Question about Asko 24 in. D3530 Stainless Steel Free-standing Dishwasher
Water inlet fault - Asko 24 in. D3530 Stainless Steel Free-standing Dishwasher
  • 126 Answers
Does it fill water at all? If not, the water valve is defective. If it fills, but then stops, it may be possible to program it to fill on time, instead of volume.
Posted on Oct 15, 2013
My ultima1000, wm 71 says error 10 sometimes and error 11 mid way thru a cycle. The pipes are fine and water is on what could be the problem?
E10 No cold fill detected - washing machine does not fill
  • Check mains water pressure
  • Check inlet hoses for kinks
  • Check inlet filter
  • Check water inlet valve
  • Pressure switch fault
  • Wiring fault
E11 Not hot fill detected - washing machine does not fill
  • Wiring fault
Apr 11, 2016 | Washing Machines
Fault 49 pops up on the screen
If your washer is a Fisher Paykel Top-Load Washer Error Codes = 49 I found this online by typing "Washing Machine Fault 49" into a google search engine...
Error Fault Condition - Water Inlet Valve Fault.
Repair or Check - Unplug the washer from power. Reconnect any non secure wires on the water inlet valve. Replace the wire harness if it is found to be damaged. If the wiring is okay then measure the resistance of the water inlet valves using an ohm meter. If the resistance of each water inlet valve solenoid is not 60 to 62 ohms then replace the complete water inlet valve assembly.
Parts for Replacement - Water Inlet Valve Assembly or Wire Harness.
Mar 09, 2016 | Washing Machines
How can I correct a recurrent F6 error?
you may have got a water inlet valve that is faulty, return and exchange.
press the helpful button
Feb 04, 2016 | Whirlpool Dishwashers
WHIRLPOOL DISHWASER MOD ADG8100 fault f6 is on what is that
There is a problem with intake water.
Could be:
- water tap closed
- water inlet hose blocked
- faulty water inlet valve
- faulty flow meter
Opening the water tap within the first 30sec. of the program cycle rasets the failure F6. After another 30sec. water inlet valve will close due to safety reasons.
Dado
Jan 10, 2015 | Whirlpool Washing Machines
No fault code washer will not fill
Hi
If the washer won't fill you'll need to check for the water inlet hose, the water inlet valve and the pressure/water level switch assembly. Inspect the inlet hose coming to the washer for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the pressure/water level switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Whirlpool WTW6400SW Cabrio Washer
Showing F01 error code on readout? what does that mean?
Hi.
It depends on the model. On Whirlpool built machines F01 is EEPROM error, pump drive error, or main relays error.
With Hotpoint F01 means defective triac or defective motor.
Aug 18, 2011 | Washing Machines
E10 PROPLEM AEG
Your Machine manual is HERE
E10 is an inlet fault.
Check the water valve is turned on. If you are only getting a dribble of water in, then clean the inline filter at the hose inlet.
If no sound of inlet water - replace inlet valve (available as a spare from online stores)
Sep 30, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Dishwasher adp 4601 when switched on the pump activates.and after 2 mins start lamp bliks and pump goes off
The number of flashes indicates the fault. Reset machine by holding down the start button for 3 secs, then start a new cycle. If fault reoccurs, the number of flashes indicates fault eg 3 flashes, stop, 3 flashes stop, indicates F3 fault.
Faults listed below- advice on repair depends on which fault your machine is indicating, but may give you an idea of what to look for
1flash=NTC (temperature sensor) break- NTC outside normal range.
2flash=water leakage-float switch in base activated.
3flash=heating fault(check element.NTC,control board).
4flash=drain error-blockage in pump or drain system,or faulty water indicator switch.
6flash=water inlet fault-check inlet valve, check inlet hose not kinked
7flash=flow meter failure (flow meter measures water intake volume-large plastic weir located on left hand side of machine-reomve side panel to access)
These a most common faults, but further advice on repair requires counting flashes when fault occurs.
Aug 09, 2009 | Whirlpool Dishwashers
Dishwasher has fault code ie
IE fault indicates water fill problem. Check inlet hose not kinked or blocked. Check no water in base activated flood switch. Otherwise, problem will be a faulty inlet valve(can test with Ohm meter), faulty flow meter (measures water intake- cannot test with meter), or faulty control board. Flow meter located on Left hand side of machine- accessed by removing side panel. It has a sensor with 3 wires(red,white,black) which goes up to control board. If inlet valve tests OK (about 4K ohms), and there is no water in base, I would try replacing flow meter assy (comes with housing and sensor complete)
Aug 08, 2009 | LG Dishwashers
Asko w640 has a water inlet fault
Check the drain line to make sure the water does not siphon out as it enters the machine.
Mar 10, 2009 | Asko W640
Asko 24 in. D3530 Stainless Steel Free-standing Dishwasher Logo
134 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
