Question about Samsung Refrigerators
How to operate the referigator GR45-2FD? - Samsung Refrigerators
I have a question how normal for the temperature for the freezer and referigator
Typical for a freezer is zero degrees farenheit and for the fridge is at between thirtee three and fourty, thirty eight would be great
Sep 06, 2015 | Refrigerators
How do I install insulation around my referigator door
You have a bunch of screws all around the gasket, pull the old gasket back to see them. Hard job even for a service tech, good luck!
Mar 15, 2013 | Hotpoint HSS25GFP Side by Side...
We have ck3bxa048021aaaa coil .is feron add r22 or r41a
the evapator coil has nothing to do with what kind of referigent the unit uses. R-22 is still in use in most home units. R410a puron has only been in use for 10 years or so. if the unit is older than that it's most likely a r-22 unit. Either way it requires a federal license to purchase. you do not want to mix referigents it will cause problems
Aug 06, 2011 | Heating & Cooling
Airconditiondoesnotwork
1. check AC fuse look in manual as to whereabouts
2. make sure fuse is opearable
3. turn on unit hi setting does blower work if not check fuse and replace
4. physical look for clutch to operate intermittenly if not replace ( engine compartment)
5. top of unit with R134a referigant
6. check for leaks and by using soapy water on all fittings repair as needed
Good luck
Jun 17, 2011 | 2002 Kia Sedona
My may tag referigator not colling...frezer seems to be working fine
look in back of freezer for ice / if so you need my help not a un comon problem as the defrost system has failed . mm
Sep 02, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Where is the valve to charge the air conditioning referigant on a 1999 Oldsmobile Alero
LOOK DOWN THE LOWER BACK ENGINE TOWARD FIREWALL FOLLOW EVAPORATOR LINE YOU WILL SEE A LINE WITH BLUE CAP.THATS YOUR LOW PRESSURE PORT WHERE YOU RECHARGE YOUR AIR CONDITIONER.
Jul 12, 2010 | 1999 Oldsmobile Alero
No power
Fridge is 60% nit working.The freezer is -20%.Circuteboard was replaced and defrost controler.Referigator does not work.Service technition has tried three times to repair.Referigator is 14months old.
Aug 05, 2009 | LG LFC23760ST Side by Side Bottom Freezer...
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
