Question about Acer Aspire 3680 Laptop
Cursor i have tried to get the cursor unstuck, i go to control panel thats as far as i can get then cursor gets stuck,,,please help!!!!
    Problem Solver:
  • 12 Answers
Try another driver for touch pad...
Posted on Dec 30, 2011
  • 3 Answers
Pls, try to go to control panel, system properties, hardware, device manager den click positve sign den remove the mouse driver and restart laptop to be avable to redetect mouse.
Posted on Sep 24, 2007
For Cabela's big game hunter 2006: Trophy season i got the boat stuck and ive tryed everything how do u get it unstuck without making a new game
save the game BEFORE you enter the marsh? Use cheats? I'm stuck too. I'm trying to get unstuck using cheats. I don't think the official cheats are working so I'm going to try cheat engine. Hope that helps!
Jan 08, 2012 | Activision Cabela's Big Game Hunter 2006:...
I have an error code 68 what is this?
The error code means a key is stuck; enter the service diagnostic mode and perform the key test to determine which key is stuck. Once the key is determined, try to unstuck it; replace the Electronic Control Board (Part Number AP3851146 if the error code continues to appear after the button is unstuck.
Press and hold simultaneously the Select and Cancel buttons for six seconds to reset the control then immediately after the buzzer sounds, turn the cycle selector knob 5 clicks counterclockwise to position the cycle indicator light second (Touch Up) from the bottom.
Press and hold the Options and Cancel button simultaneously for two seconds to enter the service diagnostic mode. The buzzer will sound three times and all of the LEDs will flash indicating the service diagnostic mode has been entered successfully.
Rotate the cycle selector knob 4 clicks to the Heavy Duty cycle; the motor runs with the heater off. The buttons can now be tested. Press each button and all corresponding LEDs should flash; otherwise the button is stuck or a faulty. Unstuck the key and perform the key test again; replace the control board if the problem is not resolved.
Access to the control board requires the removal of the top panel and the console. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the two screws attaching the top panel to the rear of the dryer then slide the panel rearward and lift it off the dryer.
Remove the four screws, two on each side, securing the console to the front panel then flip the console forward. Disconnect the wires from the control board and lift the console off.
Remove the five screws mounting the control board to the console and lift the control off. Remove the control board's rear cover by releasing the two locking tabs the flip the cover off the control board. Try to unstuck the faulty key and reassemble the dryer in reverse of the disassembly steps.
Hope helps.
Apr 14, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Stops working with code e68
The error code means a key is stuck; enter the service diagnostic mode and perform the key test to determine which key is stuck. Once the key is determined, try to unstuck it; replace the electronic control board (part number 134557201) if the error code continues to appear after the button is unstuck.
Apr 27, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
The cursor on my laptop is non functioning. The trackpad wont control it at all. If I use a mouse the cursor just jumps around the edges of the page. I cant get to the control panel to try to make...
what OS, please if windows, use CTRL+ESC to activate the menu, find control panel, by using the arrow keys all the way till you get to the control panel also use the enter key to activate. make necessary adjustment
this should resolve it, vote for when if resolved
regards
Mar 24, 2010 | Computers & Internet
Haier Portable A/C HPPRO9XC7 will not turn on shows E1. Unit is only 15 months old and has worked well until now. Factory suggest STUCK button -- OK -- HOW do you unstuck a buton.
you can just take the panel off to the control and look for dirt and grime. then take a can of compressed air that you can by at a local hardwar store or office supply and blow around the buttons. also you can unplug the unit and let it reset itself sometimes this will break the circuit to the button and then it should work normally. you can also tap on the button(just enough that it will click like tapping on a window) these should help you...please rate thanks
Sep 04, 2008 | Haier Heating & Cooling
Stuck print on HP Deskjet F380
Did you restart the computer? I know, a little obvious. But restarting should clear out the print queue.
I think what you're thinking of is typing services.msc at run. There you can stop the print spooler.
You can also get to 'services' by going to control panel > administrative options > services.
May 20, 2008 | HP Compaq dc5700 Microtower - Free Flat...
Pause mode stuck
Is the door firmly closed? Open the door and close it firmly. If the pause button is really stuck, you will need to repair/replace the board.
Oct 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Cursor disabled
Try going to control panel, then personalization, then mouse pointers. Under mouse properties, go to pointers and try to use windows black (system scheme). See if changing your mouse poiners makes it appear.
Sep 24, 2007 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Laptop Logo
230 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
