Question about Canon i-SENSYS FAX-L150 Laser Multifunction Printer - Monochrome - Pla
Why does it make black copies? - Canon i-SENSYS FAX-L150 Laser Multifunction Printer - Monochrome - Pla
Can't find copy menu to take a copy of an address
May i know the printer/ copier model number to assist you better ?
The general rule is, If your printer is a Color printer, then it should have a button/option for COLOR copy.
If it does not have a button/option for Color that means it prints only in black.
Jun 13, 2011 | HEWLETT-PACKARD Hp Ac Adapter Power...
Copies made are totally black. what do i do? i changed cartridged, put in new paper then copied. it copied fine after 20pages, copy sounded like it was jamming up, paper came out with some parts black....
Hello limay_uera
Please check your Printer setup. or options ( I am not familiar with this printer. what terms they use- I'm not sure) Ther will be options for Print in Color or Black. Make sure the radio button for COLOR is checked. This way, black and color both will print in the correct color. So leave it on color even when you want to print in Black. The black radio button is there for a different reason.
Hope this will help you.
luciana44
Nov 19, 2009 | Canon FAX-L800 Plain Paper Laser
HP Officejet 6210 All-in-One: Black Ink Copy Problem
i've fixed a simular issue recently, it could be your print head has developed a issue\blockage for the nossles for the black ink tank, it could be mixing colours from word but a black white copy will just use the black ink, try removing the head and using isopropol on a qtip to clean the head for the black only.......
Aug 13, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Copies of xerox copier model 5201 almost black
USUALLY Black copies are a Drum grounding problem. I have not seen "black" copies due to old, bad, or otherwise inferior toner... Although, It is a Xerox, LOL
Apr 03, 2009 | Office Equipment & Supplies
Black streaks all over copy
Copies come out with one black line
Feb 05, 2009 | Sharp AL 1631 Copier
4 sets of copy counter numbers on canon imagerunner 2200
101:Total black copies and printed pages
103:Total A3 black copies and printed pages
201:Total A4 black copies
203:Total A3 black copies
Oct 31, 2008 | Canon imageRUNNER 2200
Error 9-363
NOTE: The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
NOTE: The above solutions are based on jobs using 8.5 x 11 inch paper, single sided, with no more than 28% coverage.
Feb 18, 2008 | Xerox DocuColor 12 Printer
Totally black transmissions
Copy lamp has blown, light should shine in where original is placed.... it isnt lighting the paper up, so reflection received is black hence black transmit/copy result
It is just a small specilised floro but would probally be more ecomomical to replace machine than to fix it.
Nov 19, 2007 | Brother Personal FAX-190
Copies print all black
Make 1 copy with the lid open & verify that the scan lamp is lighting & that the scanner moves. A blown lamp is the most common cause for all black copies.
Jun 11, 2007 | Gestetner 5499 Black and White Copier
Canon i-SENSYS FAX-L150 Laser Multifunction Printer - Monochrome - Pla Logo
49 people viewed this question
old marine
old marine
