Question about Cell Phones
Hang up my 6233 is always hang up when i press the push to talk on the left side of this unit
  • 122 Answers
Button on side is not for answering calls.
PTT or Push To Talk allows you to use your mobile like a walkie talkie. It is dependant on your network operator running the service.
Quote from Pocket lint:
To use the function you must first create a group or individual in your phone menu and send an SMS invitation to those you wish to join. Once your contacts are set up, your phone shows which members have their handsets switched on with push-to-talk enabled, in the same way that instant messaging works online. By pushing a single button on the handset, you are connected with one person or with your group. There is no need to dial numbers, nor do the recipients need to answer calls. You simply push a button and talk. As with a walkie-talkie, anyone in the group hears you almost instantaneously. The talking is one way with only one person able to speak at a time. Unlike walkie-talkies, which are infuriatingly dependent on distance, push-to-talk has no such limitations.
You should be able to disable PTT in the Nokia menu, which is best if your network doesn't support it. Plus you won't keep cutting off calls.
Posted on Apr 23, 2009
Dear sir, my phone nokia 6233 hang so many time restore factory setting my phone plz help me give me code Regards, Prashant
Use Nokia Master Code for reset to factory setting : 12345 or 00000, but try 12345 first.
Hope this help.
Feb 11, 2011 | Nokia 6233 Cellular Phone
Can i asked the hard reset code of my nokia 6233 . thanks a lot sir .
Hello
*#7370# .......... Format phone...[Hard-Reset]
*#7780# .......... Factory Reset
if that doesnt work in case you lost your lock code, try:
Turn phone off, press and hold the green (talk) key on the left + number 3 on the keypad + the * key + the on button.
good luck
Feb 09, 2011 | Computers & Internet
I have a segafredo zanetti vienna de luxe. I have had this problem before and the the guy(unfortunately they are closed today) where I bought it talked me through a re-set with the buttons. The problem is...
Read through this until you find how to reset the brw unit thyen follow the directions.
Remove the dredge drawer. Open the door. On the left side of the brewing unit, and towards the back of the brew group, there is a single screw. Remove the screw. Grab the handle and pull carefully, but firmly with a quick ****. The brew group should come out. There is a piece that remains in the machine. Slide that piece down and to the right and it will come off. Insert the piece into the hole on the backside of the brew group with the clip up. Tighten the screw and move brew group back into position.
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. (You can insert your key into the hole in the front and twist the key to return the brew unit to the center. Line up the 2 diamonds and it centered) If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit,(it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door and turn on the machine without having the brew group in, but you must have your drip tray and dredge drawer in. Turn the machine on. You will hear the motor turn on and when it stops completely, open the door and remove the tray, now insert the brew group and replace the tray.
Feb 05, 2011 | Saeco Vienna De Luxe Espresso Machine
The press nob when you open it will not press down it jamed and it will not come out it stuck
Hi
Directions for removing a stuck brew unit. Vienna.
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. (You can insert your key into the hole in the front and twist the key to return the brew unit to the center. Line up the 2 diamonds and it centered) If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit,(it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door and turn on the machine without having the brew group in, but you must have your drip tray and dredge drawer in. Turn the machine on. You will hear the motor turn on and when it stops completely, open the door and remove the tray, now insert the brew group and replace the tray.bansheracer_0.jpg
Jan 17, 2011 | Saeco Vienna SuperAutomatica Coffee...
Motor stuck in brew postion wont reset even with the brew group out
Hi
Leave the brew unit out but put everything else back in and then turn the machine on. the brew drive should reset to where it should be so you can put the brew unit back in, but make sure that the brew unit is ready to install.
You must make sure that the brew unit is ready to reinsert into the machine. To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. If you have you key you can insert it in the front of the brew unit. There is a round hold in the center below the "Push", and twist it clockwise until it stops and the 2 marks are lined up. If you don't have your key you can do this. Push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit, (it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Press the "Push" lever until you hear a click and you are now ready to reinsert the brew group in to the machine.
Dec 31, 2010 | Saeco Incanto Classic Espresso Machine
My Nokia 6233 Hangs & Then Shuts Down.
check the side button PTT
and make full reset
May 11, 2010 | Nokia 6233 Cellular Phone
Fomat my phone
Try *#7370# .......... Format phone...[Hard-Reset]
That formats everything.
But in case you forgot your lockcode.
Switch it off, press and hold the green (talk) key on the left + number 3 on the keypad + the * key + the on button.
Apr 01, 2010 | Nokia 6233 Cellular Phone
Camera opening time hang
go to settings and press factorysettings
Oct 03, 2009 | Nokia 6233 Cellular Phone
ANSWERING A CALL AND NON FUNCTIONING ANSWERING SYSTEM
no make or model listed
on many phones there is an ability that when the phone is picked up it is automatically connected to the caller and pressing the answer button is the same as hanging up
as for you second point , if a caller rings but hangs up before the message beep or after the beep but hangs up , there will be no message recorded
Nov 15, 2017 | General Electric 29115AE1 1.9 GHz 1-Line...
Unlock memory card
6233 memory Card Password missing
Mar 29, 2008 | Nokia 6620
Cell Phones Logo
170 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
