Question about Xerox CopyCentre C123 Copier
When scan document, failed to scan, message : A
When scan document, failed to scan, message : A fault or an error has occurred. See Users Guide for information on fault code 072-210. Any body can help I'm using Fuji Xerox DocuCentre-III 2007 PCL 6. Thank you very much for any information.
SOURCE: xerox 3535
email
Posted on Jul 15, 2008
SOURCE: fuji xerox document centre C250
Press machine log in button, enter 11111 confirm, this will take you to sys admin mode, from here you can navigate into sys settings to configure network,copy and fax defaults, and also auditron admin if this is the password mentioned, if the 11111 password has been changed hold the zero button for a few seconds then press start while still holding zero enter 6789 to get into diagnostics, and you can navigate through to the above settings caution be careful what you change in this mode.
Posted on Sep 04, 2008
pineworks
  • 4041 Answers
SOURCE: xerox phasor 8400 - fault 37,004,40:157517"
Hi I can gave you some error codes but this all I can do hope it be of help to you.
8,009.4x:CAP_FAULT_MP_NO_ CLUTCH_STALL:
  • The media path motor has stalled while moving without the clutch engaged.
33,001.4x - TM_DEV_FAULT_MPT_WIDTH_VALUE_TOO_LOW
  • Tray 1 status:
1. Check the wiring and connectors from the front door to the I/O board.
2. Run the Test Tray 1 Width Sensors.
3. If the test fails replace the front door.
4. Replace the I/O board.
08.055.44:
  • The media path drive module has stalled while engaging the head tilt.
37,008.44:
  • The Preheat preheater is not drawing the expected power from the supply.
Run the Preheat Heater test, check the wiring. If test fails and no apparently problem is evident, replace the preheater.
05,002.42:
  • Problems with the Y-axis. It could be the belt,motor or the drum.
7,008.4x: PM_FAULT_HEADTILT_NOT_ ENGAGED
  • The printhead tilt is not engaged, so it didn't tilt back properly or the printhead is stuck in the tilted position by the tilt lock arms. The process motor gear train getting out of sync can also cause this error.
1. Try rebooting the printer.
2. Check for an obstruction or damage in the process gearbox.
3. Ensure the gears are correctly aligned and homed. If faulty replace the process gearbox
assembly.
4. Run the Tilt Axis Drive test to test the headtilt.
5. Run the Head Maintenance Wiper Clutch test. If the test fails, replace the wiper drive clutch.
6. Run the Wiper Axis Drive test.
7. Replace the exit assembly.
7,010.4x: PM_FAULT_HEADTILT_HOME_ERROR
  • The printhead is stuck in the tilt position by the tilt arms. The process motor gearbox being out of sync can also cause this error.
1. Reboot the printer.
2. Verify the lock arms rotate correctly.
3. Check for spilled ink around the printhead.
4. Check the process motor gears for damage. Ensure the process gears are correctly aligned and homed.
5. Verify the process gear box, process shaft, and drive module shaft are at home position.
6. Verify the headtilt gear will engage, see the home positioning procedure on page. You can manually engage the headtilt gear.
7. Run the Tilt Axis Drive test.
8. Run the Process Motor test.
9. Run the Head Maintenance Clutch test, if the test fails replace the clutch.
10.Run Wiper Drive test. If this fails inspect the wiper drive system.
All The Best: Pineworks
Posted on Jan 30, 2010
  • 33 Answers
SOURCE: for document centre c250 fuji
Defective IIt/IPS board. Is very expensive. Call you local Xerox service number and ask them for part number 160K99811 and how much it would cost to get it fixed.
Posted on Sep 08, 2010
SOURCE: My printer Fuji Xerox C4350
Click on the link below to view the C4350 owners manual, inside this manual will have error codes and what to replace:
http://www.fujixeroxprinters.com.au/downloads/uploaded/DPC4350_User-Guide_en_c239.pdf
Posted on Nov 29, 2010
I need a list of erro codes and definations for xerox workcentre 7232 serie. and I want the solution to my xerox workcentre 7232 copier. when switched on it shows erro 093-311
When a fault occurs, the touch screen displays a message on how to clear the fault. Some faults indicate customer maintenance, while others require the attention of the Key Operator and/or System Administrator. The following table represents some of the fault codes and their corresponding corrective actions. These may appear in the Print Queue or Faults List available in the Machine Status mode.
002-770 The job template could not be processed due to insufficient hard disk space. Delete unnecessary data from the hard disk.
