Question about Acer TravelMate 4010 Notebook
Can't get power to my laptop.don't know if it's the laptop, or the powercord
Is there a way for me to find out if my laptop isn't working because the powercord is faulty or is it the laptop itself without buying a new powercord?
    President:
  • 2,004 Answers
Look for a friend around and trouble shoot swapping the power cords. But I believe it must be your power cord that should be replaced.
Do the trouble shooting before replacing.
Rate this, please.
Posted on Apr 23, 2009
Where is the fuse located at on acer computer
There is none.
If it is a Desktop Computer (case) you will need a new power supply or a different one to test if that is really the problem.
on a laptop, try holding the power button for ~40secs with all power diconnected (no battery and no powercord).
then re-plug the powercord to see if it will turn on. Try a different powercord if it still wont turn on, or have it tested at an electronics store.
Aug 30, 2014 | Acer Aspire Computers & Internet
I have a flashing red light where the white light should apper
it might be your power cord, if the battery is empty and your powercord no longer working, the light will flash red to indicate it has not enough power to turn on. Try a different powercord for the same model, or have your current one tested at an electronics store.
Aug 30, 2014 | Dell Computers & Internet
Powercord replacement
please explain further.. do you mean your laptops power adapter cord?
thanks for using fixya
Nov 10, 2011 | IBM ThinkPad 380ED
When i push the power buton the powerled go on and few secons off again i used the powercord suply and the battery suply. Could i be the power suply I.C wiht best regards Andre
Hi
Try this. Remove Battery. Hold power button for 10 to 20 seconds Insert Battery and switch system on. Let me know if this works
Oct 01, 2010 | HP Compaq nx6125 Notebook
I just used my laptop at work and when I got home with it and connected it, I can't get the power on, and I hear a little sound from the powercord (or the transformator - the thingy between powercord and...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Sep 11, 2010 | HP Compaq nc6000 Notebook
My powercord
Try another power supply. If you don't have one try visiting the place you purchased the laptop and using the power from one of their display units. If it works, then replace the power supply of course.
If not hopefully your laptop is still under warranty.
Does the jack feel loose, do you get an lights?
Let me know.
Feb 26, 2009 | Acer Aspire One PC Notebook
Problem with booting my A205-S4577 with the powercord on
Have you tried a new power AC/DC convertor ? make sure you have the correct spec...see manual for power adaptor needed. Cost less if you can get a loan of one. other than this i would be looking into checking the power jack. hope this helps
Feb 15, 2009 | Toshiba Satellite A205-S4617 Notebook
Which powercord to use?
In the bottom of the laptop you can find the input required, make sure the voltage matches the requirement and the connection is the right way.
from what you said I can't tell if its too stong, can you adjust the voltage? look in the bottom it is documented there on a label.
Jan 16, 2009 | Acer Aspire 1640Z Notebook
I have no power up the icon for the power doesnt come on no power what could be the problem I have a r31 series laptop
check your powercord power adapter its working or not if working then you have to send your laptop to service center its a motherboard problem
Sep 27, 2008 | IBM Computers & Internet
No powercord
I'm not sure which powercord you wanted because the title and the message had different things, so I'm providing both.
This is for the CN6555 Power Adapter.
http://www.laptoppartsnow.com/wabacnseauca3.html
http://www.shopbattery.net/wabacnserela2.html
Very inexpensive at
Ebay Seller
Dec 01, 2007 | Balance CN6555 Notebook
Acer TravelMate 4010 Notebook Logo
178 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
