Question about Logitech Z313
The ic was damage,,my i know the excact combination of this ic....can u help me pls....
No Sound!! Hp w2207 Pls Help!! Por favor ayuda!
Where is the IC U11 located? is it on the power supply or the buffer PCBs?
You have to have skills to remove and solder the IC and if it's a surface mount then, you need to have the right soldering equipment and you must be an expert.
In my opinion, I would try to replace the whole board instead.
Best of luck
www.aaatvservice.com
May 29, 2012 | HP w2207 Monitor
K770i sim ic location in board
i want to know sonyericson sim ic location in board.pls show me now
Apr 05, 2012 | Sony Ericsson Cell Phones
Nobel tv... model no:dcl 3482 My remote control is lock...pls tell me how to unlock my remote control...thanx
my nobel tv dcl 3482 woofer ic damage i reapir to macnic and lost the ic number please send me woofer ic number
Jun 08, 2011 | Directed 434MHZ Remote Control
My tv is making a pulsating sound like a heartbeat , its continuous.
Hello
Your Combos' audio output Ic has damaged. Just open it, locate the Ic , resolder it out of board, and replace it with a new one of same type and number. Ok
Nov 23, 2010 | Philips Televison & Video
The black ink stopped working but is still registering as still being some in the cartridge. How do i make the black ink work?
Printer estimates how much ink is left in the cartridge and there is no way it can know excact amount of ink. You should install another another one.
pls vote so I may continue sharing
Nov 09, 2010 | Lexmark Optra Color 1200 Led Printer
My Nokia N72 display does not work, the modem works and I can connect to internet, and check sms and send sms using pc suite, pls kindly help me MP
Dear Friend , Your Problem Might Be
  • Display Damaged
  • Display Connector Damaged
  • Display IC damaged
  • Some Components Related to Display Damged
Kindly Check above things..Your Problem Solved.....
You may feel Free Contact mE.........
Is this Helped you...Rate me....
Thanks for Using FixYa
Apr 01, 2010 | Nokia N72 Cellular Phone
HP Color LaserJet 2600 Printer color shifting
this will solve the problem... check out this link
Thanks Good Luck
Appreciate to rate as "Fixya"
May 09, 2009 | HP Color LaserJet 3500 Printer
China mobile ringer problem
sigmatel s890 ringer not working pls give me a solution immedietly
Sep 16, 2008 | Handmark Software MobileLists (950142) for...
Display dim
it was the display ic., and combiner to produce lights it got grounded ..gotta go to center and fix the light combiner or capacitor..or the display ic... but if it is backlight problem of the lcd.. go to the light combiner capacitor and not to the ic..
Apr 15, 2008 | Sony Ericsson W850i Cellular Phone
No Sound
sounds like a cold solder connection on the audio output ic?? maybe even an audio plug from the deck assy.
Apr 05, 2006 | Panasonic PV-C2780 27 in. TV/VCR Combo
Logitech Z313 Logo
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
