Question about Fisher and Paykel Ovens
Fisher & paykel 600 series oven door does not close properly - door is loose and open at the top, heat escapes from sides and top of door.
catriver
  • 878 Answers
SOURCE: The oven door are not closing all the way
spot, Maytag put out a service bullitin on this issue....TDC-0017B-B, They put out a new hinge kit...part #12002111 for single and 12002112 for double units. This may be covered under this service flash. Call Maytag service and inquire about the above mentioned service bullitin. Problem addresses doors not closing...Catriver..post back.
Posted on Sep 03, 2006
  • 1170 Answers
SOURCE: Fisher Paykel electric oven doesn't heat in Bake mode
Electric Oven: Repairs and Maintenance Electricranges and ovens are generally easy to repair, because there's not muchto go wrong and there's not much you can do. Most repairs are actuallyreplacements, a matter of unplugging the old part and plugging in thenew. Most of the malfunctions that affect electric ranges involvefaulty heating elements.
Caution: Beforedoing any work on an electric range or oven, make sure it's unplugged,or turn off the power to the unit by removing one or more fuses ortripping one or more breakers at the main entrance panel or at aseparate panel. If the range is fused at a separate panel, this panelmay be located adjacent to the main panel or in a basement, crawlspace, or other location. If there is a grounding wire to the range,disconnect it. Make sure the power to the unit is off.
Servicing Fuses
Ifthe range or oven is receiving power but doesn't work, the unit mayhave its own fuse or circuit breaker assembly. This assembly is usuallylocated under the cooktop of the range. In some units, lift the top ofthe range to gain access to the fuse assembly; or lift the elements,remove the drip pans, and look on the sides of the cabinets. Inside theoven, look to the back to spot the fuse assembly.
Ifthe unit has this additional fuse or breaker system, components such asthe oven light, the range heating elements, the timer, and aself-cleaning feature may be separately fused.
If thesecomponents or features fail to work, don't overlook the possibilitythat the fuses have blown. To replace a blown fuse, unscrew the oldfuse and install a new one of the same type and electrical rating. Ifthe unit has circuit breakers, push the breaker or reset button, whichis usually located on the control panel.
Replacing Range Heating Elements
Whena range heating element burns out, it's easy to replace. But before youdisassemble the range to check or replace an element, make sure therange is receiving power. Here's what you can do:
Step 1:Check the power cord, the plug, and the outlet. Then look for blownfuses or tripped circuit breakers at the main entrance panel or at aseparate panel.
Step 2:Check the fusing system inside the range. If the circuit is broken,restore it. If the range is receiving power, go on to check the element.
Step 3:When the element is cool, remove it. In most ranges, each top heatingelement is connected to a terminal block in the side of the elementwell. To remove the terminal block, lift the element and remove themetal drip pan that rests below it. The element is held by tworetaining screws or is push-fit into the terminal block. To remove ascrew-type element, remove the screws holding the wires. To remove apush-type element, pull the element straight out of its connection.
©2006 Publications International, Ltd.
To remove a range heating element, remove the screws holding the terminal
wires, or pull the element straight out of its connection.Step 4:Test the element with a volt-ohm-milliammeter (VOM) set to the RX1scale. Disconnect one of the electrical leads to the element and clipone probe of the VOM to each element terminal. If the element isfunctioning properly, the meter will read between 40 and 125 ohms; ifthe meter reads extremely high, the element is faulty and should bereplaced.
To test a range element without using a VOM, remove aworking element from its terminal block and connect it to themalfunctioning element terminal. Don't let the test element overlap theedges of the element well; keep the element inside the well, even if itdoesn't fit perfectly. Turn on the power to the range. If the workingelement heats, the suspected element is bad and should be replaced. Ifthe working element doesn't heat, the terminal block wiring or theswitch that controls the element may be faulty. Call a professionalservice person.
Step 5:Replace a burned-out range element with a new one made specifically forthe range. Take the old element to the appliance-parts store; ifpossible, take the make and model information, too. This data willprobably be on a metal tag attached to the back service panel of therange. To install the new element, connect it the same way the old onewas connected.
Replacing Oven and Broiler Heating Elements
Electric oven and broiler elements are often even easier to test and replace than range elements. Here's how:
Step 1:If the oven element doesn't work, first check to see if the range isreceiving power. Don't overlook the fusing system inside the range.
Step 2: If the range is receiving power, set the timer on the range to the MANUAL position.
Step 3: If the element still doesn't heat, turn off the power to the range and test it with a VOM set to the RX1 scale.
Step 4:Remove the screws or plugs that connect the element to the power.Remove the retaining shield, which is usually held by two screws, andremove the element from the brackets that hold it in the oven. Theelement is usually held in these brackets by screws.
To remove an oven or broiler heating element, remove the screws or pull
the plugs that connect it. Remove a retaining shield and lift out the element.
Step 5:Clip the probes of the VOM to each element terminal. If the element isin working order, the meter will read from 15 to 30 ohms. If the meterreads higher than 30 ohms, the element is faulty and should bereplaced. If the element tests all right but doesn't work, the problemmay be at the terminals. Make sure the terminals are clean and tight atthe element connections.
Oven and broiler elements cannot betested without a VOM. If you don't have a VOM, take the element to aprofessional service person for testing. The problem is usually amalfunctioning element; however, you aren't risking much by replacingthe element without a professional test.
