Question about GE JVM1660 Microwave Oven
Stovetop lamp sockets very brittle and are disintegrating.
Purchased new GE JMV1660 spacemaker m/w oven from hom depot April 2005. Both bulbs recently burned out. When I removed the original 40w bulbs the glass bulbs they simply twisted off, leaving the metal bases still screwed into the light sockets. The bakelite socket holder insulation crumbles to pieces from the slightest touch. I can remove the metal lamp base but the socket holder insulation is no longer there. Is it safe to replace the bulbs with the insulation missing?
Otherwise the unit has performed very well and is in excellent condition.
    President:
  • 1,489 Answers
In effect (given the unit is wired correctly) without insulation on the socket, you have an exposed neutral wire in your oven -- this is certainly not as dangerous as an exposed hot wire, but does present risks. I recommend replacing the light sockets -- you'll sleep and cook a lot better.
Posted on Apr 23, 2009
Surface Light Bulb burned out where can I purchase new one. Model ge #JVM230BL001 Spacemaker
most hardware stores/home centers carry them,you will need to unplug the unit and you should be able to access the lamp and unscrew it from inside the cooking chamber near the top of the cavity,you may need to remove a screw holding the cover first
Jun 25, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave lights flicker on then off
There must be a short in the wiring between the bulb sockets and the power supply or control board. Otherwise the short may be in the bulb sockets themselves.
I would test the connections to make sure the wires aren't loose and all solder joints are tight. If all wires look good, and bulb sockets are tight, then the problem may be faulty capacitor
Jul 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I need to find an incancent 40w 120v bulb for microwave
This is a common item. Take the bulb to a home depot and they will match it for you or direct you to a local source.
please mark my answer as a fixya!
Mar 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need new light bulb socket for GE spacemaker mircrowave
The bulbs are glued in at the factory. Unplug the microwave and see if you can remove the base of the bulb from the socket with needle nose pliers. You may have to twist the heck out of the bulb base but it should come out. If you do need a new socket it is available at www.geappliances.com under parts and accessories. Or call 1-800-626-2002 for GE factory parts
Dec 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave
maybe the problem is in the door latch switch try to replace the switch going to lights or bulb.
Jun 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Bulb replacement
WAIT!!! Before you just take the lamp cover off and try to replace the bulb that way, which would MAKE SENSE!!!, stop! All you'll do is snap the bulb off, leaving the metal screwy end of the bulb in the socket. Believe me - it happened to me. Twice.
The only way to ensure that you'll be able to get the entire bulb out, because the only way you can actually SEE what you're doing, is to remove the bottom cover of the microwave. It's about 6 screws along the underneath surface of the unit. After removing the screws, the front of the cover will hang down and the rear will stay nested in a groove at the back. At this point, you'll be able to see the backs of the light sockets. Remove the two screws on either side of the sockets, and you can gently pull the bulbs out of the housing so you can actually see and work with them.
Chances are, the bulbs have been GLUED into the sockets with silicone, which GE says it does to prevent moisture from getting into the sockets. Right. Then why is it that the replacement lamps work just fine without being glued in?! Anyway - GE actually instructs in the manual to "run a knife around the edge of the socket" to break the silicone seal. Hmmm..Sounds safe to me.
So, after you've eliminated the silicone one way or another, just gently unscrew the lamp like you would any other.
Trust me - you do not want to try to remove the lamps without removing the bottom cover. Oh, yeah - most importantly, unplug the microwave first! Good luck.
Jan 04, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Sockets for bulbs are cracked and shorting out
You should be able to take the screws out of the bottom plate and remove it. Then you should be able to get to where you need.
Oct 10, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave Surface Lights
The control circuits for the cooktop lights and the hood fan are spearate. The problem is indeed with the control unit. It's usually caused by either the filaments shorting when the lamp blows or by removing or installing the bulbs while the oven is still plugged into the power line. We regularly repair these nationwide for $32.50. Details of our service, as well as *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1660 Microwave Oven Logo
212 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
