Question about LG Refrigerators
LG Refrigerator LFX25960ST Dispenser Panel
Http://i208.photobucket.com/albums/bb189/ccunni3812/Untitled-8.jpg
When I removed the dispenser panel from fridge I broke the bottom clips that lock the dispenser panel to the fridge.  On the link above, the image you see LFX25960ST refrigerator dispenser and the items circled in red is the location I'm referring too.. Do you have any recomendations or tips to fix the dispenser? I just want it to mount correctly to the refrigerator.
  • Seabiscuit
    Seabiscuit Apr 23, 2009
    Thank you!!!!
    President:
  • 1,489 Answers
Here are four ways to reattach the panel:
- Put a short stainless steel screw in each of the two lower corners of the panel. Drill a hole in the panel first -- the hole should be bigger than the diameter of the screw. Next, with the panel in place, carefully drill thru these holes, into the door, a hole smaller than the diameter of the screw. Then screw the panel back on.
- Or, put thick double stick tape along the bottom of the opening for the panel. Two short pieces would be preferable -- this would make it easier to remove.
- Or, if there is enough PVC in the plastic panel, PVC pipe solvent may allow you to refasten the broken clips to the panel. (This is available at hardware stores -- you may want to use PVC primer as well -- but be very careful, the primer is purple, very "thin", and will run -- it will stain everything it touches. If the panel is not PVC, this solution will not work.
- Or, 5-minute epoxy may hold the broken clips to the panel (make sure the epoxy is thouroughly mixed).
Posted on Apr 23, 2009
  • Samuel Charles Spriggs Apr 23, 2009
    You are very welcome!
    Here's some additonal info:
    If you use the screw approach, they shoud have sheet metal or wood-screw threads. If you want to balance the look of the panel, you could also put two more screws at the top of the panel.
    If you use the epoxy approach, make sure you coat the clips thouroughly. The epoxy most likely won't hold if you just put it on the joint where the two broken pieces come toghether.
    If this solved your problem, could you please respond accordingly to the Fixya questionnaire.
    thanks...
    Charlie
Trouble shooting LG french door ice dispenser
LG French Door Refrigerator - In Door Ice Maker Troubleshoot
? 4:41
https://www.youtube.com/watch?v=rA1DhfTwuwM
Feb 4, 2013 - Uploaded by ExperienceLG
Ice makers are great, but not if it means you can't fit all of your food in the fridge. The Slim SpacePlus Ice ...
LG fridge ice maker troubleshoot/ repair. How to fix ice ...
? 8:06
https://www.youtube.com/watch?v=arJpFgMnvPY
May 19, 2013 - Uploaded by spartacus1234567890
The ice maker quit working in my LG refrigerator so I decided to take it apart ... LG French Door Refrigerator - In Door Ice Maker Troubleshoot ...
LG Refrigerator Ice Maker Not Working - Model LFX25960ST
www.repairclinic.com/RepairHelp/...Fix...-/LG-Refrigerator-ice-maker-n...
LG Refrigerator Ice Maker Not Working. LFX25960ST. The part(s) or condition(s) listed below for the symptom Refrigerator ice maker not working are ordered ...
Jan 05, 2016 | LG LMX28988ST Refrigeration : Refrigerator...
Tip
How to Rejuvinate Your Motorbike Leathers
So here's how to. Its actually real simple but can be time consuming if doing a colour change.
Can be used for your old faded set, ones you've had a slide in or even if your looking for a colour change.
[B]1.[/B] Go to any shoe repair shop that sells Leather spray dye's in lots of colors.
[B]2.[/B] Also you need the leather deglazer.
[B]3.[/B] Prep leathers, clean, dry and deglaze the area you want to color.
[B]4.[/B] Mask the area you want to color , this is what is time consuming. it gets real messy.
[B]Pic of lowside damage[/B]
[IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/1-5.jpg[/IMG]
[B]5.[/B] Apply dye roughly 4 or 5 coats (if changing colours, less if just touching up). This takes awhile cuz it take long to dry inbetween coats and work on one area at a time.
[B]Pic of Repair (still fresh)[/B]
[IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/2-4.jpg[/IMG]
[B]6.[/B] When all finished let the Leathers sit to fully dry and cure for 4 days to a week if possible.
[B]And now for the all important pics.
