Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron TV Snow
I have a Sony Trinitron TV which is hooked up to the cable outlet in the wall. Almost daily, the TV sputters and then goes completely to snow. The only thing that will correct the problem, I found out accidentally, is when I push the "demo" button, which shows many of the features on the TV. It'll run through the demo a few times, for as much as 10 minutes, then the TV will be fine. Sometimes it will go out again, but usually not until I've turned it off for a few hours (like overnight). Lately, it's taking longer and longer for this recovery process and it is a 37 inch TV and unbelieveably heavy, which is why I haven't taken it in to be repaired yet. Anyone have any experience with this or have any advice?
  • Black Paw Apr 18, 2008
    Is there a reset buttom on the Trintron 32.
I found out accidentally, is when I push the "demo" button, which shows many of the features on the TV. It'll run through the demo a few times, for as much as 10 minutes, then the TV will be fine. as you are getting fine picture on demo it indicates that your tv is perfectly ok. problem is out side of tv 1 check cable connection for loose or its socket is loose. 2 wire might be old or defective. 3 check tunning is done properly 4 if every thing is fine then check for tuner in your tv. good luck
Posted on Sep 24, 2007
SOURCE:
Here's my suggestion , unhook all the external components to the TV and leave the TV unplugged for more than a few minutes (a day/overnight). The next day plug the TV into the wall outlet (not the powerstrip) without anything hooked up to it, and turn it on. See if it comes on. Sometimes unplugging for a few minutes/hours is not long enough for it to reset itself.
Dec 28, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony trinitron tube tv Standby is flashing and the tv wont turn on
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 06, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony tv power drop
Jun 13, 2010 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Sony tv kv-20fv 300 power light just blinks
Apr 25, 2010 | Sony FD Trinitron WEGA KV-20FV300 20" TV
I have a comcast digital converter box and i need the manual to hook it up to a tv
Here is the easiest way...
1. Connect coax cable from the wall to the "Cable in" on the cable box.
2. Connect a coax cable from the back of the TV to the "To TV" output on the back of the cable box.
3. Tune your TV to channel 3
4. Plug the power cord into the back of the cable box and into a power outlet.
5. If you do not have a picture call Comcast and ask them to send a signal to activate your new box.
6. Enjoy your new programming.....
Good Luck...
Jan 03, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
KV35540 Sony Trinitron
pls check the antina or the cable line or the cable plug or call the tech.
in the tv tunner foulty
Jun 07, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Moved tv from 1 location to another
hi there, it may need some fine tune for the sony kv-27fs12 to be connected directly to cable jack wall. do some test. ty
Jan 10, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
"No signal"
It could be a bad barrel at he TV and at the wall. Your cables and connector could be of poor quality. You may also have a signal issue. Has anyone fron the cable company be out to take a signal reading?
Nov 09, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
"No Signal"
Might need a tuner, I suspect if you arent seeing any snow/static you probably need to press the tv/video button untill you get the ANT input.
Jul 31, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
155 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
