I have a sinotec rc-601 t.v that has a usb slot on it , how can i connect my external hard drive to the usb to make it work
  • 37 Answers
SOURCE: restarting computer
what edition is it,pro,home,studio ,office.essentiel ect ect and model/order no let me know and we can see if we can help.In meantime try installing usb 2.0 drivers again
Posted on Dec 09, 2007
SOURCE: PS3 Does not register external hard drive
The E.H.D. might not be formated correctly. The Playstation 3 will not read any disc or hard disc if it is formatted under NTSC. It must be formatted under FAT or FAT32 ( can't remember exactly). You would need to format the E.H.D. with windows and check to see if you can format it for FAT32 if not then you need a formatting software (Max Drive or some other). Mine works great.
Good luck
Ken
Posted on Sep 30, 2008
  • 289 Answers
SOURCE: My laptop HP zd8000 doesn't recognize Seagate external hard drive
hi..the reason for your problem is your extenal
hard drive has been affected by viruses.The best
solution to this problem is scanning your hard drive.
once you scan it u will be free of viruses and your
laptop will be able to recognise your hard drive.
try it out..
thank u..
rate me..
Posted on Feb 10, 2009
  • 603 Answers
SOURCE: Can I Connect a USB external hard drive to my LG LCD TV
No TV I know of can do that.
Posted on Jan 07, 2010
SOURCE: verbatim usb 160 external hard drive.
That model doesn't have an external power supply port.
Posted on Feb 23, 2010
My usb touro external hard disk won't turn on/ be detected. its so new. its really frustrating
You need to be sure that it is plugged into a USB 2.0 slot. Sometimes USB 2.0 devices will not be detected in USB 1.0 or 1.1, or on low powered USB slots. The back of your computer is the most likely location for a USB 2.0 and is likely indicated.
Jul 05, 2011 | Hitachi Touro Desk 2 TB USB 20 External...
Seagate external hard disk is not getting detected in windows 7 previously it was detecting. i tried to change usb cable, tried on different system but nothing worked. i want to take backup of data also....
This is my suggestion for you to possibly recover the back up file in your external hard disk.
Remove the enclosure cover of the external hard disk. Detach the hard disk from the ide connection.
Change the jumper setting of the hard disk to slave. See the sticker in the hard disk to see how to set up the jumper to slave. Connect the hard disk to the ide cable inside your pc. If your computer is equipped with sata cable, just find some ide cable and connect it the the ide slot in your motherboard.
Restart your system and you will find your hard disk as drive (d:) in your system. If this was successful then problem can be cause by loose terminal solder in the usb/ide connector of the enclosure, or possible voltage drop of the power supply of the enclosure. USB driver issue or problem with the usb slot in your computer can also cause this issue.
Jan 26, 2011 | Seagate FreeAgent Go 320 GB USB 20 Hard...
I use hm121hi on usb external i want to know to connect the jumpers
Use external hard disk casing to connect it to USB slot of computer, you can get this hard disk casing in any local computer hardware store.
Jan 13, 2010 | Samsung Computers & Internet
Hard disk not detected sometimes
I can think of 3 possible causes to your problem:
1. Faulty cable - try replacing the cable by borrowing a working cable from a friend. If this solves the problem then you need to buy a new cable
2. Lack of power - some USB drives especially those for high capacity drives require extra power aside from that provided by USB. If you do not have a separate power leading to your drive, check if there is a separate power slot and run a cable from it to your outlet/USB slot. Just make sure that the voltage levels are correct.
3. USB Slot - some laptops' USB slots do not produce power enough to drive a hard disk. Other devices may work (e.g. keyboards, mouse) but not hard drives. Try to use another slot in your laptop. If this works, remember to use the same slot next time.
Hope this helps.
NOTE: Please rate our help to keep this free service online
Jan 08, 2010 | Western Digital External USB 2.0 80 GB...
External Hard disc isnot recognized by PC
Dear Sir,
Here is the Procedure for Connecting External Drives to Computer.Several brands of computer does not recognise external drives when connected to USB expansion slots,and Slots of front panel,So connect your Ext HDD to back side onboard Slots.Because there is a lack off USB power surge voltage to detect a large capacity exteral drives.Some time it is does not recognise by many computers,when USB power surge voltage is low.
I think it helps,
If you find any difficulty post a feed back we were happy to assist you
have a nice day.
Good luck
Sep 17, 2009 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Connecting an External Portable Hard Drive?
You are connecting it to a car DVD player, but how many types of music format is it capable of playing? It should be in the Manual, however it will be able to play mp3. *.flac, *.wmv, *.wav, *.cda. But how ere you going to power your external hard disk? If it has provision for use of 12V DC voltage, same as that of the car. After its powered, only then will it work, but the USB connector will provide the output into the DVD players USB slot(just like attaching a flas drive like pen drive which uses the USB slot for power too....sodeep
May 20, 2009 | JVC KD-AVX33 Car DVD Player
External USB Drives No Longer Detected
There are two possibilities:
The Mybook USB/ATA controller board is faulty.
In this case you can simply take apart the enclosure and mount the disk into a new enclosure. WD Mybooks are SATA, but double check the hard disk connector to ensure.
The hard disk inside is faulty.
In this case repair may be expensive. You need to locate a data recovery facility with a 'clean room' , the cost is usually more than $800.
If this happened after a power surge, then the problem is most likely a faulty controller board.
If instead you have dropped the hard disk it is possible an hard drive failure, in that case repair will be expensive.
A replacement enclosure will stfrom art about $20 on Ebay or Amazon, and must not necessarily be WD .
Check if your disk is Sata or PATA (IDE) before buying the enclosure.
Apr 22, 2009 | Western Digital 320GB MyBook External USB...
Xp can't find the drivers
It does not need any drivers it's Plug&Play you just need working USB slot. Try to connect it to another USB.
Apr 18, 2009 | Western Digital My Book Essential 320GB...
Maxtor and vista
Try some other USB device (memory-stick, printer, camera) in the USB slot in the Vista computer, just to "prove" that Vista will recognize _any_ USB device connected to that slot.
May 31, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Televison & Video Logo
Top Televison & Video Experts
