I have a external 2.5 sata hard drive to usb 2.0 it use to should up and now when I plug it it says hard drive not recogize. Did I lose all my informatiuon or is there a fix.
  • 326 Answers
You can attempt to run a Command-line utility called CHKDSK. Check Disk will attempt to repair any misplaced or unreadable pieces of your hard-drive.
Two methods maybe required.
First running CHKDSK while in Windows:
Start > Run > Type "cmd" and hit enter.
Type N:\ (N is the drive letter assigned)
Type CHKDSK N:
If your drive is no longer receiving a drive letter it may be required that you attempt to mount the drive in an external OS, such as BackTrack3.
BackTrack is a free Live OS, Meaning it boot's and runs off of a CD. Simply download and burn the ISO (Disk Image) and then when booting your computer follow the instructions on your screen for your Boot Options Menu and Select Boot From CD.
Once booted, Plug in your drive and BT should recognize it. If it can be recognized, you will be able to attempt to repair, or at the least should be able to bring your data over.
***In the event that your drive is physically failing, and to be safe, please prioritize what your going to attempt to save before attempting this and work as quickly as possible.
Get BackTrack3 here:
http://www.remote-exploit.org/cgi-bin/fileget?version=bt3-cd
While the BT method may seem like a long and tedious process, its important to note that aside from actually replacing the electronics inside your drive, this is about the only way you can get your data back.
I wish you the best in this endeavor.
If you have any questions please let us know. If this information was helpful to you, please take a moment to rate the solution. Thank you.
Posted on Apr 23, 2009
Wd50000aakb make into a external usb
USB 2.0 To SATA IDE 3.5 2.5 Hard Drive with an Adapter Cable http://www.youtube.com/watch?v=iE8t5IGr0e4
http://www.ebay.com.au/itm/USB-2-0-to-SATA-IDE-2-5-3-5-Hard-Drive-HDD-Adapter-/330612048804?pt=AU_Laptop_Accessories&hash=item4cfa0383a4
USB 2.0 to SATA IDE 2.5 3.5 Hard Drive HDD Adapter Kit
AU $8.10 free postage worldwide
You would have to remove the hard drive and use a usb sata ide kit
you will then have to connect it to your computer using a usb port
Aug 13, 2013 | Western Digital Caviar SE16 WD5000AAKB -...
My samsung sata hard disk HM120JI is not working fine. Windows is not coming up. I have replaced the hard disk and now want to copy data from samsung sata disk to the new disk. Could you please tell me how...
You can buy a SATA dongle that plugs in to the hard drive and plugs into the USB port on you computer $20 or buy a external SATA case to put the hard drive in $40 at most computer retailers.
Feb 06, 2011 | Samsung SpinPoint M60 HM120JI 120 GB SATA...
I have one hard disk. model number MHK2120AT. i need to make this hard disk as external is that possible
Yes, thats possible, you will need an external usb enclosure such as the one here:
http://cgi.ebay.com/NEW-2-5-SATA-Laptop-Hard-Drive-USB-External-Enclosure-/390241288440?pt=PCC_Drives_Storage_Internal&hash=item5adc3180f8
When you get it, the drive will go in it and then you can plug it in via your USB port on your desktop/laptop.
Regards,
Brandon
Computer Bytes
Dec 10, 2010 | Fujitsu Mobile MHK2120AT 12 GB Hard Drive
MHK2120AT Model number i want to use this hard disk as an external drive
Regards,
Brandon
Computer Bytes
How to install 2 t hard drive in computer compaq
A 2Tb hard disk will be a SATA hard drive. If your PC Desktop does not have a SATA disk controller then your have a couple of options.
1. Insert a SATA controller card into the PCI expansion slot, mount the SATA hard drive inside the PC case and then connect the SATA hard drive to the controller (you will also need a 4 pin power to SATA adapter cable) and install the SATA controller driver.
2. The other option (and the easiest) is to purchase an external USB 2Tb hard drive. All you need to do is, plug it into the USB port of your computer and it will see it as an external storage device.
Oct 22, 2010 | Computers & Internet
External to internal with sata plug
It will be a setting in the BIOS to enable SATA hard drives after you select it will give it a drive letter and show on computer. Cheers from Scott and please dont forget to vote
Jul 17, 2010 | Western Digital My Book Essential 1TB...
Cannot power on Seagate Freeagent Desk external hard drive
Hope this has only been used for backups, and not as a primary storage. The best way to trouble shoot something like this is to purchase a USB/SATA adapter. You will need to dissemble the device and take out the hard drive. Connect it to the USB/SATA adapter to see if the drive spins up and can be seen by the PC. This will let you know if the drive is OK and whether the fault is related to the external bay electrices or the drive itself.
Good luck, you can get the USB/SATA devices quite cheap off of eBay.
Cheers,
Ripface.
Sep 27, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate 50gb external drive - not recog on computer
It could be your USB or firewire. i had a problem with my h drive and now i'm using a ps3 usb cable instead
Sep 10, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How does a external USB SATA drive dock
yes you can but whether that would make it work or not is a different story.
It depends if the hard drive is still working or not however it would test for certain whether it is working or not.
Apr 14, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
External hardrive problem
try do access it with a version of linux. linux is a free operating system.
Aug 04, 2008 | SimpleTech SimpleDrive Portable USB 2.0...
Computers & Internet Logo
141 people viewed this question
David Payne
David Payne
