Logitech microphone k i have a 2 in 1 set which includes both microphone and head phones my headphone parts work perfectly but not my microphone even my friends say that they cant hear me and i dont get whats wrong its pluged in ?
  • 73 Answers
1 - Check to see if you plugged the microphone into the PINK socket (I know I might be sounding like I'm talking down to you but the most common problem is people just jamming the plug into any color hole but you need to use color co-ordination like pink to pink ... green to green, It wouldnt be the first time someone has said to me "Oh I though Blue and Green look quite spiffing together")
2 - See that little speaker icon in your task bar next to the time? Double click on it and look for the microphone ... Mute it ... Trust me, you do not want feedback in your ears! I know too many people with tinitus!
Next keep the new window you just opened open, Click on "Options" then "Properties" ... Then select "Recording" ... In the little tick boxes check that the microphone input is ticked then click "OK"
The window for the sound will now have changed to the INPUT sounds, Or RECORDING as I like to put it ... Turn the microphone all the way up and select the tick box under it to make sure that anything listening for you uses the microphone input, Yes you can change it to line in or cd and play music over the internet but you want the mic I'm guessing.
Next click options one last time and select advanced controls (If its not ticked already) and see if an optional button appears below the microphone slider.
Click the now appeared button (Normaly "Advanced") and choose the +20 Db boost.
Now when you talk to someone it should work ... If someone says your distorted or too damn loud turn that microphone slider in the recording option down a few notches and try again until you get the desired sound ... If it still doesn't work then get hold of me and we can figure something out.
Posted on Apr 23, 2009
    Problem Solver:
  • 11 Answers
Have you checked the settings under control panel/sounds and audio devices?
open that up click the voice taband under voice recording press the volume button, check to see if the check box has a tick in it under microphone and that the volume is turned up. try the test hardware button to test your mic and adjust the levels from within the wizard.
hope this gets you headed in the right direction
Hear myself through my headset
so to begin
1. right click the lil speaker on the bottum right hand side
2. select Playback
3. Right click you default speaker set, (for me its 2-logitech G330 headset)
4. select properties
5. go to Levels in the tab menu.
6. use the microphone slider and slide the microphone volume to 0
hats it your done, your mic will continue to work as normal with out the feed back loop in ur head set.
Aug 30, 2012 | Logitech USB Desktop Consumer Microphone
My head phone works very good but the microphone doesn't work
When you say headphones do you mean the music headphones, like speakers, because they go in the headphone jack in the computer while microphones go in the microphone jack. The microphone is normally a pink color and the headphone jack is normally green. If you already knew this try wiggling the microphone to see if there is a brake in the wire, if that dose not make it fissile in and out then its something wrong with the microphone its self and should be replaced
May 03, 2011 | Logitech (980240-0403) Microphone
I got new Logitech Clearchat stereo headphones. I plugged the two pins into the pc - pink and green. When I do a skype test I hear the message from my computer speakers (settings says Realtek HD..with no...
realtech hd is your sound device. go into windows control panel and access the sound settings then navigate to voice settings click the volume button,your mic might be muted. also if you want the headphones to work plug them into the plug that your speakers are using (side-note: mics and head phones never need something installed to work as long as your sound device works and your definitely does work,only when the mic is a special interface like USB do you need to install software and/or drivers)
Apr 01, 2011 | Logitech ClearChat Stereo Headset Headset
The Microphone for my logitech headset (clear chat) will not work with Skype.
Try checking if the mic volume on the pc is enabled, and if it's pointed to logitech.
Jun 06, 2010 | Logitech ClearChat Stereo Headset Headset
I got a blue snowball microphone and had 2 problems. On XP, I can get it recognized and record stuff (I use Acid Pro) but while I am recording (with headphones) I dont hear anything in the head phones....
Thanks for purchasing the Snowball! The problem doesn't look directly related to the mic (as it's purely USB) and monitoring is dependent on the capabilities of the recording software being used. For direct monitoring, we recommend GarageBand and Audacity.
Hillary, Blue Microphones
Mar 24, 2010 | Blue Microphones Snowball Professional...
My Speakers and Microphone on my Dell inspiron 15 Dont work
maybe you have a piece of your head phone jack stuck in the port, does the sound still come through the headphones if you re insert them? or have you tried control panel sounds to see if your default speakers have changed ?
Jul 12, 2009 | Dell Inspiron 1521 Notebook
I have a Logitech Pro 9000. After installation, I found that my head phone set that I am using for SKYPE calls was disabled and the Pro 9000 microphone is enabled. There is an echo problem when I speak on...
I have version 4.0.0.206 of Skype. Don't know whether this works on versions below that. If in doubt update your version of Skype, the current version is 4.1, click here to download it if needed.
Within Skype, click Tools, Options
Click on Audio Setting, in the General Tab. Now under the microphone section, click on the down arrow and select your other device and then click 'Save'.
If the other device is not present it may need to be re-installed, Nik.
If this helps click YES below.
Jun 30, 2009 | Logitech QuickCam Pro 9000 Web Cam
How to connect the two wires plugs pinc and green pluggs
On my computer (Compaq Presario) the green jack is the headphones out. I hope this matches yours.
May 22, 2009 | Logitech USB Desktop Microphone
Logitech microphone stuffed up my Computer Speakers!
go to sound icon in bottom task bar, double click on it,go to options,then properties,then click RECORDING,make sure you have a tick in MIC,then go to back to sound icon in bottom task bar,and adjust mic settings to suit
Rod
Sep 19, 2008 | Logitech (980240-0403) Microphone
Loss of signal
The receptor in the Logitech MP3 Wireless and Ipod wireless headphones is located in the right speaker of the headphones, so place your player in a pocket in the right side of your coat.
Dec 03, 2007 | Logitech Bluetooth Wireless Headphones
Computers & Internet Logo
98 people viewed this question
David Payne
David Payne
