Vulcan freeloader 300. Third person always get a cold shower, why?
Because the two people b4 are showering too long .....thats what happens no matter how many litres yo have ...Solution: Become the first or Second Person
Posted on Dec 14, 2009
To hook up gas, to an Vulcan 260 freeloader
best left to a pro . gas leaks cuase explosions when we certainly don't want one
Jan 21, 2015 | Water Water Heaters
Vulcan freeloader 260 suddenly turns off after heating to temperature. Control unit was just replaced but still doing the same. I was told by another person it is the thermo couple but the fitter said
The thermocouple makes sense, if it does not send enough electricity to the control unit it will shut off. The thermocouple was probably moved when a new control unit was installed. Check to be sure the pilot flame touches the thermocouple, if not realign it else replace it.
Mar 25, 2014 | Water Heaters
My shower only stays hot for a minute and then goes cold even though the hot water works everywhere else. I have a hot and cold tap and a third one to direct to shower or tub.
I would take a look at the stem replacement task. Maybe something is clogging the hot water flow, perhaps a damaged washer or debris
Jan 14, 2013 | Moen Home
Hi I am renting a house with a Vulcan freeloader 260 outside boiler. We keep finding that we do not have any hot water, we turned the thermostat dial up and this seamed to fix the problem for a few...
The unit may be undersized for the amount of water you are drawing off. The freeloader is a storage system. As you draw water off, it fills with cold water. On a 260 its not unusual to use at least half that on a long shower, or if someone else ahs the hot tap going. It takes around 30 minutes to reheat the misplaced water up again...
Jul 16, 2011 | Heating & Cooling
I have a vulcan freeloader 260 gas, how do i make sure it has water in the tank
The old freeloader is feed by cold at the bottom and the hot feed comes out the top. Basically if you are getting hot water out the hot tap (or any water out the hot tap) it has water in it. If you have any concerns post a new fault, I will keep a look out for it. These are great heaters, well worth looking after.
Sep 20, 2010 | Heating & Cooling
Running out of hot water with Vulcan Freeloader 300
hi i need help with mi Vulcan 300 hot water main gas pressure...
our kitchen tap got broken and we turn off our main water pressure in front off our house and now our hot water gas not working ....please help
thank you ...
Sep 24, 2009 | Water Heaters
Freeloader 300 pilot light goes out when I turn
make sure that the thermocouple is staying in the flame youmay want to replace it unless it is staing lit on its own until knob is turned if so gas valve bad
May 12, 2009 | Emerson Fans 300 Heating & Cooling...
Vulcan 300 Freeloader Gas Water Heater
I assume it has a pilot. Try blowing out the pilot area with compressed air or CO2. Then relight the pilot.
Dust can cover the pilot combustion air inlet and cause it to pull away from the safety generator or thermocouple. Its called an oxygen depletion arrangement on some space heaters. I assume your Domestic Water Heater has this setup as well. Even if not the thermocouple is not getting all then heat from the flame. If this doesn't work get back to me here. We'll try 1 more thing.
If this helps you please grade me accordingly. GOOD LUCK
Mar 04, 2009 | Emerson Fans 300 Heating & Cooling...
Water too hot on a Vulcon Freeloader Super 10
Remove the cover and there should be a temp setting
Jan 31, 2009 | Water Heaters
Heating & Cooling Logo
483 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
