Question about Alias Maya 6.5
Sansa e260 and real player
1) my computer will noy always recognize the hardware. I have windows xp.Iam not sure which usb mode to be in.The computer wont write the music as it tells me it cannot see the format mp3 and wma.Icannot empty my sansa of music I had on it from my old computer. my firmware updates are new but i have tried everythimg. Please help. regards lisagail
  • prpmd Nov 19, 2007
    I cannot empty my Sansa 260. Neither Real Player or Media Player will synch it down, saying it's full (it is, as Media Player auto loaded everything in duplicate and triplicate) after "synching." It now takes 5 minutes everytime it's turned on just to "refresh data."
My computer wont recognize my sansa e260
Make sure USB mode is MSC....If this doesn't work make sure that you are connected to a 2.0 USB port....I had to install the update on to my labtop and finally it recognized it and updated....
Download Update if you haven't yet(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe)
Then connect to your computer and see if it works
Hope it does..........Please rate
May 20, 2009 | SanDisk Sansa e260 MP3 Player
MY SANSA ISNT RECOGNIZED BY MY PC!
Try connecting it to another computer and see if it will recognize it as sansa or removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansa and add the Usb Mode. Try to connect it to your computer at home it should recognize.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier Make sure USB mode is MSC I use my computer to drag and drop my music from my music folder to the sansa media folder.... Open my computer click on folder what ever folder has your music in it and drag to media folder and drop (click on the (+)where it say's sansa )
Apr 14, 2009 | SanDisk Sansa e260 MP3 Player
No USB mode on my sansa e260
I think this is what you are asking. Forgive me if I didn't understand the question correctly.
Switch on the mp3 player. Select "Settings", scroll to "USB Mode" and make sure that "MSC", not "MTP" is selected.
When you next plug in the USB connector, your PC should recognize the Sansa as a standard USB device.
Apr 07, 2009 | SanDisk Sansa e260 MP3 Player
Computer(s) wont recognize sansa e260
i have the same SANSA e260.....and the same problem....its easy just turn on your sansa then push the menu botton, slide the wheel in the center and at the end of the options say USB enter there and change usb mode from MTP to MSC mode.....and ready
Jan 02, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260 says connected but device not recognized
Substitute REC fo volume + in the following:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Nov 16, 2008 | SanDisk Sansa e250 MP3 Player
How do I get my Sansa e260 to appear in Windows Media Player (v. 11; Vista)?
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 12, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e-260
May 04, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260 not being read by the system?
Does it show up in your windows explorer as another drive letter ?
Nov 26, 2007 | SanDisk Sansa e260 MP3 Player
Recognise my sansa
to old for vista to recognize
Apr 29, 2007 | SanDisk Sansa m240 MP3 Player
I agree with the above suggestion. Try setting the USB Mode under "Settings" on "MSC" on the Sansa. My computer would not recognize the e260 when the mode was set to "MTP"; works fine on "MSC".
Dec 27, 2006 | SanDisk Sansa e260 MP3 Player
Alias Maya 6.5 Logo
97 people viewed this question
Top Alias Computers & Internet Experts
Ekse
Alun Cox
Are you an Alias Computer and Internet Expert? Answer questions, earn points and help others
