I have a samsung dvd\vcr player. The dvd no longer works. Can I connect a outside dvd unit to the combo. I can't seem to get it to work. Combo is a Samsung and outside unit is a magnavox.
In short, no. Not with this unit on its own. No function for recording from or copying to DVDs exists with this brand/model.
A separate DVD recorder is required. I don't know of anyone who records DVDs to tape these days.
You are correct; the manual states clearly you cannot record from the DVD deck in this machine, which is a bit unusual, considering other brands of combos such as LG, SONY and PANASONIC offered an input (which was between channels or could be selected via remote) to allow DVD to VHS recording within the one unit.
I would presume you can connect this combo to the input of a DVD recorder, play a videotape and it will work via cables. DVDs last longer than tapes anyway.
On these combo units, the VCR will not play using component cables but the dvd's will play just fine.
What you need to do is run a pair of composite (Yellow, red and white) cables and use that for VCR and component (Green, blue, red, white and red) for the dvd player.
Make sure you switch the tv to the corresponding input.
On a DVD/VCR combo unit....the Component Output (RED, GREEN, BLUE) is exclusive to the DVD player section only (VCR can only output analogue source) and will only be able to view DVD.
To watch VCR, you will need to connect to your TV via Composite (YELLOW) cable, into the Yellow AV input on your TV. You can then tune the VCR section to match your TV's RF input (if you prefer this connection).
Good luck...
"if this has helped you, please rate this solution"
We also don't have a remote. We hooked a DVD/VCR combo to the Samsung combo by attaching the cable from the cable line to the DVD player and an additional cable from DVD to TV and it used to work but after we lost the control, the DVD can only be listened to but not seen. The VHS from the DVD player works perfectly though.
When we had the remote (before connecting the other combo) we used line-in to see a DVD or VHS using the yellow red and white cables from the Samsung to the other player.
