Question about Kenwood Audio Players & Recorders
Stereo cassette receiver--hums
Have a Kenwood KRX 891 stereo cassette receiver (manufactured as tuner, cassette, amplifier connected together) Has not been abused. There is a fairly loud hum in it---no matter which unit you are using, even the separate CD player. We have tried different speakers, different cords, turning up the volume, disconnecting the external antenna and nothing works. Pretty dry here so don't think it can be humidity. Any ideas??
    Top Expert:
  • Kenwood Master
  • 43,997 Answers
There could be an open filter capacitor in the power supply.
Posted on Jul 13, 2017
hardrocko
  • 1476 Answers
SOURCE: My Emerson NR305TT will not produce sound
You have one of 3 problems:1) bad solder joints in the amplifier or preamp section 2)defective output transistors/ICs in the power amp or 3)missing or incorrect voltages to the amp section. If the unit has a headphone jack plug in a headset. If you have sound then everything is OK thru the preamp section and your problem is in the power amp. Any competent repair shop should be able to solve this one easily.
Posted on Jun 23, 2006
robotek
  • 1512 Answers
SOURCE: Kenwood Amp blinking Standby indicator light
Hi fuxsiloh.
It sounds like you have eliminated all the things that could generate this symptom that are external to the amp. It is most likely that there is an internal problem that is causing the amp to go to protection mode. A power supply failure(maybe a fuse) is the only really user serviceable part inside the amp. Perhaps check for failed fuses, replacing any that may have blown with exactly the same type. BE SURE TO UNPLUG AT THE WALL FIRST:)
Is the amp still under warranty? If so, then returning it to a Kenwood service center is the shot. If you want to have a go at repairing it, I can talk you through it, but some experience with this sort of thing is very necessary. Good luck
regards
Graeme
Posted on Apr 06, 2008
SOURCE: Technics ST-X302L tuner - Unit not powering on
i have the same unit and a similar problem, after a fall of the tuner on the floor while i was cleaning my room, first times the st-x302l was powering fine but after some minuts it quit alone.. now (i dont know why) it remains on but if there is an interruption of electricity it dont turn on anymore, it turn on only by removing the metal chassis and moving random the electronics.. i think it has some electronic contact or circuit break.. i brought it to a specialist in electronics and he told me the reparation would be too expensive so i prefer to try fix it by myself.
Posted on Apr 10, 2008
djchillsnyc
  • 152 Answers
SOURCE: Loud humming noise from new hdtv
hello, the speakers are fualty or have a shorted connection if they came with the tv contac your seller and arrange for a replacement imediately dont wait. since they are giving you feedback dont use them they may cuase other fualts in your tv, any component thats cuases hum or noise when pluged into the tv should not be used at all.
one important thing is to have a grounded plug this also may cuase fualts down the line,
if posible get a power line conditioner or ups (uniteruptable power supply)
flat panels are very over protective you dont want the tv to start blinking. since flat panels have built in protection circuts any slight short or fualt may cuase the wide screen to go into circut shutdown mode and this will cost you more if the speakers create a short in your audio circut it may damage your widescreen internal boards and cuase a system shutdown circut (red light flashing no picture)
contac your sellers site let them know your speaker are cuasing a loud hum
and that you will need the speakers replaced these are definitely fualty
if you dont have any coverage or you got the set as is then dont take any chances use other speakers.
if you are electronically inclined you can open these up and find out whats wrong with them internaly it may be a loose connection, since opening up the equipment may void your warantee contac the store first see what they say..
good luck happy holidays
Posted on Dec 11, 2008
  • 5 Answers
SOURCE: loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Posted on Dec 16, 2008
I have a Kenwood krx-89 standby light on please help
Krx-89 stand by light wont turn off - Fixya
www.fixya.com/support/t14712608-krx_89_stand_light_wont_turn_off
Oct 20, 2012 - krx-89 stand by light wont turn off Stero doenst play is it because thestand by light is on? How do i turn off - Kenwood Audio & Video Receivers ...