This is what the suit looked like before
[IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/3-3.jpg[/IMG]
[IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/4-4.jpg[/IMG]
[B]And after the new colour scheme:[/B]
[IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/5-5.jpg[/IMG]
[IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/8-1.jpg[/IMG]
[IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/7-2.jpg[/IMG]
[IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/6-2.jpg[/IMG]
[B]Some close ups:[/B]
[IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/9-1.jpg[/IMG]
[IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/13-1.jpg[/IMG]
[IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/12-1.jpg[/IMG]
[IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/11-2.jpg[/IMG]
[IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/10-1.jpg[/IMG]
[IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/15-1.jpg[/IMG]
on Apr 27, 2010 | Motorcycles
Tip
IPod Shuffle 2nd & 3rd gen Sync cable
save up to $50, make a sync cable for ipod shuffle 2nd gen and 3rd gen on your own,
all you need is a 4 poles 3.5 mm jack, and USB plug. you get this on an old USB connectors ,
the color coding of USB cables is in standard so all you have to do is to solder the color coded wire to the 3.5 mm jack
here are the links of pictures of wire color coding that tells where the wire shouuld be solder http://i863.photobucket.com/albums/ab192/matrix_jc2001/Untitled-1.jpg
on Dec 31, 2009 | Audio Players & Recorders
M1195c going to sleep
Customize Power Plan To access your Windows 7 power management plan, go to > Start and type > power options in the search field. Under > Control Panel pick the top result, i.e. > Power Options. Please see links for illustrations http://i1157.photobucket.com/albums/p585/mritsurgeon/84112902.jpg http://i1157.photobucket.com/albums/p585/mritsurgeon/9e0706d8.jpg http://i1157.photobucket.com/albums/p585/mritsurgeon/59586efc.jpg http://i1157.photobucket.com/albums/p585/mritsurgeon/ba8a87aa.jpg
May 18, 2012 | HP Media Center m1195c (PJ475AA) PC...
Http://i632.photobucket.com/albums/uu42/edgaaaFSHO/Picture017.jpg http://i632.photobucket.com/albums/uu42/edgaaaFSHO/Picture018.jpg http://i632.photobucket.com/albums/uu42/edgaaaFSHO/Picture019.jpg...
check to see if you have a trojan   use unhackme to remove it   you can find unhackme on torrents  or go to filetopia (a peer to peer software)  and go to the All Good Things room   I'm The_MacGyver
Nov 06, 2009 | Samsung SlimFit TX-S3082WH 30" TV
Want to install a fusion f 2000 car alarm system into a 1990 toyota celica gt 4 but ive lost the wiring diagram. any help? or instruction?
heres some links to the wiring info you requested
http://img.photobucket.com/albums/v249/2fas4u/f2004.jpg
http://img.photobucket.com/albums/v249/2fas4u/f2003.jpg
http://img.photobucket.com/albums/v249/2fas4u/f2002.jpg
http://img.photobucket.com/albums/v249/2fas4u/f2000.jpg
heres the wiring info for your car also. as always, double check with a DDM before connecting
Battery WHITE (+) IGNITION SWITCH HARNESS ico_question_mark.gif Ignition 1 BLUE/RED (+) IGNITION SWITCH HARNESS ico_question_mark.gif Starter 1 BLACK/WHITE (+) IGNITION SWITCH HARNESS ico_question_mark.gif All Door Trigger RED/WHITE (-) DRIVER'S KICK PANEL ico_question_mark.gif Trunk Trigger RED/WHITE (-) AT TRUNK LIGHT "HB WORKS WITH DOME LIGHT ico_question_mark.gif Hood Trigger N/A ico_question_mark.gif Alarm Disarm N/A ico_question_mark.gif Parking Lights DARK GREEN (+) DRIVER'S KICK PANEL
hope that helps:D
Sep 15, 2009 | Vehicle Parts & Accessories
Water is slowly trickling out of water dispenser
This is usually because the water filter on the supply line needs replacing.
If it has not been replaced within 6 months, then this will probably cure it.
Thank you for using Fixya,com
Aug 05, 2009 | LG LFX25960ST Stainless Steel French Door...
My HE Washer is leaking - Adjust Water Pressure?
The dispenser is likely clogged with soap scum. Pull it and clean the orifices.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Maytag MAH2400A Front Load Washer
Refrigerators Logo
205 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
