Question about Symantec Norton AntiVirus 2004 - (Open Box) for PC
Error creating dec3.cfg
Hiii I am tring to install the symantic AV but it gives error of error creating dec3.cfg
  • saurabhjain_ Aug 29, 2008
    hi......................... i got an error "dec3.cfg" when i installing symantec antivirus in my pc
    President:
  • 2,961 Answers
You need to check in add/remove programmes and make sure all previous elements of norton are uninstalled first, then run a registry clean up, it should then install, but be aware a 2004 version may not be compatable with your current operating system version as it's over 3 years old and outdated. For a free reg cleaner (Ccleaner) see below http://filehippo.com/download_ccleaner/
Posted on Sep 24, 2007
SOURCE:
Have a pc with no internet access my son was given a copy of rail simulator and when i went to install the game it asked for installation code on back of the manual which is not with the game where can i...
You will need to go to the link below, create an account with EA games.
Then, once created, send EA an email asking for a replacement product key.
https://customersupport.ea.com/loginapp/login.do?skin=default&locale=en_US&curl=https://help.eastore.com/cgi-bin/eastore.cfg/php/enduser/home.php&surl=https://help.eastore.com/cgi-bin/eastore.cfg/php/enduser/cci/ecp_redirect.php?ext_vars=cF9zaWQ9NFEqVG9IN2smcF9hY2Nlc3NpYmlsaXR5PTAmcF9yZWRpcmVjdD0mcF9sdmE9JnBfc3A9JnBfbGk9JnBfbmV4dF9wYWdlPWFzay5waHA*
Aug 17, 2010 | Electronic Arts Rail Simulator for...
Error loading 0004f220429c.cfg
This means the phone cannot find its <mac>.cfg file on the boot server, and does not have one loaded in its own flash memory.
You will need to configure a boot server to host the SIP software, BootROM, and all the config files (these are included in with the SIP software).
You can download these from Polycom's product support page:
http://www.polycom.com/support/voice/soundpoint_ip/soundpoint_ip330_320.html
Aug 18, 2009 | Polycom SoundPoint 330 IP Phone
The program says "Symantic proxy servic has encountered an error and needs to close." This happens almost every day and then my browser doesn't work. I also have problems loading some games due to the...
uninstall all symantic software on your computer. install avast free home edition, or AVG Free anti virus. Norton anti virus software is the worst thing you can have on your computer!
Aug 05, 2009 | Computers & Internet
Symantic anti virus is not getting instal
I'm not sure what is causing this issue but I can tell you that Symantic AV will do more harm than good. If you have window vista & have any web sense at all you don't need it. AV software is the biggest conspiracy in computers. They only cause problems & never fix them.
Jul 03, 2009 | Microsoft Windows XP Professional for PC
I TRY TO INSTALL AVG FREE 8.5 ANTIVIRUS AND GET AN ERROR MESSAGE Local machine: installation failed Installation: Error: Action failed for file ldrlog.cfg: creating file.... @AvgErrorCode_0xc04e'' How can...
Make sure you are logged into the system as an Administrator, otherwise the install will fail. It is trying to create a file in a location where the currently logged in user does not have Create or Write permissions.
Mar 27, 2009 | Internet Avg AVG Security V8.0 WIN - 2...
Counter-strike 1.6
see if your mouse has left hand properties
control panel set up mouse OR
If you cannot switch your weapon to the right-hand, please go to your advanced video options and change the renderer to either OpenGL or Direct3D. The software renderer does not support right-handed models.
You can select left or right-handed models by typing the following command into the Console:
  • To use your left-hand: cl_righthand 0
  • To use your right-hand: cl_righthand 1
You may wish to create a userconfig.cfg file with the cl_righthand 0 command if you would like to keep the left-handed setting. Please follow these instructions to create a user.cfg file:
  1. Locate the subfolder in your game folder that holds the config.cfg file
    For example, you can find the config.cfg file for Counter-Strike at [Steam installation directory]\steamapps\[your Steam account name]\counter-strike\cstrike\config.cfg
  2. Create a new text file in that directory called userconfig.cfg
  3. Open the file with Notepad and enter cl_righthand 1 (to use the right-handed model) or cl_righthand 0 (to use the left-handed model)
  4. Save the file
  5. Launch the game to test the user.cfg settings
Jan 21, 2009 | Sierra Online, Inc. Half-Life:...
Faulty DFL-700 image - missing FWCore.cfg
Possible problems:
1. IDE Flash device is damaged
2. IDE controller is damaged
2. Firmware is corrupt
Try and download the firmware, and install. You should then get a better idea if the IDE device or controller is bad if it won't install or see the device.
Download Link:
http://www.opendrivers.com/freedownload/232591/d-link-dfl-700-vpn-firewall-firmware-1.33su-download.html
May 05, 2008 | D-Link NetDefend DFL-700 Firewall
Backup drive
try to fix it by using startup disk 98,and run fdisk,dellete the partition,and create a new parition,from there you will know if your hardisk has a problem.
Mar 10, 2008 | Computers & Internet
Open Questions:
Symantec Norton AntiVirus 2004 - (Open Box) for PC Logo
175 people viewed this question
Top Symantec Computers & Internet Experts
Peter Dragonetti
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