How do you turn off standby on a kenwood krx-89 stereo ...
www.fixya.com/.../t15447523-turn_off_standby_kenwood_krx_89_ster...
Dec 20, 2012 - Hi, is the red light that says power On? If not, it could just be the fuse since I had the same problem. If you take the lid off, it should be in the left ...
Read - Document Download
Dec 14, 2015 | Kenwood Audio Players & Recorders
I have a 1987 model kenwood home stereo system ihave a graphic equalizer ge 76 control amplifier kc206 synthesizer tuner kt76 power amp km206 how does the RCA connections hook up which ones go to...
First connect all sources like tuner, cassette player, Cd player into the proper RCA inputs of the control amp, then connect the output of the control amp into the input of the equalizer. Then connect the output of the equalizer into the input of the amplifier. This is how to get the best performance and proper outputs to all the right equipment. The speaker outputs of the amplifier would then go to the speakers.
Let me know if you need more help from me by addressing your post to me, or if you wish to communicate with another expert you can address your post to them I.E. @tech48 or @whoever
Thanks and good luck,
Dave
Sep 27, 2008 | Kenwood Audio Players & Recorders
Do all Kenwood Home stereos have fuses?
yes there are fuses. usually they are glass fuses near the power input on the board inside the unit. but you could also have fried or corrosion damaged other electronics if you have dropped water inside it
Nov 24, 2013 | Car Audio & Video
Hi, is the red light that says power On? If not, it could just be the fuse since I had the same problem. If you take the lid off, it should be in the left rear and is a 250v 6amp fuse. I had the same problem where only the standby light and the input lights were on. Neither the radio and cassette lights were on.
Dec 20, 2012 | Kenwood Audio Players & Recorders
I just got a Kenwood system, i would like to know how to hook it up, it has, Kenwood power amplifier km207, kenwood stereo control amplifier kc 207, disc player dp-m 97, cassette deck ky-77 cw, stereo...
That's a pretty standard setup. RCA cables from the KM207 to the preamp (KC207), and RCA cables from all of the other components into the KC207. Speakers connect into the KM207
Nov 01, 2012 | Master DE Kenwood with Housing...
I have an old kenwood stereo system I forgot how to hook up it is a ka-87 amplifier a kt-57 tuner and a double deck cassette player kx-57w .Can anyone help?
Connect the RCA Outputs of the Tuner to the RCA inputs for Tuner on the amp.
Connect the output of the Tape Deck to the Tape Input on the amp.
Connect the input of the Tape Deck to the Tape Output on the amp.
Select Tuner on the amp to listen to the tuner.
Select tape Monitor to hear the Tape Deck(s).
Dec 30, 2010 | Audio Players & Recorders
Kenwood Stereo
I presume you realize none of these things produces speaker amplification. A receiver would do that and facilitate graceful and simultaneous interconnections. But it's not a necessity for selective interconnective between them, just not all at the same time.
I can't find any details on anything you named except the Tuner.
Typically, the tuner would use an RCA pair to go to a receiver AUX, TUNER or other Line Level input for source selection and amplification. Lacking a receiver, run it to the Tape Deck inputs for recording.
Ditto for the CD changer, but you'll probably have to disconnect the tuner.
Jan 26, 2010 | Audio Players & Recorders
I HAVE A OLDER KENWOOD STACK HOME STEREO SYSTEM WITH OUT MANUALS OR REMOTES AND NEED TO KNOW HOW TO HOOK ALL THE COMPONENTS TOGETHER. KC-206 STEREO CONTROL AMP KT-76 TUNER KX-96W CASSETTE DECK KM-106...
start with the tuner, hook up the equalizer to the tuner, then on the rear of the equilizer hook up all the peripherals except the amps which will go to the tuner outputs and all will feed thru the tuner to the amps and out to the speakers
Oct 23, 2009 | Audio Players & Recorders
Need an owners manual for a kenwood amp
HI...
try www.hifiengine.com ...those are free
or Rick at www.stereomanuals.com
Please rate my help if you can.
Thanks
Feb 21, 2009 | Audio Players & Recorders
145 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
