Question about Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin Oil Radiato Heater
Honeywell oil radiator
I lost the manual for our oil filled radiator heater. I need to know how to program it for timer and temp setting. Thanks
  • 1 more comment
  • Slack Matt Aug 17, 2008
    I lost the Manual and i do'nt know if i have to refill with oil. also, if i do have to refill; what kind of oil do i use?
    Matt Peterson
    Wilmington, N.C.
  • Anonymous Mar 17, 2014
    oil filled radiator heater not working
    oil filled radiator heater doesn't work
  • 4 Answers
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Posted on Nov 16, 2007
How do we operate and turn on it i have no manual
The left button under the temperature display lets you toggle between the heat output (high, medium and low) settings. Press the left or right side of the buttons. The center button sets the timer; press the left side of the button repeatedly to increase the run time. Press the right side to lower the length of time before the heater shuts off. The right hand button sets the desired final temp. Again it's an up/down toggle on the left and right sides of the button. Once you get to the desired temperature (in 1 degree increments), the display will return to showing the current temperature three seconds after you release the button.
Home Depot has the Use and Care manual on their product site: http://www.homedepot.com/buy/honeywell-1-500-watt-oil-filled-convection-portable-heater-hz-709.html#.UMp5GTmk5G8 . The direct link is http://www.homedepot.com/catalog/pdfimages/79/79058e0a-291f-48e8-8667-ff500b3d7bb7.pdf?cm_mmc=seo'altruik'202804472 . You will need Adobe Reader or a similar program to view the document.
I hope this helps.
Dec 14, 2012 | Honeywell HZ-709 Oil Filled Radiator...
Need to know what the buttons mean lost the instructions, need to know how to set it uo.
You can freely view the manual here.
I hope this helps & good luck. Please rate my reply. Thank you.
Apr 14, 2011 | Honeywell HZ-709 Oil Filled Radiator...
Where can I download the owners manual?
http://www.honeywellcentral.com/ssi/pdf/honeywell-commercial/oil-filled-heaters.pdf
That is the owners manual for your model. If you need anything else, let me know.
Feb 20, 2010 | Honeywell HZ-709 Oil Filled Radiator...
How do you set heater to work? I have no manual for this heater it is Honeywell HZ-709 Oil Filled Radiator Heater After I turn it on How do I turn it on and set it to work?
That is the manual you need. Hope it helps. If you need anything else, let me know.
Dec 29, 2009 | Honeywell HZ-709 Oil Filled Radiator...
Honeywell HZ-709 oil filled radiator heater-all controlls work but no heat produced. Possible reason?? Thanks
There is a bottom element and a top element so the elements could be dead.
More likey, there could be no power coming from the wall - there are switches on the front that need to light up or the thermostat could be set to off.
Dec 07, 2009 | Honeywell HZ-709 Oil Filled Radiator...
We purchased the Honeywell HZ-709 heater and the instruction manual is missing. How do we operate it?
That is the manual that you need. Hope this helps. If you need anything else, let me know.
Nov 19, 2009 | Honeywell HZ-709 Oil Filled Radiator...
How do I program my Honeywell HZ-709 radiator heater
Is there a seperate control for the timer and temp? If so, turn the temp off first and then the timer.I think they need each other for safety.
Oct 30, 2009 | Honeywell HZ-709 Oil Filled Radiator...
Delonghi MG15T Magnum Oil-Filled Radiator timer -timer keeps running?
I found the manual at this website:
http://safemanuals.com/user-guide-instructions-owner-manual/DELONGHI/MG15T-_M
I hope this helps.
Oct 13, 2008 | DeLonghi MG15T SafeHeat Oil Filled...
Heater shut off but doesn't turn on by it'self
Do not touch the timer, once you do, it activates it. Set the temp. and leave the timer alone, unless you want it to shut off at a given time, 1 hr. and up. Once the timer shuts off you will have to start it manually.
Oct 14, 2007 | Honeywell HZ-709 Oil Filled Radiator...
Heating & Cooling Logo
934 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
