Question about Husqvarna Sewing Machines
Presser foot pressure dial changes on husqvarna 230 sewing mach
My wife sets the presser foot pressure on her viking husqvarna 230 electronic sewing machine but the dial changes position whenever she raises the presser foot lever. When the presser foot is lowered she has to reset the presser foot pressure. Shouldn't the dial stay put when the presser foot lever is raised?
  • 323 Answers
SOURCE: Presser foot lever stuck
You lever doesn't work because the presser foot Bar is seized from lack of use.Open the side of the machine to access the bar. Put a mixture of water and ammonia ( about 80%water 20% ammonia) on the top and bottom of the bar. Let it sit for 15-20 minutes then try to move the presser foot Up by lifting the foot with a screw driver. Do not pry so hard you break something. It should get progressively easy the more times you do this. Put some sewing machine oil on the top and bottom of the shaft and it should be good to go.
sewman7
Posted on May 31, 2008
  • 192 Answers
SOURCE: Presser foot wont raise and lower
Does the presser foot move at all when the machine is first turned on?
Do the needle and feed teeth calibrate when the machine is first turned on?
You probably need to locate your nearest authorized repair center.
Posted on Jun 12, 2008
SOURCE: When I attach the embroidery arm and turn on the
My moms does the same. One way we got around it was to hold the presser foot all the way up and click the ok button on the screen. The other thing we did would be to hold the presser foot up all the way while turning the machine on while the embroidery unit was already attached. When I say raise the presser foot all the way up, I am talking about raising it up as if you were placing something really large under the foot, not just in the resting up position. Hope this helps - it is very frustrating! My sister has the same exact machine purchased at the same time as my moms, but she doesn't have this problem.
Posted on Dec 19, 2009
RichSew
  • 184 Answers
SOURCE: presser foot control -- Viking Husqvarna #1 sewing machine
There is a presser foot pressure dial on the left end of the machine, make sure it is on 3 or higher.
Posted on May 27, 2010
Testimonial: "Thanks--Don't know how the wheel was moved, but that fixed the problem. Now if I could only find the owner's manual!! "
SOURCE: presser foot lever does not lift presser foot
It could be that yours is frozen like mine was. I followed the directions for resetting the screw, but it still wouldn't go. I had to sand off the rust and tap the end with a hammer! Now it goes up and down just fine! I have a Singer 9005, but like the techie said, they are all a lot a like in this part.
Posted on Dec 06, 2010
Can the feed dogs be adjusted up or down on a husqvarna viking quilter
They are adjustable but should be done by a sewing machine technician. Special tools are needed to get the setting right.
If the feed dogs are not pulling the fabric through the machine, check the presser foot pressure adjustment. It tightens the pressure on a spring on the presser foot bar causing the presser foot to apply more or less pressure to the fabric. The pressure adjustment can be located several places but usually around the head of the machine--to the left of the needle or at the very top of the head. Some older machines simply have a screw that is located under the top lid.
Jan 04, 2017 | Husqvarna Sewing Machines
Change the presses foot
Check the user manual. You can view, download, or print the manual free from the viking website - http://www.manuals.husqvarnaviking.com
See page 11.
Changing the Presser Foot ! Turn off the main switch
  1. Make sure that the needle is in the highest position. Pull the presser foot towards you and slight pressure downwards.
  2. Line up the cross pin on the foot between the spring and the presser foot ankle. Press back until the foot snaps into place
Aug 12, 2014 | Husqvarna Scandinavia 100 Sewing Machine
How to set bottom and top thread center of material
Hello
It sounds like you are trying to balance the top and bobbin thread so it locks perfectly. If so, this is accomplished by balancing the thread "tension". If you see loops on the underside of the fabric, tighten (increase) the tension. If loops for on the top, lower the tension.
If the fabric is puckering: reduce the stitch length AND you may need to use a finer needle along with finer thread in the bobbin and on top.
Presser foot pressure is rarely adjusted, unless sewing with extremely variable fabrics. For example, pressure is lowered when sewing with silk chiffon as it transports easily under the presser foot (and to prevent damage to the fragile fabric). Whereas pressure is increased when sewing with tent canvass to allow the feed dogs to be able to 'grip' and move the fabric.
Happy Sewing!
Jun 07, 2014 | Husqvarna Viking 1
How to adjust pressure foot pressure on husqvarn viking disginer 1 sewing maching
I'm confused by your question, which mentions two machines. The presser foot pressure on a Tacsew T111-155 is adjusted by turning the knob on the left side, top of the machine that is directly over the needle. The Designer 1 mostly sets its own presser foot pressure, but it can be increased or decreased by following the procedure on p. 13 of the manual: http://new.husqvarnaviking.com/SiteMedia/Products/Machines/Support/Designer_I_manual_EN.pdf
May 22, 2014 | Tacsew T111155 Mechanical Sewing Machine
How do I move the presser foot on a Husqvarna Viking Emerald 116 sewing machine?
Not sure what exactly you need to know. Are you trying to lift the presser foot or change the presser foot to another one? If it is lifting, there will be a lever of some kind behind the machine. On one of my Husqvarna machines it was a big flat "paddle" shaped lever, not sure what shape it is on the Emerald machines. Lift the lever from the bottom upwards and outwards. Most Husqvarna machines have clip on-and-off feet. You just gently pull forwards on the foot (while the presser foot is raised) to remove it, then push the new one on making sure the small bar part of the presser foot goes into the clip on the presser foot ankle.
Jun 16, 2010 | Husqvarna Viking 1
Presser foot control -- Viking Husqvarna #1 sewing machine
May 23, 2010 | Husqvarna Viking 1
Ordinary straight stitching
When you turn on a #1 Husqvarna Viking the machine defaults all the electronic settings to do a straight stitch at a 2.5mm stitch length, that equates to approximately 10 stitches per inch. The top tension dial sets itself automatically and the only other dial is on the left side of the machine. That dial sets the pressure on the foot that holds down the fabric. It's normal setting is 6.
Sep 02, 2009 | Husqvarna Viking 1
Presser foot husquvarna rose
You should be able to adjust the pressure on the presser foot. Check your user manual or see an authorized husqvarna viking dealer for assistance. They are usually eager to help. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Nov 11, 2008 | Husqvarna Rose
Sewing Machines Logo
230 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
