Question about Gateway MX6447 Notebook
Free disk space on Drive C
I have a laptop Dell Inspiron 1525 with Windows Vista. The free space available on drive C was 98.4 GB, after doing disk cleanup, scan hard drive and defragment; the free space size is reading 97.7 GB. Whereas I was thinking that this will increase. Can you please enlighten me on this?
    President:
  • 2,004 Answers
The swept files are stored up in folders you might not see.
Run disk clean up and you will have more spaces wherein all temporary files will be deleted.
Cheers.
Rate this please
Posted on Apr 23, 2009
My computer won't turn off properly
THE SOLUTION TO YOUR PROBLEM IS, WINDOWS FILES AND HARD DRIVE NEED TO WORK AS A UNIT, FOLLOW THIS:
GO TO START ALL PROGRAMS ACCESSORIES FOLDER COMMAND PROMPT, RIGHT CLICK (IF VISTA OR WINDOWS 7) AND CHOOSE "RUN AS ADMINISTRATOR". IN COMMAND PROMPT BOX TYPE CHKDSK /R AND PRESS ENTER BUTTON ON KEYBOARD. THEN PRESS THE Y BUTTON FOR YES AND THEN TYPE EXIT TO CLOSE THE COMMAND PROMPT BOX HIT RESTART AND IT SHOULD DO CHECK DISK OF 5 STAGES, IF NOT THEN DO IT AGAIN EXCEPT TYPE IN CHKDSK /F DO THE 3 STAGE AND THEN DO THE /R 5 STAGE AFTER THE 3 STAGE IN /F THIS SHOULD FIX THE PROBLEM NEED A HASSLE FREE FILE CLEANUP UTILITY....?? TRY ATF CLEANER BY ATRIBUNE...NO INSTALL AND NO UNNECESSARY RESOURCE AND HARD DRIVE SPACE WASTED.
Nov 14, 2012 | Dell Inspiron 1525 Laptop
My dell inspiron 1525 laptop is running slow because it is saying the memory is nearly full when it isnt, how do i solve this
HARD DISK MAINTENANCE
Harddisk maintenance should be carried once a month to make your computer runefficiently.Thisremoves redundant and temporary files, recovers disk space and speed up harddisk access.Disk Cleanup should be donefirst - Click My Computer - then right click on the C drive then click Properties,then click Disk Cleanup - let it examine the C drive then it will calculate theamount of disk space it will recover, tick all the boxes to recover themaximum disk space and then Click OK and then Yes to perform theseactions. If you have a D drive then repeat these steps on this drive too.Next the C drive needs tobe Defrag. This process converts fragmented filesinto continuous files and this speeds up disk access and makes the hard disknot work as hard. Click on Start - All Programs - Accessories - SystemTools - Disk Defragmenter - click to highlight the Cdrive and click Analyse - then click Defragment.When this is completedrepeat these steps for the D Drive if you have a D drive.Disk Cleanup and Defrag can take a long time to complete, especially ifthese tasks have not been for a long time.
May 09, 2012 | Dell Inspiron 1525 Notebook
I have a DELL Inspiron 1720 with windos vista. I am trying to install windows 7 but it is showing me this message: OEM Name : DELL INC OEM model: Inspiron 1720 BIOS version: Phoenis ROM BIOS plus...
You need to check the specifications of your laptop it may not be able to run Windows 7.
You need these specs:
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
Sep 17, 2011 | Dell Inspiron 1720 PC Notebook
I have Dell inspiron 1525 window vista recovery reports 5 error are detected in hard drive and memory errors detected on my laptop 1. hard drive doesnt respond to system commands-critical error 2.boot...
your HDD may be corrupted, re-installing windows vista is one option. Your best bet is if you have/ can obtain a copy of windows vista run setup and try the repair wizard in the windows vista setup, the wizard automatically finds errors and missing files and replaces them therefore solving any errors in your HDD. you can also try to use the recovery wizard from your recovery disc. best of luck
May 17, 2011 | Dell Inspiron 1525 Notebook
I have dell inspiron 5160 is very slow n getting problem in more time now problem is laptop wanted boot ,where is problem i dont know but stopped in unwanted time n after
5 ways to speed up your PC
By following a few simple guidelines, you can maintain your computer and keep it running smoothly. This article discusses how to use the tools available in Windows 7, Vista, and http://www.microsoft.com/atwork/maintenance/speed.aspx#">XP Service Pack 3 (SP3) to more efficiently maintain your computer and safeguard your privacy when you're online.
