trust this is helpful.
Jan 04, 2011 | Brother MultiFunction Center MFC-440CN...
What cause a error report Unable to print 70? and how do I solve problem. Many thanks Susan
These mean the machine does not work due to a paper jam or some sensor problem. try to clear the paper jam. If the problem still continues after clearing the paper jam, try to clean the encoder strip (clear strip of plastic) located behind the head.
Nov 10, 2010 | Brother MFC 490cw Color Inkjet...
Dear all here i am anil kumar from india i have MFC brother printer DCP-195C but i have facing problem when i print the page the printer show print unable error 70 please solve my problem thanks...
Error 70 normally is a paper jam or something else that is stopping your print head moving correctly.
Open the covers, have a look, and after clearing the jam you must power off and on the machine.
- Dirty encoder strip
- Foreign object, such as a paper clip or ripped piece of paper is stuck in the machine
- Mechanical malfunction
The most common cause of this issue is dirt on the encoder strip.
Oct 27, 2010 | Brother DCP 165C Compact Color Inkjet...
Have an Error 51 on Brother MFC-210C all in one printer?
I can help you with your Brother MFC-210C error 51 problem.
Error 51 refers to a paper jam error.
Clear the paper jam to clear the error code.
If the error code will not clear after clearing the jam, resetting and powering off, the printer may require service.
I hope that helps.
Aug 30, 2010 | Brother MFC 210C All-In-One InkJet Printer
I cannot print or copy . i see error 51
Error 51 is a paper jam code. Remove the paper tray in the front and the jam clear cover in the back (the light gray plastic piece in the center of the rear of the printer) and pull out any paper you can see.
Once you've removed the paper, the jam code should clear on the display, but if it doesn't, try resetting the machine. If the jam code is still there, that means there is still paper somewhere inside the machine. Check again to make sure you didn't miss any, and also lift the scanner bed to see if you can see any paper under there. (To lift the scanner, lift up with the tabs on either side until the scanner locks into place.)
Jun 03, 2010 | Brother Multi-Function Center MFC-240C...
Brother MFC 8460
Hi
There must still be a piece of paper in the machine check the fuser section at the rear of the machine maybe be piece there or check at the paper cassette area remove cassette and check that the paper hasn't got jammed as it feeds through.
Thanks
Dec 29, 2008 | Brother MFC-8460N All-In-One Printer
Brothe MFC-240C paper jam error msg won't clear
**, it is not fixed. I followed instructions on Brother web site and was able to find a piece of paper near the printhead, so I removed it. The printer makes a grinding sound when it tries to print and the same paper jam error returns and can't be cleared. I beleive that the printer repair cost will be more expensive than replacing it with a different printer, and it won't be Brother brand. I probably would not be able or have the tools to do any complicated repair job.
Mar 08, 2008 | Computers & Internet
Brother MFC790cw All-In-One InkJet Printer Logo
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
