Question about Frigidaire FRT21P5A Top Freezer Refrigerator
Water accumulates in the bottom of refrigerator, under storage bins.
SOURCE: leaking water
dianaluscou,
The freezer has a drain hole in it typically in the back at the bottom. This is clogged and needs to be cleared out in order to stop the water problem in the refrigerator section. Remove everything from the freezer and if needed defrost. Look for the drain hole and you can pour hot water or use a hair dryer to melt the ice in the drain. Once it is unclogged, the water problem should stop.
I just did this about 6 months ago on my own refrigerator/freezer.
Cathy
Posted on Jan 21, 2009
  • 2976 Answers
SOURCE: accumulation of water in bottom of fridge
You probably need a new door deal for the freezer. When you cet too much condensation in the freezer, it drains down the back of the refrigerator section during the defrost cycle. Check under the produce bins for a drain. If you don't have one, you're not alone. I used to have have to wipe mine out every other day until I finally replaced the seal.
Posted on Feb 02, 2009
  • 3 Answers
SOURCE: water accumulation under crisper bins
Check that the hole at the back of the fridge is not blocked with gunge.  There should be a drip tray at the rear with 2 slopes towards the hole where the condensation drains to.  Some cabinets come with a little rod to clear the blockage.  The rod may live in the hole alowing water to drain around it.  Have a peek!
Posted on Feb 22, 2009
Maytag317
  • 1136 Answers
SOURCE: I have a side by side refrigerator. There is water at the bottom of the freezer. It is thick enough to freeze the bottom with the first pull out storage shelf. I can't figure out where the water is co
Hi, You need to get to the defrost drain. Remove the ice (do not use a sharp object)
Once you can get to the rear freezer panel, remove the screws and take the rear panel off. Now you should see the drain pan. Remove the ice (Hair dryer works good) and locate the drain hole. Remove the ice in the drain hole and flush hot water through it. You might need to push a wire through it or you can flush water through it with a baisting seringe. I hope this helps. If I can help further, please let me know.
Thanks
Vic
Posted on May 16, 2009
TheMobilian
  • 8220 Answers
SOURCE: we have water laying on the bottom shelf every day
Under the evaporator coils is a drain. It catches the defrost water and directs it to a pan above the compressor where it evaporates. The drain clogs and water cascades down the back wall ending up under the crispers. Get a shop vac and open the drain.
Posted on May 17, 2010
Where can I access the defrost drain hole in my Kenmore model 253.74879404 Refrigerator? Disassembling the freezer did not work.
I've used used a compressor for that drain hole at the back of the fridge. A hanger wire will work too. I've never tried it but maybe a can of compressed air might work also.
The water drain line is plugged and that little catch tray is overflowing. That's why you're ending up with water under your bins inside the fridge. The problem is not in the freezer or else you'd have a skating rink on the floor of the freezer.
I don't recognize the photos exactly but they're all the same principle. Take everything out of the fridge , including the racks. It's far easier than o find the screws and disassemble the drain "catchall".
Good luck.
Dec 18, 2014 | Kenmore Refrigerators
Water accumulates under vegetable bin (bottom of refrigerator) every couple of days
If this is an older style top mount refrigerator than most likely the drain is clogged causing the water to leak into the fridge during the defrost process. What's the model number?
Jul 06, 2011 | Refrigerators
HOTPOINT side by side. water and ice accumulating at bottom of freezer under bin. what is causing it? how do I fix it?
Well I have the same problem and my husband had to shut the water off. But I was reading that its the little hole at the far back on bottom that gets clogged up or frozen. I looked and it is that problem but Im not sure how tp fix it. I read that hot water and vinegar should do the trick. GOOD LUCK.
Oct 16, 2010 | Hotpoint HSS25GFP Side by Side...
My freezer is getting a lot of ice buildup at the bottom and I am now getting water buildup under the storage bins in the refridgerator as well. What is the problem and can I fix it myself? Please advise....
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 25, 2010 | Whirlpool EV171NYMQ
Water drips from freezer and runs down to bottom of refrigerator, under slide out storage bins. After a few days, you need to mop up water. Otherwise it works great. What is wrong.
Check your door seals they could of inavertntly been pulled from the channels. Allowing air from the outside to get in. Just a quick guess.
Jun 18, 2009 | Refrigerators
Water leaks under veg bins.. Cannot tell where it is coming from. Accumulates slowly
This refrigerator look like mine (Picture).
Mine did the same thing. If it is the same then this is what I did.
Look under the there is a collection tray.
This tray collect the water.
At the bottom of the refrigerator (Inside where the water collect) is a cap.
The cap has cap would have holes or a slot that allow the little water to fall to the collection tray.
Mine has slots and was block up.
clean it out and that should do it.
The water should be able to fall to the tray at the bottom.
I do hope this help you.
Mar 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Accumulation of water in bottom of fridge
Feb 02, 2009 | Frigidaire FRT21G4B Top Freezer...
Water accumulates under vegetable bins and spills out the front
the water is coming from the freezer when is defrosts. the drain line is in the back wall of the freezer and may be clogged up with ice. clean out the freezer and pour some hot water in the very back of the freezer, this will hopefully unclog the drain. if not, then you have to take the back wall out of the freezer to get directly to the drain line. there should just be a couple screws holding it; it is just an aluminum or plastic panel.
Jul 06, 2008 | Whirlpool EL7ATRR Refrigerator
9 yr.old GE profile top/bottom refrigerator
There could be many things that cause these symptons. Defrost timer not working, bad door seals, or lack of freon. It may be less expensive to replace the frige than repair it.
Oct 20, 2007 | Kenmore 18.3 cu. ft. Top Freezer...
Frigidaire FRT21P5A Top Freezer Refrigerator Logo
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
