Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Older oven stuck on Clean and door is locked.
We have an older Kenmore oven can't find the model number bt it is one where the burners are old school anyways we needed to clean the oven so we turned it on clean at 1pm this afternoon and the door has been locked, the clean light is on and it is really hot. Have tried unplugging the oven and tugging on door, flicking the fuse in the fuse box, turning it off and nothing works. Please help as I have 2 young children and the like to touch the oven door and I do like to cook.
  • moz205236 May 13, 2009
    Panel states door locked but it isn't. I think the latch is in the lock position but can't clear it. Unplugged to no avail. I'm going to run through the clean to see if at the end it will unlock automatically. Any other recommendations? I wasn't cleaning it I was cooking and opened then closed door to check food when this happened.
Does your oven have a lift up top if does. lift up burns and silver box open box and you can unlatch the lock. hope workds
Posted on May 13, 2009
How do I fix an oven lock on a self cleaning Kenmore built in dual ovens? The oven locked up during a clean oven cycle and will not unlock.
Some ovens will not open unless the clean button or knob is set to Clean. Make sure you are trying to open in correct direction. Try turning it on and off and press down on the latch while trying to open. I would not use a crow bar, this can be done. If you unplug it and wait for it to reset after about 30 seconds it might let go. Just keep playing mine stuck once and it was because I flipped the clean switch off an turning it back on ready to start the cycle pulled back on it and it opened. Oh I remember my neighbor had a older style dial clock and she set the clock for a certain time to stop and the door would not open until she ran the clock to that time spot. Hope this helps. I wish I knew how to open it from the electrical side but I dont.
Jan 30, 2015 | Kenmore Ovens
Where is the product number on Kenmore Oven?
open oven door should be right there
Oct 14, 2014 | Kenmore Ovens
How can we calibrate the oven temperature?
Older oven or newer oven? Old school ovens have a screw in the hollow stem yall can tweak. The new ovens have a themobilian_2771.jpgsensor.
If your oven has a sensor it should read around 1100 ohms at room tempt. If it is out of spec, shorted to frame or open then the fancy shocktronic oven control won't know what the oven temp is.
If you want a great answer post a make and model.
Aug 06, 2011 | Kenmore Ovens
I have an older model double oven by Kenmore - probably 15-18 years old. I was baking bread in foil three days ago and the oven set on bake 325 degrees. (I had been cooking a roast in it for several hours...
Hi.
the oven may have locked in consequence of the self cleaning cycle.
After unplugging, allow the oven cooling down for few hours.
If the is still locked, then the high temperature generated in self cleaning cycle may have damaged temp probe, door latch, or electronic control.
Parts must be tested to discover the fault.
Call Kenmore at the number listed on the owners manual.
Regards.
Mar 03, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore oven door will not unlock, it is an older model and i have lost the manual. i tried to activate the self clean but i couldn't remember how all that ended up happening is that the door has locked...
Look around the console area for a button that says push to unlock. If it is there push the button in while unlocking the door. Some models may require that you also place the stove into self clean then canceling it out thus enabling you to unlock the door. Without a model number off stove tho it is all just guess worjk as all stoves are not the same.
Feb 28, 2010 | Kenmore Ovens
I inherited an older Amana Gas oven that is self
Here is an older manual with instructions on self clean and everything else. Hope it helps!
http://shop.amana.com/assets/pdfs/literature/30946503.PDF
Jan 29, 2010 | Ovens
I HAVE AN OLDER MODEL KENMORE LIMITED EDITION STOVE/OVEN. I DON'T HAVE THE MODEL NUMBER OR OWNERS MANUAL. ANYWAY, I HAVE A PROBLEM, I TRIED TO USE THE OVEN BUT AFTER I SET IT " F5" COMES UP AND IT BEEPS...
you can get the model number and serial number from the oven, just open the oven drawal and get the number and call the customer service from where you got this oven from.
Dec 05, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Older Kenmore oven- door locked by itself
We had a quick power outage and when the power came back on it locked our older (1991) Kenmore electric oven model # 40889 / 40881. Went throought the manuel and nothing pertains to this problem. We have turned off the circuit breaker and turned back on, but nothing seems to unlock the door. Any suggestions would be GREAT!!!!!!!
Nov 21, 2008 | Ovens
wanna say you have a faulty latch/self clean assy. however the erc( lcdd panel could also send eratic power supply to latch mechanism)
Mar 09, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Tappan Electric Oven
I have a Tappan double oven range. An older model #316065301
How do I operate the cleaning cycle? I set the start and stop times, Locked the door and switched to clean. The clean light comes on but it doesn't heat up much at all. Never locks. I have misplaced my instructions manual.
Any help would be appreciated.
Barbara
blueznmooz@aol.com
Nov 19, 2007 | Tappan 30IN ELEC IGNa Oven
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
208 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