003-750 No document was saved for the double-sided Booklet Creation feature. Check the setting of the double-sided Booklet Creation feature.
003-751 The specified document area is too small. Select a higher resolution or a larger scan area.
003-754
003-755 An error occurred in the document scanner. Reset the document, and scan again.
003-756 The fax document is completely white. Check that the original is not white, or that the front and back sides have been reversed.
003-760 Incompatible features are selected in the document scan conditions. Check the selected options.
003-761 The paper size in the tray selected by auto tray switching, differs from the paper size in the tray selected at the tray selection. Either change the paper size for the tray, or change the paper type priority setting.
003-763 An error occurred when reading the Gradation Adjustment Chart. Place the chart properly on the document glass.
003-780 Compression of scanned data was unsuccessful. Lower the resolution or reduction/enlargement ratio to reduce the data size, or send the document in
smaller segments.
003-795 The reduction/enlargement ratio exceeds the setting range when the scanned document is enlarged/reduced to the specified paper size. Directly enter the reduction/enlargement ratio, or change the paper size.
003-981 Stapling mixed size documents is available only for documents with the same width. Cancel the staple feature or reset the documents with the same width.
005-210
005-275
005-280
005-283
005-284
005-285
005-286 An error occurred in the document feeder. Contact the Xerox Welcome Center.
Jan 16, 2011 | Xerox Office Equipment & Supplies
Trying to scan I get the error message ''A Sharing violation occur
Create a new windows user account .Try to scan the document in the new admin user account.
Aug 17, 2009 | Lexmark X5495 Printer
I have a fujitsu 4120 scanner that will not pull the paper even after i changed the roller and pad.
Does the scanner displays any error message on the scanner panel? Is there any TWAIN error message?
If paper jam occurs, U1 error will be displayed on the scanner panel and TWAIN driver will display " Paper jam the ADF (Code DS32002)" error message.
This error is detected when one of the followings occurs:
1) A document does not reach the TOP sensor while the scanner has transported the document about 250 mm to pick. (The scanner
performs retry operation.)
2) The trailing edge of a document does not reach the TOP sensor after the scanner transports the document by the length (L) below. (The document may have slipped on the rollers) Scan condition Transported length.
In order to assist you with your scanner issue, Please provide the issue details with error message.
If nothing is being displayed, then the issue could be due to failure in Pick Motor function or Pick Sensor malfunction.
Hope the above information is helpful.
Thank you for contacting FixYa.
Regards,
TechSatya
Apr 24, 2009 | Fujitsu fi-4120C Path-Through Scanner
RX595 Printer error has occurred
try to turn off the printer for 5 min. and unplug the power, and then turn it on again, this worked for me, and apparently this error associated with all Epson printers,
mine is 8300
Apr 07, 2009 | Epson Stylus CX9400 Photo Printer
Error 2200
The 2200 error message indicates a scanner stall or jam. The steps below will help you to resolve the issue and clear the error message.
Printer Reset
NOTE: The embedded links in the table lead to specific troubleshooting documents.Step Action
Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.
Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3.
Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 02, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Connection issue between XP Pro and HP C6180 all-in-one
Hi Lynn,
Unfortunately, HP.com doesn't have a very satisfying online solution to your problem. Still, there are a few things you can try.
The first is a general diagnostic check of your scanner. HP provides a doc that takes you through some steps, many of which you probably already tried, to see if it's a simple fix:
An error occurred while communicating with scanning device
The next document is a set of diagnostic steps to address errors trying to scan to a PDF:
An error occurred while trying to scan to a PDF
I don't know if the current situation was created by a fault in the device or some recent change in your configuration settings. I do know you can use the HP Director software installed on your computer to set the scan destination settings:
Settting "Scan To" Destination using HP Director
Those were the most relevant solutions I could find for you. I hope some of this information is helpful. Good luck.
-Trip
Oct 07, 2008 | HP Photosmart C6180 All-In-One InkJet...
I am receving error messages E301 or E100
E100 - 001 and 002:
BD error has occurred.
• The laser unit has a fault.
• The BD PCB has a fault.
• The laser driver PCB has a fault.
E301:
The scanning lamp intensity has a fault.
• The scanning lamp has a fault.
• The CCD PCB has a fault.
• The DC controller PCB has a fault.
Seems to that you have issues with dc controller pcb
Oct 04, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Priner error occurred.Please see users guide?
Try turning off the printer and turning it back on. If the error persists, it's time to call Epson and have them service the unit.
Jun 20, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Open Questions:
See all Xerox CopyCentre C123 Copier Questions
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
