Question about LG Washing Machines
Lg f10a5qd door - LG Washing Machines
Lg washer wm2455hw door won't lock. DE code flashes.
LG Washer Door or Lid Won't Lock - Model WM2455HW ...
www.repairclinic.com/...Washing-Machine/...-/LG-Washer-door-or-lid-...
LG washer door or lid won't lock? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
Nov 15, 2015 | LG Washing Machines
Lg in door ice maker, water won't fill in ice tray
I had that problem and water was also leaking. I tossed the ice and kept the door open for about 20 minutes when the door open alarm started to go off. It's working again. The error code on the door was 1f
Feb 01, 2013 | LG LFX25960ST Stainless Steel French Door...
LG Intellowasher 7kg WD-14125RD shows DE error
DE is for a door lock error and you will need to replace the lock. Here is the part to order.
Dec 07, 2012 | LG WD-12126RD Front Load Washer / Dryer
Lg tromm washer leaking from front door
We have the same problem with our LG washer. Don't think the door can be adjusted but I'm not for sure. I think the gasket is wore out but haven't checked on fixing the problem yet because it barely leaks.
Sep 29, 2012 | LG WM-2277HW Front Load Washer
Replace door latch on lg refrigerator
Put the LG in the trash. I did after pay 150.00 three time to fix the latches that kept breaking. LG stands for Loads of Garbage.
May 12, 2012 | LG LFC23760SW Side by Side Bottom Freezer...
Repair door springs - LG dishwasher - LD-2040WH.
my lg door keeps on falling done something wrong with door springs ; how do i repair it.
Nov 28, 2009 | LG Dishwashers
Broken Optibin door on LG refrigerator
I got a new bin from repairclinic.com, but the little nubs that hold the bin onto the door (in the thin plastic lining of the door itself) are snapping off. Sigh.
Jun 20, 2009 | LG LRFD25850 French Door Refrigerator
Need wireing schamatic for 1988 ford ranger (audio)
LG/Y --Power
Y/BK --Ignition
BK -- Ground
LB/R -- Illumination (+)
Or/Bk -- Illumination (-)
DG/O -- Right door speaker (-)
W/LG -- Right Door Speaker (+)
O/LG -- Left Door Speaker (-)
LB/W -- Left Door Speaker (+)
If it has rear speakers:
O/R -- Right Rear Speaker (+)
Bk/W -- Right Rear Speaker (-)
PK/LG -- Left Rear Speaker (+)
T/Y -- Left Rear Speaker (-)
Hope this helps
Feb 24, 2009 | 1988 Ford Ranger
LG front door washing machine gasket, how to replace it ?
how do i replace the door seal on my intello LG washer the old one is torn
Jan 05, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
27 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
