Question about Dell Vostro 1510 Laptop
Problem with my Dell vosro 1510 wireless
In my Dell quickset, radio control options, the WIFI catcher network locator is diactive and I can't enable the wireless network search.
In my Dell quickset, radio control options, the WIFI catcher network locator is diactive and I can't enable the wireless network search, How can I fix this Problem?
  • hhamzehh May 08, 2009
    my wifi led is turned on when installing wifi. but after complete instalation the led turn off for always. . .
    plz help me: hhamzehh@gmail.com
RESTART THE COMPUTER IN SAFE MODE AND ACTIVE THE LINE CARD
Posted on Apr 23, 2009
How to turn on my wireless card on my Dell 1545?
Have you just tried pressing the F2 button without pressing FN? The function of the button before pressing the FN is to enable/disable the wifi.
If the above method is not working...
Try this:
Click on start and type quickset in search box.Click on quickset icon from the search results.From quickset window check if wireless network shows connected or on.If this doesn't work click on start-all programs-DW WLAN card utility.Click on diagnostics and run it.Check if it finds any errors.
Aug 17, 2014 | Dell Inspiron Computers & Internet
How to connect wifi
yeerat,
The system has a wireless switch located on the front of the computer. The switch enables or disables the wireless antenna. Since the system does not have Quickset, there is no additional function for this switch. For information on setting up your wireless connection you can click the link below.
Dell Networking and Wireless Support Center
http://dell.to/1bhMlHP
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 27, 2014 | Dell VOSTRO 3500 Notebook
Bluetooth peripheral device driver
Sai Ch Krishna,
Depending on the system. The bluetooth would have to have been purchased at point of sale. The wireless and the bluetooth are turned on by a wireless switch on the side of the computer. If needed you can reinstall the drivers. Also, make sure bluetooth is turned on in the bios. Below is more information.
Wireless Switch
Wireless Technology The Latitude D630, D631, and D630c system ships with a wireless feature called the wireless switch. It is located on the left side of the system next to the IEEE 1394 connector. When used in combination with the Dell 38482; Quickset utilities, this switch enables or disables the wireless LAN, wireless WAN, and Bluetooth cards in the system or searches for all wireless networks in range.
To scan for a Wi-Fi wireless LAN, slide and hold the switch in the momentary position for a few seconds. The Wi-Fi Catcher network locator works whether the computer is turned on or off, in Hibernate mode, or in Standby mode, as long as the switch is configured through QuickSet or the BIOS to control Wi-Fi network connections.
Because the Wi-Fi Catcher network locator is disabled and not configured for use when the computer is shipped, it must be enabled and configured through the Dell QuickSet utilities to control Wi-Fi network connections.
Wireless Switch LED Settings
The LED on the wireless switch works even if the system is off. A user can activate the switch and have it scan for networks without going through a complete boot process. The switch can be set to detect for only certain wireless signals, such as WLAN only, WWAN only, Bluetooth only, or any combination of these. This is set in the BIOS under the Wireless section.
The LED indicates the presence of a network as follows:
  • Flashing green - The system is searching for a signal.
  • Green - The system has detected a wireless signal and has good strength.
  • Yellow - The system has detected a wireless signal, but it is moderate to weak in strength.
  • Red - The system failed to detect a wireless signal, or the wireless signal is extremely weak.
Thank You,
Dell-Jesse L
Aug 27, 2013 | Dell Computers & Internet
Dear sir, i can not see the wireless icon on my laptop
do you have the drivers for your wifi card installed properly. if not then go to manufactures website and download driver software for your wifi unit, are you using xp or vista? find device manager and see interfering hardware.
Dec 02, 2010 | Dell Vostro 1500 Notebook
I have switched over to the wirless modem (wifi) system. To activate this BSNL has asked me to switch on the wireless function key on which I am not able to trace out. Please help atonce. My laptop model...
There are 2 ways of which you can enable the wifi on your dell inspiron 1525:
1) Make sure the wifi catcher on the side is set to the "on" position, this can be achieved by sliding the little switch, so the line in the middle of the switch is aligned with the ' (a line) sign.
2) The next thing that you need to do is ensure that the wifi is enabled you can enable wifi by pressing "FN" (the key on the keyboard) and F2. N.B. This will only work if you have Dell quickset installed. An alternative way of doing this is by going to start > control panel > network connections, find the wifi adapter > right click > enable.
Hope this has helped slightly, add more info if it hasn't
Thanks for reading and good luck with your problem.
Good day
Nov 04, 2010 | Dell Inspiron 1525 Laptop
Hello, i got a dell inspiron E1505 ,which is showing that the radio it disabled thus i got no wireless connect.I would be happy if you can advice me on how to enable my radio
  • Double-click the "QS" icon in the system tray to launch the Dell QuickSet utility.
  • Click the "Radio Control Options" icon in the upper-left corner of the QuickSet window.
  • Click the "Advanced Settings" button and select the "Radio Control Options" tab at the top of the window.
  • Place a check next to the WiFi device and then click "OK." You should see the "WiFi" indicator light on the bezel above the keyboard turn on. If the indicator turns on, you should now be able to connect to a wireless access point. If you continue to experience a problem, continue to the next step to confirm that the adapter is enabled in the Windows XP Device Manager.
  • Click the "Start" button. Right-click the "My Computer" icon on the Start menu and select "Properties."
  • Select the "Hardware" tab at the top of the System Properties window and then click the "Device Manager" button.
  • Double-click the "Network Adapters" category.
  • Right-click the Device Manager entry for the WiFi adapter and select "Enable." You should now be able to connect to an access point.
Oct 24, 2010 | Dell Inspiron E1505 Notebook
How i turen on my wireless
here is the answer... (For Vista)
Go to the icon at the bottom right yellow/blue arrows (Dell Quickset) Open it.
Then go WiFi Catcher/radio controls (click it to open it).
Then go to "advanced settings" at the bottom of the pop up (open it - click it).
Then select the TAB "Radio Control Options"
Then UN-check all the radios and wifi, then apply, then OK. Your green bars should work now...
BEFORE DOING THIS CHECK YOUR WIRELESS SWITCH IS ON AT THE SIDE. AND THEN PRESS FN & F2 AT THE SAME TIME.
May 27, 2010 | Dell Inspiron 1525 Laptop
I have problem with my vostro 1510 wreless, by switching the wireless and bluetooth key on, only the blutooth devise is turn on.
The Dell QuickSet utility Wireless options can cause these issues.
There is a setting to always deactivate on battery. Make sure this is not set up. The correct setting would be Always active on battery or Always On, or no power saving options for Wi-Fi. Depending on the version of QuickSet which you have.
It is known to glitch when power is removed from the machine while the wireless is in use.
Please let us know if you have any futher questions. If this information was helpful, please take a moment to rate the solution. Thank you.
Apr 23, 2009 | Dell Vostro 1510 Laptop
How do I turn on wireless capabilities for a Dell Inspiron 1525?
On the right-hand side near the cd rom drive, there is a switch that moves back and forth. move it towards the back of the computer. that should turn on your wireless capabilities. A wi-fi manager screen should pop and and you should be good to go.
Jan 01, 2009 | Dell Inspiron 1525 Laptop
Dell Vostro 1510 Laptop Logo
560 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
