Question about C3 RS6652W (NEW with 1 LCD Transmitters) 2way 3Channel Vehic
Drains battery what would cause car battery to drain have a auto page alarm and just installed an after market Dual stereo in 1996 Honda Accord. I bought car used
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 145 Answers
My aftermarket alarm used to drain my battery. fixed it by removing alarm system.
Posted on Oct 24, 2013
97 honda accord the speedometer bouncing all over and causing the transmission to shift roughly do i need a vechicle speed sensor or a speedometer speed sensor
This car is known for bad Instrument Clusters. Not to say that it is out of the question that your speed sensor could be bad... But 75% of the time it is the Cluster in the 1996-1997 Accord.. Car Part com Used Auto Parts Market
Sep 11, 2014 | 1997 Honda Accord
1996 honda accord lx 4cly auto how do you drain transmission fluid from this car
Get a service manual from Autozone or a similar store. They usually run about $25. If you pull it out to check it, you might as well change it out. Most tranny filters are internal to a metal outer piece and there's no way to "check" them. Be sure to use fresh transmission fluid and make sure it's the right TYPE. The store can help you out with this as well.
Mar 13, 2014 | 1998 Honda Accord
Battery on 98 Ford Expedition doesn't hold charge
First thing I would do is have someone qualified disconnect the alarm and stereo and start over.
Chances are you have circuits cross-connected and something is draining the battery.
Jan 14, 2013 | 1998 Ford Expedition
Can a new car radio kill the battery?
Yes and that was due to bad installation. I have had 3 car stereos installed on my 98 RAV4 through Best Buy and never had battery problems. I even had 2 amps installed as well but the installers had to make me buy this 200-dollar thing that would not drain the battery.
If you are getting a drain through the radio's power supply it could eventually drain down the battery if it was improperly installed, I would pull the fuse for the radio and see if the drain continues, if the drain does not stop there is another short somewhere. To learn more :
http://www.xcardiag.com/wholesale/automotive-battery-analyser-vat-560-tool-536.html
May 16, 2012 | Cars & Trucks
After putting inn a new starter, new battery, and battery fuse my car starts sometimes. I can start it and go somewhere and then go to leave and it won't start. A jump does start it.
I would have the think its the alternator. If a jump starts the car, maybe the alternator isnt charging the battery properly. If you can take it off, Auto Zone, and places like that will test for free. Also, start your car and put a volt meter on you battery. You should be makin 14ish volts (14.4). If its making less (like 12-13) id def say its the alternator. (make sure everything is off in your car when you take the volt reading. Heater,lights,stereo,headlights.... Everything)
Jan 20, 2011 | 1995 Honda Accord
Battery keeps going dead. Installed new Honda battery, checked charging rate while running, 14.5 volts and battery static voltage is 12.65. After sitting for one day, car won't start, lights but no sound,...
diode pack on the alternator is most likely suspect ,alternator will charge but drains to earth when not running ,pull the big terminal lead off and see if it goes flat overnight
Jan 13, 2011 | 1996 Honda Accord
I have a blue flashing light that flashes when I set alarm and car is off . Is this normal and will it drain my battery ? ( 2002 Nissan Pathfinder )
the flashing blue light is to let potential thieves know that there is an alarm in the car. it uses minimal power and should not drain your battery.
Dec 02, 2010 | Excalibur. K9-MUNDIAL-SS Entry Level Auto...
I believe that the alarm system in the car is draining the battery also causing the car not to start.....I want to disconnect the alarm system or disarm it but cannot locate the valet switch...my friend...
This sounds like a factory alarm, so it is unlikely that it is draining the battery. Much more common is alternator diodes. diagnosis is pretty easy for a shop, consider using one for this issue.
Sep 09, 2010 | 1994 Honda Accord
Battery is being drained by something, its new
2 things, not enought cold cranking amps, or while you where trying to start the car the brushs inside the starter caused a ark on the armature causing the starter not to be working at 100% option 1 have a drain test done or 2 replace the starter the drain test will show how much amps its taking to spin the starter if its pulling a high amount of amps/votage to spin the start then replace starter
Mar 04, 2010 | 2002 Honda Accord
Headlights causing battery drain while driving?
Hi:
Though your car seems fine without using the headlights, you have a charging problem, and need to get a couple things checked out. First make sure your battery connections are clean and tight. Your alternator belt should also be checked to make sure it is serviceable and properly tightened too. Your alternator should be checked under load, and lastly, your battery too. Most auto parts stores, such as auto zone,will check your parts for free,so you should only be spending money on what is broken!
Feb 17, 2010 | 1990 Honda Accord
C3 RS6652W (NEW with 1 LCD Transmitters) 2way 3Channel Vehic Logo
139 people viewed this question
Top Autopage Vehicle Parts & Accessories Experts
John
John
Charles Osborn
Are you an Autopage Vehicle Part and Accessory Expert? Answer questions, earn points and help others
