Question about Logitech Cordless Mouse
Document flip and taskbar
Hi, my document flip no longer works with vista, all it does is bring up a list of windows open, no longer the cool visual feature of each window, also when I hover my mouse over the open windows in the taskbar it no longer shows a little picture of the window, it just says the name of it, just like xp used to
brendan
Hey bro, ive had the exact same problem. it was working, but then stopped. i fixed mine by checking my colour settings.. it was on 16bit (medium) rather than 32bit.
to fix - desktop - right click - properties - display settings - dropdown box that says colours. i instantly got my doc flip back properly, and all the windows and bars etc are all looking correct again, transparency etc works again.
hope this helps :)
Posted on May 11, 2009
My screen does not flip 180 degrees when i turn the screen around
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Jan 28, 2013 | Panasonic Toughbook 19 Rugged Notebook -...
Tip
Shortcuts tricks for Windows Vista(Keyboard shortcuts)
Following are some of keyboard shortcut tricks for Windows Vista and also for Windows XP:
  • Window key+B: Sets focus to first icon in the notification area. You can use arrow keys to move among the icons in the notification area or press Tab to move around on the task bar.
  • Window key+D: Show Desktop (without the Sidebar).
  • Window key+E: Windows Explorer (opens to Computer).
  • Window key+F: Find Files or Folders (aka Search).
  • Window key+M Minimize All windows (Sidebar not included).
  • Window key+Shift+M: Undo Minimize All Windows.
  • Window key+R: Open the Run dialog box.
  • Window key+Tab: 3-D Flip (flips you through your applications but with a cool graphic instead of the standard Alt+Tab). Requires the use of the Aero user interface.
  • Window key+Pause/Break: System Properties.
  • Window key+F1: Windows Help.
  • Window key+L: Locks workstation. If the user account has a password, it must be reentered to unlock the system again.
  • Window key+U: Ease of Access Settings.
  • Window key+ Spacebar: This shows the Sidebar (the Sidebar must be open, but minimized).
  • Ctrl+Window key+Tab: Brings up Flip-3D, but it will stay on the desktop so you can scroll up, down, left and right.
  • Window key+T: Allows you to tab between application buttons on the task bar.
  • Ctrl+Shift+Esc: Opens Task Manager more faster than alt+ctrl+del.
  • Alt+Tab: Windows Flip. Allows you to choose an open application to switch to by repeatedly pressing the Tab key.
  • Window key+5: opens the snipping tool.
Some User Logging Shortcuts:
  • Window key (and then) three right arrows and Enter To Shut down
  • Window key (and then) three right arrows and U To Shut down
  • Window key (and then) three right arrows and R To Restart
  • Window key (and then) three right arrows and W To Switch Users
  • Window key (and then) one right arrow and Enter To Sleep
on Jan 16, 2010 | Microsoft Windows Vista Ultimate Edition
I used to get approximately 1 inch tall minature window pics of what was open when I mouse over an icon on my taskbar but I no longer see that. Instead I get a list of the open windows which is what I...
Click on Start menu.
Type the following text into the Start Search box: Aero
Click on a search result listing under Control Panel group that named as the following:
Find and fix problems with transparency and other visual effects
An "Aero - Troubleshoot computer problems" wizard dialog will appear. Click on Next button.
The troubleshooting wizard will try to detect any problem by running a series of checks against various components required to make Aero works and running, such as video memory, Desktop Windows Manager (DWM) service, color depth, theme, power settings and etc. At the end of the analysis, the wizard will attempt to fix the issues related to Aero service and restart the Aero feature.
Mar 23, 2011 | Computers & Internet
Missing task bar - running vista
Sounds like explorer.exe is not running:
1. Hit Ctrl + Shift + Esc at same time.
2. Windows Task Manager should open.
3. Hit File on top menu.
4. Select New Task.
5. Type explorer.exe and hit OK
That should bring your task bar back.
Jun 02, 2010 | Microsoft Windows Vista Home Premium...
