Question about Hoover Refrigerators
Need to replace freezer door seal on Hoover HFA29K
Have purchased a new freezer door seal but cannot see how to get the old one off, cannot see any screws under the seal and there seems no obvious way of changing the seal.........any clues please?
    Guru:
  • 1,524 Answers
This is probably a "push in" gasket.
Posted on Apr 23, 2009
I have a Hoover Fridge freezer and my fridge is really warm inside and the freezer is not freezing the food in the top drawer but it is keeping the food a bit cold. What could be wrong with it?
It could be
- a faulty thermostat
- a loss of refrigerant through leakage
- a very poor sealing door gasket
If the fridge is old I'd say you will need to replace it.
Nov 13, 2016 | Hoover Refrigerators
Why is my Hoover A Class upright freezer alarm light constantly on
1) It could be a short. 2) The thermo sensor that turns the light on could be defective and needs to be replaced.
Mar 24, 2015 | Hoover 9.9 cu. ft. / 280 liter Upright...
My hoover hfa29k fridge freezer originally started to freeze the contents of the fridge and appeared to be running continuously.I unplugged it and left it for about an hour and then switched it back on...
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
Try this and let me know.
Feb 22, 2011 | Hoover HFA290K Bottom Freezer Refrigerator
ICE DOOR SEAL IS LOOSE AND NOT SEALING CAUSING FROST BUILDUP
This is the step you will use to repair your ice door seal that is loose.
There are screws under the fold of the freezer door gasket that holds the brace for the gasket in place. Lift the rubber gasket to expose the screw head, one section at a time. Just loosen the screw, and do not take it completely out.
As you loosen the screws, one section at a time, carefully remove the old gasket. At the same time, fit the new gasket into the groove. Make sure your new gasket is lined up properly.
Continue around the freezer door, unloosening the screw, taking out the old gasket and fitting the new one in.
Tighten the screws into place. This may have to be done once the entire gasket is fitted into place.
Check the seal by closing the door. You should have a nice, tight seal.
Good luck.
  • Step 4 Tighten the screws into place. This may have to be done once the entire gasket is fitted into place.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7rn3O8
  • Step 3 Continue around the freezer door, unloosening the screw, taking out the old gasket and fitting the new one in.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7gYaZ2
  • Step 2 As you loosen the screws, one section at a time, carefully remove the old gasket. At the same time, fit the new gasket into the groove. Make sure your new gasket is lined up properly.
  • Step 5 fix-freezer-door-seal-1.5-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep5 span.image a:first').attr('href','http://i.ehow.com/images/a04/k5/eg/fix-freezer-door-seal-1.5-800X800.jpg'); }); Keep the gasket clean to last longer. Check the seal by closing the door. You should have a nice, tight seal.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7JfY8i
    Jun 22, 2010 | Refrigerators
    I need to change the door seal on a 1990 ge fridge and top freezer, looking for tips on how to remove and replace seal. i have the new seal.
    place new seal in warm water for 15 min. start at one corner, remove appr 4 srcews in each direction pull old gasket down. now start to install new. continue to remove old and install new. make sure to remove weight from door. after your done place a film of vasoline on mating surface.i sometimes will roll a small amount of paper towel to insert where gasket is not wanting to pull up . push door firmly shut for a few days.
    Jan 19, 2010 | GE GTS18HCM Top Freezer Refrigerator
    Freezer door of electrlux freezer keeps coming
    Try cleaning along seal and seal itself. If it does not work get new seal. The seal do go bad after a while.. If under warranty call dealer you purchased from for them to replace.
    Jul 06, 2009 | Freezers
    Is my warming fridg worth repairing?
    you will have to get in a technician to do a proper diagnosis to get enough information to make that decision. the service call will be very small compared to the cost of a new unit if the repairs are cheap
    because the compressor is working overtime , it suggests that the door seals are faulty and not sealing or the door/s need adjustment
    May 18, 2017 | Refrigerators
    Not Freezing
    Check the door seal all the way around. We purchased one recently that was slightly dented (not noticeably and the seal was not tight.) You need to get in touch with whomever you purchased it from immediately so that it can be repaired or replaced.
    Aug 18, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
    Refrigerators Logo
    168 people viewed this question
    Top Hoover Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    tom wright
    tom wright
    JONFRIDGEDOC
    Level 1 Expert
    Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