1. Free up disk space
The Disk Cleanup tool helps you free up space on your hard disk to improve the performance of your computer. The tool identifies files that you can safely delete, and then enables you to choose whether you want to delete some or all of the identified files.
Use Disk Cleanup to:
  • Remove temporary Internet files.
  • Remove downloaded program files (such as Microsoft ActiveX controls and Java applets).
  • Empty the Recycle Bin.
  • Remove Windows temporary files such as error reports.
  • Remove optional Windows components that you don't use.
  • Remove installed programs that you no longer use.
  • Remove unused restore points and shadow copies from System Restore.
Tip: Typically, temporary Internet files take the most amount of space because the browser caches each page you visit for faster access later.
To use Disk Cleanup
Window 7 users
  1. Click Start, click All Programs, click Accessories, click System Tools, then click Disk Cleanup. If several drives are available, you might be prompted to specify which drive you want to clean.
  2. When Disk Cleanup has calculated how much space you can free, in the Disk Cleanup for dialog box, scroll through the content of the Files to delete list.
  3. MORE INFORMATION GO TO THIS LINK: http://www.microsoft.com/atwork/maintenance/speed.aspx
Dec 06, 2010 | Dell Computers & Internet
Hi, I am owning a dell inspiron 1525 for the last 3 years now. Few days ago when i was formatting my laptop to install a new OS, i accidentally deleted a partition and it became unallocated. My hard disk...
Startup from the windows 7 disk as if you were going to reinstall. Choose 'advanced' in the section where you sort out the disk to install to, and partition the unallocated space. Then exit out, do not continue to the format and install stage.
Once you have restarted into your original windows, you can format the new partition as normal.
Having said that, 10gb is pretty small for an OS partition, 15 0r 20gigs would be better and you can swap some space from your new partition to the OS partition. There are plenty of tools you can use to do this with at www.download.com.
Aug 29, 2010 | Dell Inspiron 1525 Notebook
Deleting updates, freeing space on hard drive
if you are running windows vista, this might help alot, if running xp, it might not, go disk clean up for drive c. to do this, open up my computer, and right click on drive c, and open up properties. click on disk clean up, and a window should show up. if you are running windows vista, its going to ask if from current user, or all users, click all users. after the calculating window, a window that says disk clean up for drive c will show up. click on the tab at the top of that window that says more options, and on the bottom box, which should say system restore and shadow copies, click the clean up button. the longer it takes, the more space its freeing up. Goodluck
Jul 07, 2009 | Dell Inspiron 1525 Laptop Midnight Blue
Have tried a solution but there's still a problem
look first make habit of saving ur downloads to Drive D ok never save ur download s on drive Acer : C secondly let me tell u windows Vista is a bulky OS and it needs much space on hard drive thats why atleast 120 Gb is recommended for Vista it seems like u have an 80 gb hard drive Vista will work but it will take much of ur drive space as my Vista installation is around 39 GB now i dont know but it grows his size day by day thats why some ppl with less system resources go back to XP , u can free up more disk space by doing following:
go to http://www.ccleaner.com download ans install it run the cleaner and look for temp files that may be lying and occupying disk space.
2. Go to My Computer Right click on Acer C take properties click button Disk cleanup select files from all users let it scan ur hard drive and then it will present u with some temp files , hibernation files and thumbnail files and error reporting files check the boxes and perform the cleanup select all of them u will get some space press OK it will cleanup and delete these files and u will see some space freed up, in more options in the same windows u can also uninstall some progrmas on ur C drive which u installed and u no longerr want now u can un install them as well after that come out of it
3. Now go to My computer right click and take properties of Acer C now go to Tools Tab and select Defragment Now and select C drive and defrag ur drive this will take time after this correct free space will be visible to u after all cleaning steps
if u get enuff space u wanted then it is ok otherwise u can also take some space from the D drive and can merge into C drive if u want i can help u in that but i prefer changing ur hard drive as it is too small for a system like Vista , XP will give u no trouble on that drive
pls let me know and do rate me if i fixya problem
Feb 25, 2009 | Acer Aspire 9410-4317 Notebook
Slow computer
amy b d disk is full try to free some space or try using any recent antivirus software like avira,macafaee to scan fro virus
May 07, 2008 | Dell Inspiron 6400 Notebook
Gateway MX6447 Notebook Logo
116 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
