The washer spin cyle is stopping and when the door is opened and closed it starts to spin again. there is a rod attached to the door that makes and breaks a mirco switch when opened and closed, located on the left side of door. I suspect the problem to be the switch. If you agree, My problem is I don't know how to get to it. Help
  • blueextc3221
    blueextc3221 May 11, 2010
    reply with the make & model # so we can help further.
    President:
  • 1,489 Answers
This machine is operating properly. All washers are designed to stop spinning when the door/lid is open -- it's a required safety feature.
Posted on Apr 23, 2009
What happens when machine stops half way through cycle water emptied out and will not work on spin cycle either
This will happen if the little rod that slides into the opening on top of the washer when the cover is closed has broken off. Look at the bottom left corner of the cover when it's open, and see if the little rod is still intact. If it's broken off, you'll need to contact the manufacturer and get a replacement.
If it's not the plunger for the closed lid switch, it's most likely something that will need to be serviced by an appliance repairman.
May 07, 2015 | Indesit Washing Machines
LSR5232LQ1 Whirlpool washer Will try to spin but can't
Does it spin at all ?
If not, trying looking under the door. there is a switch that often breaks off that will not allow the spin cycle to run if the door is closed - you know when you look in your washer when its spinning and as soon as you open the door the spin cycle stops unil you close the door again ? that's the switch.
worth a try. costs about $3.00 for the switch & can put it in with a srew driver.
good luck - aloha
Feb 13, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Frigidaire front loading washer stopped at rinse cycle. 3 beeps
When in doubt check the easiest thing to check. The pump can cause a number of errors to come up. Since the unit stopped in rinse I would start but checking to make sure there is nothing obstructing the pump before going to the expensive parts.
Feb 22, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Front Load Washer
It looks like the door switch was not making because the door is defective. Also the switch may just be bad.
Mar 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Fill, Agitate, then nothing
There is a door activated switch that might not be working. It you look under the door lid you will see a plastic rod which goes into a hole on the base of the top ring. Make sure that this rod is depressing the switch when the door closes, and if possible see if the switch circut closes.
Jan 27, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Door will not open
On my machine which is identical to this one I have to press and hold the stop button to end the programme and then turn off and unplug the machine to reset it. Following this run a spin only cyle(M) to get rid of the water.
Once the machine has drained and ended the M cycle try the door again. If this fails unplug the machine wait for a few seconds and then plug it in again and turn the program knob to any programme but do not start it running, just try the door it should open.
If all this fails it may be a problem with the contacts for the electrical stage of the door release or a faulty door lock.
Good luck, Al
Nov 08, 2007 | Hotpoint First Edition WMA22 Front Load...
Washing machine stops mid cylcle
try pushing the door closed again, i have a problem with my machine that when i put a load on it starts then stops the light starts flashing then i firmly push the door (at the handle side) and it starts to work again, it might help!
May 10, 2007 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
