Question about Sony NWZB162F MP3 Player
HOW CAN I TRANSFER FILES FROM SONY NWZ B162F WALKMAN TO MY PC VIA USB
Tip
How to transfer songs, videos and pictures to a Sony NWZ Series Walkman Players
It is so easy to transfer music files, videos and pictures to a Sony Walkman using Windows Explorer. Of-course, it is almost same for other manufacturer products as well. You can use theWindows Explorer to transfer files (music, images and videos) to a Walkman Player. Once you connect the Walkman Player to the Computer, it will display asan additional storage media under My Computer. Please follow the below steps toaccess the Walkman Player using Windows Explorer.
  • Click Start and then click My Computer .
  • In the My Computer window, under Other , double click the icon for your portable player.
  • In the My Computer[Name of your portable player] window, double click Storage Media .
  1. Now, drag and drop the music files or folders into the MUSIC folder.
  2. Drag and drop video files or folders into the VIDEO folder.
  3. Drag and drop picture/image files or folders into the PICTURE or DCIM folder.
Now, the only thing you want to make sure isthat you're transferring compatible files to the player to use in it.The video files should meet the following requirements.
MP3 is fine for audio and for images, jpeg wouldbe good.
I hope this instructions help you to transfer files to the Sony Walkman player.
How to transfer songs, videos and pictures to a Sony NWZ Series Walkman Player. How to transfer files to Sony MP3 player. Transfer videos Sony player. Sony video walkman player transfer videos. Unable to transfer videos. Videos does not play in Sony video. Sony mp4 player, how to transfer. NWZ-A829BLK NWZA829 NWZ-S615F NWZ-S610 NWZ-A820 NWZ-S545 NWZ-E436 NWZ-A818 NWZ-B142F NWZ-A801 NWZ-B135F NWZ-S710F NWZ-A728 NWZ-W202 NWZ-S610 NWZ-E438F NWZ-E435F NWZ-B130F NWZ-X1000 NWZ-A826 NWZS615F NWZS610 NWZA820 NWZS545 NWZE436 NWZA818 NWZB142F NWZA801 NWZB135F NWZS710F NWZA728 NWZW202 NWZS610 NWZE438F NWZE435F NWZB130F NWZX1000 NWZA826 NWzE354BLK NWz-E354BLK NWzE354 NWzE354B NWz E354BLK NWz E354 BLK Sony NWzE354BLK NWzE353BLK NWz-E353BLK NWzE353 NWzE353B NWz E353BLK NWz E353 BLK Sony NWzE353BLK NWzA545BLK
NWzS545BLK NWz-S545BLK NWzS545 NWzS545B NWz S545BLK NWz S545 BLK Sony NWzS545BLK NWzS544BLK NWz-S544BLK NWzS544 NWzS544B NWz S544BLK NWz S544 BLK Sony NWzS544BLK
on May 11, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
How to change battery on my nwz-162f
just plug it in seems like it has this Built-in 170 mAh rechargeable lithium-ion battery so it doesn't need changing just charging unless it won't charge then check youtube and see if there is a video on it
Sep 07, 2013 | Sony nwz-b162f walkman mp3/mp4 usb 2.0...
Sony walkman nwz-b162f driver free
i have problem with my sony walkman NWZ-B 162f my pc is not detecting ,im using windows7, i have did exactly as suggested above, but still i can find any usb mass storage, when i reset my player its keep on loading........... any one help me plz plz :/
Oct 03, 2012 | Sony NWZB162F MP3 Player
I want to add video songs via sonic stage but they are not added..
The NWZ-S616F Walkman Player is not transferring the music using the SonicStage Software. Sony old Walkman player was using the SonicStage Software for transferring the files. You can use Windows Media Player 11 or higher, Media Manager for Walkman, Content Transfer Software or Windows Explorer for transferring the files to the Player.
Click here and select the operating System to download the Software for transferring the files.
Thanks for using FixYa.
May 06, 2011 | Sony Walkman NWZ-S616F MP3 Player
I cannot transfer any files to my pc or from it
The Sony Walkman NWZ-B133F model does not require proprietary Sony software to transfer songs from PC, it supports USB transfer facility like direct "Drag and Drop" feature.
You need to check if your PC identifies the device as a connected USB device, since you have not specified which OS are you using on your machine.
Nov 23, 2009 | Sony NWZB133F MP3 Player
I downloaded songs onto my mp3 but they wont play
Here is the info from Sony:
Is it possible to drag and drop music from the Apple® iTunes® software to the portable player using the Content Transfer Application? Solution
sp.gif sp.gif Yes, if you have iTunes software installed, you can transfer music and playlists from iTunes software to the Walkman® player by dragging and then dropping the files to the Content Transfer application.
NOTES:
  • The Content Transfer application supports data transfer from iTunes software 7.6 or 7.7 to the Walkman player.
  • The Content Transfer application supports data transfer from iTunes software 8.0. However, for playlist transfer from iTunes software 8.0 to the Walkman player, make sure you are using the latest version of the Content Transfer application. The latest version can be downloaded from the Sony Support Web Site at http://esupport.sony.com
  • Digital Rights Management (DRM) copyright-protected files are not supported. iTunes music files may be able to be upgraded to iTunes Plus music files, which do not contain DRM.
  • Do not disconnect the USB connection during data transfer.
  • If there is insufficient free space on the portable player, the data cannot be transferred.
  • The Content Transfer application is included with most newer Walkman Video players. It also is available for additional models in the NWZ-A, NWZ-E, and NWZ-S series. Some models may require an update to be compatible. Additional model-specific information can be found in the Drivers & Software section of the Sony Support Web Site at http://esupport.sony.com.
Jan 26, 2009 | Sony NWZ-E436F MP3 Player
Sony NWZB162F MP3 Player Logo
20 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