Step 6:Take the burned out element with you to the appliance-parts store tomake sure you get the right replacement part; if possible, take themake and model information, too.
To install the new element,place it in the same position as the old one. Connect it the same waythe old one was connected, using the same screws to hold it in place.Just about all the other components of an electric range or oven(including its door gasket, oven controls, and timer) are virtually thesame as the components used on gas ranges.
Most problems withgas and electric ovens or ranges are easier to fix than you think. Thekey is knowing how the various parts work and when to replace them.
Have a look at these websites to find parts and details :
http://www.appliancepartspros.com/appliance_range_oven.aspx
http://www.gallawa.com/microtech/dataselect.html
Posted on Mar 21, 2009
  • 250 Answers
SOURCE: Stoves 900GDO Bottom oven door seal
The handbook tells you how to take the door off. If you can do this, do so and then clean/spray all the door hinge mechanisms with WD40. Remove the surplus with kitchen towel and replace the door. Operate the door a number of times to see if this has cleared the problem. (Over time the hinges seize up and the WD 40 normally eases this situation).
(Don't be confused with the air flow coming out of the oven from the cooling fan as this also runs along the top edge of the door).
Posted on Apr 04, 2009
barkencoa
  • 3463 Answers
SOURCE: oven door not closing properly
If it is a drop down door with hinges on the bootom of the oven door, then it is likely to be weak door hinge springs, the usual solution is to replace both hinges.
If it is a swing open door, then the problem is related to a worn or broken door catch, or worn striker pin.
Posted on Apr 13, 2010
ginko
  • 19396 Answers
SOURCE: The oven door has a
Hi.
That usually means that the door is not well installed, and that one hinge is higher than the other or both hinges are not well inside the frame.
The problem is fixed pulling out and reinstalled the hinges. Check the hinges. Several Westinghouse oven models have a lock on the hinges. To pull out the door, open it and pull it toward you. Pull it out a bit, then when you are sure that is released press it down into the frame. Depending on the size of the oven get help from someone else to support the door.
See this link. Click on blue links in page to see pictures.
Regards.
Ginko
Posted on Apr 18, 2011
Why will my Fisher & paykel Aerotech OB76 oven not heat up when using the aero funtions
Some ovens require the door to be closed upon accepting the setting desired, AND then for the door to be closed. Reading your oven's manual may inform you of what to do. I am writing from experience, not making this up.
A
Dec 03, 2016 | Fisher Ovens
Kebs208dss11 model double oven. When upper oven is on with door closed, steam can be seen escaping from top of door. Door is closed all the way. Even when putting pressure on door to make sure it is...
The first thing I'd suspect is a poorly fitting door seal / gasket. This will permit the heat inside the oven to escape. Check to be sure the the one installed is defective (cut, split, frayed, dislodged, etc.) Replacement parts:
http://www.appliancepartspros.com/whirlpool-gasket-door-w10074200-ap3892420.html
Make sure this is the part you need before ordering.
Feb 25, 2014 | KitchenAid Ovens
The door will not close completely
Hi someone lifted up on the door this ishowyou remove oven doors open the door about 1/3 then push down towards the floor it should go back into place, if not you may have to remove it clean the hinges then re-install it , I don't think anyone could have bent the hinges cause that would b very hard to do, but i have seen it done before , get back to me Frank
Dec 04, 2011 | Thermador Professional Series PO301...
Oven will no longer heat
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 03, 2011 | Fisher and Paykel AeroTech OS302 Electric...
I have an ILVE oven and the door is not closing properly so heat is escaping from top left and right sides, discolouring the white frame polyurethane. How do I adjust the door so that the bottom comes out...
Hi david23413, it's the ILVE service team here. Please contact our Service Manager, Peter Dale, on 02 8569 4672 to discuss your issue further.
May 22, 2011 | Ovens
Fisher and paykel oven door wont close, there is a gap at the top of the door. The seal seems to be intact. The door feels loose to the touch.
you need to either replace - or get the door hinges replaced, the spring in the hinges has weakened over time, if it is still in warranty, then they should replace them for free, if not, then take the model number to your local f&P dealer and buy new hinges. Remove the door and dismantle the door to gain access to the hinges, undo the 2 screws holding each hinge in place, clean the inside of the glas while apart, reassemble in reverse order.
May 17, 2011 | Fisher and Paykel OS302SS, Stainless Steel...
Need to get the door off - model number B7425b1600E
To remove door: Open oven door fully open. On the hinge there is a small metal tag that swivels up and fits over a small hook on the hinge. Do this on both sides of hinge, then gently close oven door whilst lifting upwards- door will lift off. Reverse procedure to refit.
Mar 10, 2010 | Fisher and Paykel Ovens
Oven door fails to close properly. Heat escapes when cooking. Seals appear to be ok. Please assist if free, as offered.
Probably mal-adjusted hinges. Open the door fully and there USUALLY are small holes in the hinges to insert a nail into to hold the hinges open while working on the door.
Nov 25, 2009 | Fisher Ovens
Ovens Logo
Top Fisher and Paykel Ovens Experts
Dan Webster
Dan Webster
Joseph Hoffmann
Are you a Fisher and Paykel Oven Expert? Answer questions, earn points and help others
