Question about HP LaserJet 3015 All-In-One Printer
Page gets rolled
The paper/printout gets rolled at the right hand corner after it comes out from the printer
    President:
  • HP Master
  • 2,022 Answers
Problem with your paper roll assemby and it is hardware problem it will be bettre if you show your printer to service personnel .bye
Posted on Sep 24, 2007
Stop Ejection of printing paper roll after printing in dot matrix printer
I assume you are printing on roll paper, but printer acts like it is printing on cut sheet paper. When finish the page, it ejects it, but it is not a page, it is a roll and the paper keeps unrolling, right? There have to be a lever that swithes between cut sheet paper and roll paper. Turn it to the oposite direction and the problem should be fixed.
May 18, 2015 | Matrix Office Equipment & Supplies
Epson DFX9000 printer is printing blank pages
On mine it was to turn off the printer. Then while holding down the paper feed button, press the power button. Let go of the paper feed right away as soon as you hear it start up. When it's done you should get a printout with a number at the top.
OR
Still Having Epson Printer Problems Then follow Us On: Epson Printer Support
Jan 27, 2014 | Epson DFX9000 9PIN WIDE 1550CPS PAR SER...
Can Lexmark x2470 scan and print a double sided document?
after reading the manual, http://www.lexmark.com/publications/pdfs/2007/2400/ug_en.pdf, yes it is possible - not that it tells you how to do it though so read on.
Until you become familiar with the process just use one sheet of paper at a time in the printer.
As you know, in the scanner the top right of your document goes to the right hand front corner of the scan bed (the clear window), place the page on the scanner and scan.
Pick up the printed sheet of paper and flip it so the left hand side edge is now in your right hand and the right hand edge is now in your left hand and you are now looking at the blank side of the paper.
Insert the page back into the sheetfeeder.
Flip the page to copy in the scanner so the rearmost edge of the paper is now to the front of the scan bed and the front edge of the paper is now towards the rear (you should now be looking at the page you scanned previously).
Scan the page.
you should have now scanned both sides of one sheet of paper to another sheet of paper.
as your printer does not have a sheet feeder for the scanner you have to do the process manually. hope this helps.
Apr 20, 2011 | Lexmark X2470 All-In-One InkJet Printer
Changed label but now 1/2 the printout runs off label
you have to register the roll to the top edge and hit the zero function or top of page reset. try advance paper with machine off and turn on
Oct 09, 2010 | Dymo LabelWriter 400 Thermal Printer
The bottom right corner of the paper page gets stuck and stopped in the process. I have turned it upside down, nothing is in the printer. When I look at it, it just starts to buckle in this corner and...
Hi! Please try this. Unplug the printer from power source then press/hold the power button for 10secs. while the printer is unplugged. This should reset the printer's system and get rid of the problem. Plug the printer again, turn it on and see how it goes. Hope this helps and thank you for using FIxYa!
Sep 22, 2010 | Canon MX300 Office All-In-One Printer
EPSON AcuLaser C1900 paper jam when printing black or color
I have just gained a C1900 second-hand and have set it all up and got the drivers and so forth. Am having exactly this problem, right down to the folded pages, wide top margin and 'Check Paper Size' error message. Did you ever find a solution to this? Anyone else know how to fix it?
Jun 06, 2009 | Epson AcuLaser C1900 Printer
Smudged Printing
change ink cartdidge then try. check also paper jam.
if still problem then change ink cartridge then check.
Jan 05, 2009 | HP LaserJet 2100 Printer
Sharp Electric Cash Register XE-A203. I just put a new paper roll into the register because it was out of paper. The register screen is showing all numbers and transactions but when the paper comes...
Hi whitwall,
Please make sure that you have the right paper roll.
Your machine takes a thermal paper roll, which means it actually burns the print into the surface of the paper as opposed to printing with a ribbon or ink roller like other makes.
The thermal paper will only show a print on one side of the paper, in other words if you do indeed have the right roll and it is in upside down you will get a blank printout.
An easy way to see if it is the right paper hold the roll in your one hand and scratch a line with the thumb nail of your other hand accross the surface of the roll,if you get a black line on the paper then it is the right one, otherwise you have what we call a "bond" paper roll and it will not work in your machine.
If you got the "black line" with your thumb nail, then lift the printer head arm (green lever) place the roll in position with the paper rolling out from the bottom of the roll towards the front of the machine, pull the paper out past the catch mechanism and close the printer ****.Tear off the excess paper and replace the printer cover.
You should be ready to go ahead with sales.
This should solve the problem .
Regards
Gavin.
Oct 16, 2008 | Sharp Office Equipment & Supplies
Paper jam
Do the rollers need cleaning or lubrication? Mine pulls on the left hand corner facing the printer
May 11, 2007 | Canon i250 InkJet Printer
HP LaserJet 3015 All-In-One Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
