The ink is not flowing in my cis epson c90, what will i do?
  • 5,660 Answers
Epson c90 turned off, and unplugged from electricity.
I suggest you use a warm water, damp, clean, lint free cloth, and wipe the ink cartridge contact area.
Generally, but Not always, where you see the brass metal thin plate, is where the tiny holes are, for the ink to come out. Where you took the protective plastic strip, off of the ink cartridge, is where the holes are located.
I would use as warm a water as I could stand, as the damp cloth will cool off quickly.
I believe what has transpired, is that the tiny, little holes that the ink comes out of, has dried ink in them.
You may want to use a pair of dishwashing gloves. Helps to keep any ink from getting on your hands.
Also, where the holes in the ink cartridge, line up in the printer, I would suggest cleaning these.
On both areas, just wipe in one direction. If you see ink on the cloth, go to a clean place, and wipe again.
Once, you are satisfied these areas with the holes are clean, leave the printer open, and the ink cartridge sitting out.
You may want to use a hair dryer set on low, to help dry out the printer area. Keep the hair dryer moving back and forth, and not concentrated on one area, and don't hold it too close. Perhaps one finger length away.
I Do Not suggest, using this on the ink cartridge, however. Perhaps a clean, dry, lint free cloth, and letting it sit out to dry.
When you are satisfied both the printer, and the ink cartridge areas are dry, reinstall the ink cartridge. Close the printer, Plug the printer back into power. Wait ,to see if the printer has to set it self back up.
(Some do when plugged back into electricity, some only do this when the Power On button is pushed)
Push the Power On button in.
I suggest you do a diagnostic test, and print a test paper, after aligning the heads.
Start>Hover you mouse cursor on All Programs>Epson>Epson Help, will tell you how to do this.
Posted on Apr 23, 2009
GIVE ME RESET KEY FOR EPSON L200
download l200 restter & run it for waste ink pad reset & use only epson geniun ink for noworry
Sep 13, 2013 | Epson L200 Original Continuous Ink Tank...
My epson stylus C90 will not print, red light and green light bling on/off continuously
YOU NEED TO DISABLE THE INK LEVEL MONITORS AFTER RE-FILLING THE CARTRIDGES. GO TO PROPERTIES, MAINTENANCE, VIEW PRINTER STATUS, OPTION AND CLICK ENABLE STATUS MONITOR ONCE.
Jan 16, 2010 | Epson Stylus C86 InkJet Printer
Parts inside your printer are near the end of their service life.
if you put this in google ssc download it and this will reset your printer hope this helps
Feb 26, 2009 | Epson Office Equipment & Supplies
i have a problem with my printer epson stylus C90. may i know what to do when parts of my printer are near the end of their life service.? how can i fix it?
Dec 07, 2008 | Epson Stylus Photo R300 InkJet Printer
I dont know how...
Unraqr the c90.rar file and copy the extraction to any folder on your hard disk (for future frequent use).
The following only works after refilling the cartridges or using a continuous ink system.
Note: This is for the Epson C90; there are a lot more printer specific resetters. Mine is Indonesian.
Note: This does NOT work if the system date is NOT set at July 15, 2007 !!
1. Set the system date to July 15, 2007.
2. Go to MY COMPUTER, open local disk C: then delete the ADJUSTMENT PROGRAM FOLDER (if present)
3. Close local disk
4. Click START, RUN, type REGEDIT
4. Open HKEY LOCAL MACHINE
5. Open Software folder
6. Open Epson folder
7. Delete PTSG folder (right click, remove=yes)
8. Open Epson C90 Resetter folder and start adjprog
9. Click ACCEPT button
10. Click SELECT button to go to port menu. Selected designated port number (USB ...)
11. Click the "Particular Adjustment Mode" button
12. Double click the "Waste Ink pad Counter"
13. Click the "Check" button
14. Click the "Initialization" button.
15. Turn of the printer and press "OK"
16. Turn on the printer and wait until the maintenance procedure has finished
17. Close the panels of the Adjustment program
18. Reset the date to the current date.
Note: Print these steps for future use.
Note: With a continuous ink system, make sure that the ink filling cable is not to tight; the print head with the attached ink
cabling must be able to freely move all the way to the left inside the printer. Also make sure that none of the ink tubes is squeezed tight by the black plastic clamps that are used to attach the system to the outside (front) of your C90. Place them so that the transparent cover stays slightly open.
Note: With a continuous ink system, be sure to use the "lock roller" on the ink system to close the ink supply when the printer is not in use; otherwise your ink evaporates.
Note: The continuous ink system is quite erratic in its signalling: when one of the colors is about 1/3 full on the Epson monitor, the printer might stop suddenly and display the cartridge X signal. Sometimes, with 2 colors X-ed, you have to do the procedure twice!
I don't know where you got the C90.rar download. You must have the following files:
AdjProg.exe
Apdadrv.dll
EditText.dat
StrGene.dll
If you don't have them all or miss some, pls e-mail me (hanshufkens@yahoo.com) and I'll sent them to you (attachment is about 2 MB)
Last: The C90 is a **** printer. After 4 months of use the paper adjustment goes to hell, so with printing you never know if printing will start before the paper is properly loaded. Might as well buy a new printer (NOT Epson!).
Jul 23, 2008 | Epson AcuLaser C900 Printer
Waste ink pad counter reset software.
Dear Sir,
My Epson R30 Photo Printer has a problem from Waste Inkpad Full massage and it's not working. I want a free software to download to reset my printer and I tried in SSC Service Utility v4.30 but software don't have R390 model so, please help me to find right software to reset my printer. Thank you.
mallajanak@yahoo.com
Jun 14, 2008 | Office Equipment & Supplies
Waste ink pad
to Reset Waste Ink Counter
  • RUN AdjProg.exe file Epson C90
  • choose Particular adjustment mode
  • select waste Ink pad counter
  • Klikinitialization
That’ all!
Jun 01, 2008 | Epson AcuLaser C900 Printer
Compatible ink
yes i have a epson rx560 i brought a contiouous ink system the thing you must watch out for when buying copy ink is that they work with all modles or rx560 as some ink will only work befor printer made before 1 march 2007 and some will only work after made 2007
but the continuous ink system will work wit all models i can get cis for £45 plus postage and come with 6 x 100 ml ink contact me if your intreasted
Oct 11, 2007 | Epson Printer
Epson cx2900 3 in 1 printer
the problem might be the ink, change the cartridge maybe the ink dried out....
Sep 05, 2007 | Epson Stylus C84 InkJet Printer
150 people viewed this question
k24674
jasbo
jasbo
