Question about Panasonic PT-51HX41 51" Rear Projection Television
Removing chassis for carry to repair shop
I was told the chassis could be taken to the shop. How do I go about removing it?
  • lindason Oct 04, 2007
    I was told it is "easy" to take the chassis out of my Tv to carry to the shop for repair. How do I do this?
Its called the light box and it secured by 4-6 screws from front and rear of the chassis frame assy./when you locate these screws that secure the frame it will pull out from the rear,caution don't break the front harness to the control panel assy. pull off the front and you will see how the chassis is supported to the tv frame and also remove the rear panel ,look at the metal frame as a box.
Posted on Dec 01, 2007
The recorder will not eject disc.I have taken it to various places and have been told parts are no longer available. Can the recorder be repaired?
You're best bet is to find an identical one on eBay with a working disc carrier, then you can take the best of the two to get one working unit.
Mar 10, 2015 | Sony Vintage Mds-101 Compact Chassis Mini...
Knuckles loose - can they be repaired/replaced?
Hi Lauren
Please can you contact us and we can help further with finding out the age of this model Quinny Buzz and whether repair can be provided.
Dorel UK Customer Service
Jan 06, 2014 | Quinny Buzz Three Wheel Stroller
How to replace CMOS battery from dg41 mother board
It's easy, but If you haven't ever taken a computer apart or performed any elementary PC repair, Don't try to do anything like this as you might hurt your PC.
  1. Buy a CR2032 battery from a watch shop/electronics shop/computer shop.
  2. Unplug the computer from the power source and ground the computer's chassis with a piece of wire (Safety measure to protect computer from ESD).
  3. Open computer chassis.
  4. Find the battery on the motherboard (exact location can differ between different motherboards): nipunag.jpg
  5. Squeeze outwards the small metal tab that protrudes from near the battery's edge to make the old battery pop out.
  6. Place the new battery in the same place ( + sign facing up)
There. You're done.
Apr 29, 2011 | Computers & Internet
I had an accident a few months ago on the front right side, the wheel was driven back and after I got it from the shop it is not running well, I was told that the chassis is open and needs to be adjusted,...
You cannot perform any chassis repair yourself. It requires specialized equiptment and expertise. The ONLY way to repair the chassis is to take your car to a reputable certified body shop.
Mar 08, 2011 | 1999 Honda Civic
Sansung DLP HL-P4674W Is making this loud humming noise and the oicture is now in black and white
sounds like a the color wheel blown. Call a local tv repair shop. Some Samsung models carry two different color wheels for same model depending on chassis version which can be seen only when the back is removed.
Dec 08, 2009 | Samsung DLP HL-P5663W 56" TV
Bugaboo Cameleon Fitting a replacement brake shoe
take it to they will be able to repair it for you and they sell new or second hand spare parts.
Mar 05, 2009 | Bugaboo Cameleon Jogger
Opening up a laptop to start repair
Found how to remove keyboard (edge-clips), revealing the final three screws which was holding the motherboard to the chassis
Dec 30, 2008 | Computers & Internet
Replacing IC's
If you carry-in to shop, repairs can run $300.00 + $60.00 parts..
considerably more including pick-up and delivery....
Perform a google search for TV repair in your zip code and ask lots of questions...go with experienced shop owner-operated with
good reviews on ...HTH..........Terryfic.
Aug 22, 2008 | Toshiba 43H71 43" Rear Projection...
Vizio L32 32 in. HDTV LCD HDMI input not working
I recently had the same problem with my vizeo hdmi port # 1 going bad. Tried everything to fix and called vizeo. There solution for a master reset was turn off tv and unplug from the wall. then hold down the power button for 30 secs and let go. plug the tv back in and hold down the volume down and input select buttons down on side of the tv for 15 secs. release the buttons and turn the tv on after powering down all the components connectd to the tv. If this does not work they told me you need to have it sericed for a bad hdmi input. Hope this info helps anyone out there. It didn't work for me. Its a bummer cause the tv is well taken care of and only 18 months old. Best of luck to all others.
May 14, 2008 | Vizio L32 32 in. LCD HDTV
Chassis removal
all the projection tv are made with removal chassis in mind becouse thats the only parts you carry to the shop remove the upper ruber tap and gentely but firme pull the carefull tvs have verry dangerous sites, specialy in that area..good luck
Aug 05, 2006 | Mitsubishi WT-46807 46" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
53 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
