Question about Panasonic AG-DVX100 Mini DV Digital Camcorder
DVX100B Batteries won't attach
I've had a used DVX100B for a few weeks now, everything was working great until tonight the batteries won't connect to the camera. I've tried to slide them in, but where the 4 metal connector slots would grab each other, there's no attachment now. Why is this happening?!
  • 22 Answers
You probably broke off the retaining button that is above the battery when installed that says Push to Release.
Posted on Aug 10, 2009
CX7300 Digital camera won't turn on. New batteries get hot after being put in the camera after a few minutes.
No. This camera requires service/repairs, the repairs will be more than this model camera is worth !!!!
Nov 12, 2012 | Kodak EasyShare CX7300 Digital Camera
The ******** on my bouncer seat does not work
Could be a dirty/bad connection with the batteries. Try this: remove the batteries, scrub the terminals with a slightly damp cloth and dry it off. (scrub the little metal parts that the batteries come in contact with.)Then try the batteries again. I hope this helps. Good luck to you.
Mar 13, 2012 | Fisher Price Baby Gear
I need to reattach two deep cycle batteries to my fleetwood rv. Do I attach to one battery ms then attach the extra leads to the other battery , or do I attach the positive lead to one battery and the...
It should be positive to positive, negative to negative - parallel, not serial.
The simple way to tell is by how many cables you have. If you've got one positive and one negative, and only one jumper, it's a 24 volt system and should be connected in serial. If you've got one positive and one negative and two jumpers, it's a 12 volt system, and should be connected parallel.
If in doubt, connect up in parallel and test things. If everything works, it's a 12 volt system and you're good to go. If everything doesn't work (lights are dim, inverter doesn't give AC, etc.), it's a 24 volt system and you need to change to serial.
Serial - positive to system connection on battery 1, negative on battery 1 to positive on battery 2, negative on battery 2 to system negative.
Parallel - positive on battery 1 connects to positive on battery 2 and the system positive, negative on battery 1 connects to negative on battery 2 and the system negative.
Jul 06, 2011 | GPS
Replaced battery, bike started fine. Let it sit overnight, won't start. Won't even crank, just clicks once then nothing, the Neutral light shuts off and the lights started flickering.
To begin with, I'd have that battery load tested to see if it's any good. I've seen brand new batteries that were bad. It it checks OK, check all the connections that go to the battery. Be especially attentive to the smaller wires that attach to it. I've seen battery acid eat the wire out of the insulation leaving the insulation intact and the wire appeared fine. If the wire bends too easily, be suspect. If the wires have the "crimp on" connectors, make sure they're tight. Your problem sounds like a bad connection somewhere.
Good Luck
Steve
May 19, 2011 | Harley Davidson FXST Softail Standard...
Digtal answering machine not working.
I don't know yet if this is a resolution, but I'm going to try this tonight. Unplug all bases and remove all batteries from all handsets -- leave this overnight.
Here's the history of my problem. I rec'd this phone for my birthday. 3 weeks in, power went off in my building and answering machine part stopped working. I took it back to the store, and they gave me a new one. 4 weeks in, another power outage and I have the same problem. I called Panasonic, and they told me to unplug all bases and remove the batteries in the handsets for 'a few minutes' to reset the units. I waiting 10 minutes, and replaced all batteries and plugged in all the bases again. No luck, answering machine still did not work. I noticed, however that the phone did not reset as I still had all my phone numbers and caller id history.
I called my brother who is an electrician, and he advised me that the base has a 'capacitor(sp?)' and it will probably take a few hours for it to 'drain' so the phone will reset itself. His suggestion is to unplug all the bases, remove all the batteries and leave everything OVERNIGHT. By that time, the power store in the base should hopefully be wiped out and the phone should reset like new. I will try this tonight and let you know if this works.
Jan 31, 2009 | Panasonic KX-TG1033S Cordless Phone
My Mouse died
Did you check the batteries to see if they are good. Some individuals are having to replace the batteries sooner then they should have to. Good place to start. Hope this helps. Bud
Jun 11, 2008 | NexxTech NWOMMI Mouse
Battery problem
Had the same problem and I have changed over to disposable AA Lithium batteries and no problem since. (About 9 months now)
Jan 01, 2008 | Canon PowerShot S3 IS Digital Camera
Panasonic AG-DVX100 Mini DV Digital Camcorder Logo
60 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
