Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Same as other problem.
My TV does the same as the other. When I try to power on it makes clicking noise and then it clicks again followed by five blinks of the red light. Do you have any idea what parts could be bad? How much on estimate would it cost to fix? Thanks
    Problem Solver:
  • 10 Answers
Check in the deflection area for example vertical output transistor, fly back, Yoke,
If every thing ok in the deflection area, the convergence Ics could be bad.
Good luck.
Posted on Dec 29, 2007
SOURCE:
My tv goes click click click and keeps clicking when i turn it on. I have no picture or sound
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
May 03, 2011 | Samsung LN46A650 46 in. LCD HDTV
My kdl52xbr2 blinks to a black screen constantly every 5-10 seconds or so. Screen goes black for about one sec, then back to the picture. It continually does this throughout the time we're watching tv. ...
May 01, 2011 | Sony BRAVIA KDL52XBR2 Television
TV does not have a picture, however when the power button is tuned off and then on the IR light blinks and there is a LOUD clicking noise coming from the speakers. The remote control seems to work fine,...
May 01, 2011 | Akai LCT2715 27 in. LCD Television
Have vizio 37 in lcd , heard poping noise. now screen is black but sound works
Apr 19, 2011 | Vizio VX37L Television
My lg 37 inch lcd works fine for five minutes then a big popping sound happens , i loose picture and sound but power remains, after this it will either keep popping or picture and sound will return for...
Apr 17, 2011 | LG 37LC7D 37 in. LCD HDTV
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
When powered on the tv makes a constant clicking sound
THe clicking noise is the relay on the PSB that allows AC to be sent to the psb. It won't hold in due to some fault either in a resetable link or some other safety component. To check this unplug the cord from the mains for an hour, then try again. You should hear the relay click once and then the TV will power on for a short period before powering off again. The solution is to replace the component, other than that replace the psb. I can't get a manual to prove this so I am just making an intelligent guess until I can prove it.
Apr 19, 2010 | LG 42LC2D 42 in. LCD HDTV
Turns on makes clicking noise and shuts off
It has an overload and needs to be repaired.
Apr 14, 2010 | RCA 32V420T 32" TV
Will not power on, makes a click noise only
if you dont know take your tv to w/shop, let the tech test the output of that power supply.
he has to test the following, switch contacts,power transistor,diodes, and resistors less than 100 ohms.
your set will be okay again.
if you want it to be move perfect test capacitors as well, and change all electrolitic, on the power supply. this will make your tv stay longger and perfect.
Apr 29, 2009 | Sony Televison & Video
RCA tv Making a clicking noise
This is a power supply problem it may be as simple as a blown fuse or as complex as a malfunctioning IHVT (Integrated High Voltage Transformer). Is it worth fixing, only you can answer that I would estimate the cost from $100.00 - $500.00 at least.
Sep 03, 2007 | RCA D61W136D 61 in. TV/DVD Combo
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
49 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
