TOSHIBA AW-B700 KSE 6.0KG WASHING MACHINE E2 ERROR
  • 43 Answers
SOURCE: Haier washing machine E2 error
normally pump filter is the best place to start it could be jamed with a coin or hair clip if you take machine outside and empty it then lay it on its side you can access the pump take it off then stand up the machine and pour hot water into the soap draw check water should run out of bottom freely taking any fluff or bits with it now take apart the pump and clean it all out dry all components before reasembly if the machine still doesent wory could need a new pump
Posted on Nov 11, 2008
SOURCE: E2 error on homemaker washing machine.
I have an E2 error on the display of a homemaker washing machine model no HMWM8000. It will not pump out. The PCB does not have any visibly damaged components, which part is faulty, and how do i test a water level sensor.
Posted on Nov 08, 2009
  • 4 Answers
SOURCE: lerror E2 on toshiba aw8800s
throw it away u nob
Posted on Jan 12, 2011
richroth
  • 9472 Answers
SOURCE: hi we have daewoo washing machine coming error
Error code E2 is overflow problem, possibly related to the pressure switch.
If the pump runs continuously then try checking that the drain hose is not blocked or that the waste outlet is not blocked.
If that checks out OK then the pressure switch is stuck in the high level.
Take the capillary hose off from the pressure switch and blow down it to remove any residue stuck in the pipe.
Posted on Jan 14, 2011
ginko
  • 19396 Answers
SOURCE: Toshiba auto washing machine model
Hi.
E2 is not an error code. It means that the Spin only mode has been started and that the cycle is now over.
To reset the machine try disconnecting power (trip circuit breaker), connecting back, then hold down the Super Spin Dry button while you start the machine at the same time (press On while holding the other button). You should hear three beeps and the machine will be reset to initial settings.
Posted on Feb 01, 2011
My Toshiba washing machine model AW-A800MBK This have 4 LED lights, Now machine running some time drain and showing LED 2,3 glowing and then machine stop, What is the problem with this machine?
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times. E2 error code aw 8990st toshiba wash Washing Machines
Mar 13, 2018 | Washing Machines
Tip
Toshiba washing AW-9771UBB error code E2
i get Error code E2.. its stop working with out spin.
on Oct 18, 2016 | Washing Machines
E2 error code aw-8990st toshiba wash
E21: Lid open
E31: Load imbalance
Hope this helps
Jan 25, 2014 | Washing Machines
My washing machine toshiba aw-9760s Kept showing this "E2 -3" problem. Whenever i close the lid to start washing my cloths. Anyone here can help me? In need of answers A.S.A.P
I also have a Toshiba AW-9790S, and encountered similar problem. The E2-3 would occur sporadically and halt the washing programme. E2-3 error occurs when the washing machine detects that the lid is not properly seated and locked during the rinse or spin cycles. I took mine apart and resolved my problem by cleaning the contacts for the switches. There are 2 contact switches at the lower right side; 1 for sensing the lid is closed and 1 for sensing that the lid lock is engaged. Both the switches were slightly oxidized which prevented current flow and the sensors from working properly.
Nov 02, 2013 | Washing Machines
Toshiba washing machine model AW 9790s error code E1
E1 is the drainage hose error, check the drainage pipe hose is not blocked damaged or filled with water or frozen, or maybe the return sensor for the hose is switched sensing something is wrong with the pipe but isnt. check the drainage hose ensure all water is out of the hose. open and close the lid one, then press the start/hold button this should reset the error alarm.
I hope this was useful
Feb 15, 2013 | Washing Machines
My AW-1190S toshiba washing machine was showing error code E2-3
My Toshiba aw1190s shows error code E21. What the problem.. Tq..
Nov 22, 2012 | Washing Machines
HOW TO FIX AW-1170S WASHING MACHINE TOSHIBA ERROR E2
LOOK IN YOUR MANUEL ,,FOR TROUBLE-SHOOTING ERROR E2 OR CALL MANUFACTURER SUPPORT
Nov 11, 2012 | Washing Machines
My AW-1170S toshiba washing machine was showing error code E9-5...what does it mean?
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
Nov 13, 2010 | Washing Machines
ERROR E7 TOSHIBA WASHER AW8960S
check the water level switching or door sensor
Sep 09, 2009 | Washing Machines
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