With my Vista Home Basic, How do I move the taskbar?
Hi goldenhead36
Right click on the taskbar and untick 'Lock Taskbar'. You should be able to drag and drop now.
Does this help?
May 09, 2010 | Microsoft Windows Vista Home Basic for PC
When I hit the bottom left hand MS Icon to bring up list of programs to launch the list on the right hand black column list my main file areas such as 'Pictures' and used to list 'Documents' but for some...
Click the start menu button so it opens up the menu where the documents used to be, then right click on the start menu. Click properties a pop up should open up saying taskbar and start menu properties. Click the start menu tab, if your not already on it. Then click the customize button. It should open up another pop up saying customize start menu. Then click use default settings button near the bottom of the pop up or you can click the check box under the documents that says display as a link. After doing all that click ok on the pop up it should close. Then click apply and ok on the other pop up it should then close that. Then click the start button and it should show your documents. If you need more help comment and ill try again. If i helped please leave me a rating.
Jan 14, 2010 | Microsoft Windows Vista Ultimate Edition
How do you clear que on a c6300 photosmart
Windows XP Operating System
Restart the Print Spooler device
  1. Open Administrative Tools.
  2. On the Windows taskbar, click Start , and then click Control Panel .
  3. Click Performance and Maintenance . NOTE: This step is not necessary in XP Classic View.
  4. Click Administrative Tools .
  5. Double-click Services .
  6. Click Print Spooler .
  7. Click Stop to stop the Print Spooler.
  8. Click Start to restart the Print Spooler.
  9. Click OK .
  10. Restart the computer.
  11. Try the print job again.
Manually clear the print queue
  1. Return to the Printers and Faxes folder that you opened in the previous steps.
  2. Right-click the name of the product, and then click Open .
  3. Click Printer , and then click Cancel All Documents .
  4. Click Yes to confirm the action.
  5. If documents remain in the print queue, restart the computer.
  6. Try printing again.
Windows Vista Operating System
  1. Return to the Printers folder that you opened earlier in this document.
If the issue continues, proceed to the next step. Restart the Print Spooler device
  1. On the Windows taskbar, click the Windows icon (c01319360.gif ), click Control Panel , and then click Administrative Tools .
  2. Double-click Services .
  3. On the User Account Control window, click Continue .
  4. Click Print Spooler .
  5. Click Stop to stop the Print Spooler.
  6. Click Start to restart the Print Spooler.
  7. Click OK .
  8. Restart the computer.
  9. Try the print job again.
Oct 03, 2009 | HP Office Equipment & Supplies
My vista used to do document flip with the cool animation of visibly cycling through all the open pages on my desk top, now for some reason it has become just a list, i've recently installed regtool, and...
Ok I had the same problem and I found the fix, well at least for me. Right click on your desktop and click on personalize, then window color and appearance. Now make sure that you are set to use "windows vista aero" not windows vista basic. Once I did that it fixed the document flip. Hope this helps
Jul 07, 2009 | Logitech Cordless Mouse
When I bring up documents a drop down window
If you are trying to open a document sent to you it might be asking to download a program compatible with the file format
Apr 20, 2009 | Computers & Internet
No Taskbar
The taskbar is always running in Windows Vista. Unlike Windows XP, it can't be unlocked and hidden unless the 'auto-hide' feature is turned on. If 'auto-hide' is on, simply run your cursor along the bottom edge of the screen and the taskbar should pop-up.
To disable auto-hide, after moving your cursor to bring up the taskbar, right click the taskbar and click properties. Then under the Taskbar tab, uncheck auto-hide.
If auto-hide is off, it may indicate that explorer.exe is not running/has crashed. In order to restart explorer.exe you can either
1) Restart
2) Press CTRL+Shift+Escape, File -> New Task and then type in explorer.exe and run
Feb 01, 2009 | Microsoft Windows Vista Ultimate Edition
Logitech Cordless Mouse Logo
1,789 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
