Question about Kenwood DPX-501 CD Player
IPod Interface not working
I have the DPX-501 head unit, I have Kenwood's iPod interface hooked up to it, it worked for about 6 months then stopped, it says Error 60, I cannot find error 60 in the manual, any help would be greatly appreciated.
That happened to me and the PFD Manual online said it means it's a communication error between the ipod adapter and the ipod. The ipod in my case was totally froze and I had to reset it using the hold on off then holding in menu and select for 10 seconds and it rebooted.
Posted on Nov 22, 2007
Can anyone tell me exactly how to interface an IPOD with this radio? I can't find the ACDrive Software...
Posted on Jan 22, 2008
SOURCE:
My kenwood radio just stopped working but the cds will eject?
Have you tried unplugging your battery for a second ? Try that. It resets everything
Feb 11, 2011 | Kenwood DPX-501 CD Player
I have a Kenwood DPX-501, and when I attach my Ipod Touch, it doesn't seem to work. Does the Ipod touch work on this stereo?
you need to call you local car audio shop and get a cable called a kenwood 301 ipod cable
Mar 20, 2010 | Car Audio & Video
Kenwood kdc-mp532u Auxiliary?
http://inform3.kenwoodusa.com/manuals/KDCX590.pdf - Manual
iPod Adapter Compatible: Using the KCA-iP500 iPod Control Interface, you can connect your Apple iPod digital music player to this receiver. The interface (item # 113IP500) plugs into the receiver's 13-pin CD changer input and controls the iPod through the receiver's controls, as well as displays the iPod's text information right on the receiver's display.
Dec 30, 2008 | Kenwood KDC-MP532U
DPX-501 LCD Repair
I got the new display part from the Kenwood supplier on LI, NY but there are dozens of pins on lining both sides of the display, each 1/16" from the other. I don't have confidence in my ability to detach the old and solder the new to the main board without further disaster.
Choices for me now are:
- continue "flying blind" - most likely solution for the moment.
- pay someone to do it - includes removal and being without a head unit for an unspecified time, plus cost.
- replace - I'd like to change brands although it means replacing the Kenwood satellite unit too, so more cost.
This hasn't been a good advertisement for Kenwood. People are impressed by the sound in my car, but not so much by the blank screen, guesswork changing stations etc.
I really like the unit, and the display was great while it worked: exactly as long as the warranty. I can't recommend Kenwood.
Aug 19, 2008 | Kenwood DPX-501 CD Player
DPX-501 Root Menu Help
I emailed Kenwood USA and they gave me the number to an authorized Kenwood service center on the east coast( New Jersey). I sent them the receiver, and within 2 days they sent it back completely fixed. They even fixed an error code I didn't even know wasn't working. Price on the repair will vary depending on the problem. If it is fairly new and still under warranty then there should not be any cost to repair it.
May 11, 2008 | Kenwood DPX-501 CD Player
Kenwood dpx-501
I just solved the problem with my kenwood dpx mp 2090U - (looks similar with 501). FL Display with single CD, USB, 2 Din.
I should share this......... as I received the clue from someone that share the same case to me . Thanks to Mr,Nasirbaek from Indonesia,
The problem is at the main board . Dry (bad) soldering occurred. There are more then 5 resistors in series configuration. The resistor is quiet big (1.5mm x 3.5 mm, surface mount type R) about 2,7Ohms.The position is start from near usb port cable and ended to near big transistor (1 x 1.5 cm power transistor). After resoldering check with multitester to make sure that all R are connected in series configuration.
Just open 3 screws to access the main board. 1 at the top case. 2 at cd assembly, then Carefully take out the CD and the CD ribbon cable.
good luck.
Mar 25, 2008 | Kenwood DPX-501 CD Player
Factory controls interface?
Call these guys at hifiaudio.com and purchase the SWC module that matches your vehicle (ask for Scroche brand). Once you purchase the SWC module, make sure you read the installation instructions two or three times before you install it. Once installed, these SWC units work great. I just completed the installation on my 2008 F150 with the Kenwood DNX-7100 and my steering wheel interface works perfectly.
[email protected]
Feb 01, 2008 | Kenwood DNX7100 Car Video Player
No video from a new 160G ipod
There is a known incompatibility with 6th gen iPods and the DNX7100. Try to find a 5.5 gen iPod or wait until Kenwood releases a software patch.
Nov 14, 2007 | Kenwood DNX7100 Car Video Player
Kenwood dpx 4020
The iPod will stop itself from charging when the battery is full, and will not overcharge. I'm pretty sure you can't disconnect the power to the iPod (would stop it from charging) and still use the Audio to your stereo.
Aug 19, 2007 | Kenwood DPX-4020 CD / Cassette Player
Auxillary option not available in menu
Try putting the unit in standby via the "SRC" button FIRST..., then press the menu button and cycle through to the "AUX 1" option and activate this....then press menu button again. When the unit is next switched on, you should have an "AUX" option accessible via the "SRC" button which will cycle through all of the availale modes ....standby-tuner-cd-aux etc etc.
Jul 01, 2007 | Kenwood KDC-MP628 CD Player
Kenwood DPX-501 CD Player Logo
438 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
