Question about Cell Phones
Vida it headset wont pair to nokia lumia 720 windows 8 phone
SOURCE: no connection withe nokia HS-36W bluetooth headset
First check your headset pair with other handsets if ok. your headset is ok. then check your hand set connection is ok.The default password of hs-36w is 0000
Posted on Mar 12, 2007
SOURCE: pairing headset
you need to have the manual for hour jawbone headset and follow those instructions.  You have to put the headset in "pairing mode" and then once you do that (follow headset instructions) it's simple to just go to settings, bluetooth and tell iphone to search for the headset.
Instead of headset issues, we're having car speaker phone issues.  I have the iphone paired with a motorola bluetooth car speaker, and it works when you are making calls.  However when a call comes in, the speaker doesn't pick up, the phone just rings as normal.  That's a problem as you need to be hands free in our state, and if a cop happens to see you, you're in for it
Posted on Nov 22, 2007
SOURCE: accept code for a bluetooth headset
If this solution doesn't work hold down both the volume up and down buttons on the head set for about 5 seconds whilst searching for a new paired device with your phone then when asked enter the code 0000 and connect
Posted on Feb 11, 2008
trillian_tx
  • 4 Answers
SOURCE: bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
Posted on Apr 14, 2009
catht999
SOURCE: Nokia lumia 710 speaker phone and ringer don't
A friend of mine had the same problem. The 3.5mm headphone socket was playing up, thinking they were still plugged in. She plugged headphones in and give it a push and a wiggle, then took it out and now it works. Give it a try.
Posted on Nov 20, 2012
Nokia Lumia 800 Windows Phone 7.8 Bluetooth not work properly
soft reset your phone if problem persists hard reset
Oct 21, 2014 | Nokia Lumia 820
How do i calibrate lumia 720
Perhaps you find a solution her? and then you also have a link to to the nokia help line L720 touchscreen problems rebooting issue
Jul 14, 2014 | Nokia Lumia 720 Windows Phone Black
Unable to tranfer songs, files, pictures to nokia lumia 720... what should i do???
can you please tell me which operating system do you use? Windows or Mac ?
May 18, 2014 | Nokia Lumia 720
Delete All Contacts from Nokia Lumia 720 Windows Phone
Have you synced your Nokia Lumia to a computer, if so, you can delete all the contacts from your computer. Else you can go to Sign In , log in with your Windows-account, go to 'People' and select all the contacts you wish to delete (in your case all). Next click 'Delete Selected'. This should solve your problem, good luck!
Jan 04, 2014 | Cell Phones
My phone nokia lumia 720 windows display is not working,i think O S also correpted. Shridhar 8431520198
If this isn't due to your phone being dropped in water, try doing a soft rest. To do this........Hold the "down volume" and "power button" at the same time for ten secs, until it vibrates, then let go of those buttons. The phone will now reboot. This will not erase any of the content on your phone (i.e., games, contacts list, programs, etc.)
Hope this helps. :)
Sep 24, 2013 | Nokia Lumia 720 Windows Phone Black
How to do hard reset for nokia lumia 720
#Option 1, Hard Reset NOKIA LUMIA 720 with software menu:
  1. Turn on the NOKIA LUMIA 720
  2. Go to Menu Setting > Setting
  3. Choose About and choose Reset your phone
#Option 2, Hard Reset NOKIA LUMIA 720 with Hardware Key Button:
  1. Turn off NOKIA LUMIA 720
  2. Press and hold together Volume Down Button + Power Button until LCD show exclamation mark icon
  3. Now release all number 2 buttons.
  4. Press one by one continuously:
    1. Press and Release Volume Up Button
    2. Press and Release Volume Down Button
    3. Press and Release Power Button
    4. Press and Release Volume Down Down
  5. If the step finish, the NOKIA LUMIA 720 will do the hard reset or factory format by itself.
  6. Wait until it finish to format, then we will need to setup like new again.
Aug 20, 2013 | Nokia Lumia 720 Windows Phone Black
Nokia lumia 720 remove restriction
Hi. If you want to remove the network restriction from a Nokia Lumia 720, The safest and easiest way to do is to enter it's unique unlock code. You can get the unique unlock code for a Nokia Lumia 720 from www.wickedunlock.com at affordable cost with easy unlocking guide. Good luck mate.
Jun 08, 2013 | Cell Phones
Cell Phones Logo
15 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
