Question about Compaq Armada M700 Notebook
COMPAQ V5000 FAILURE
Today morning as soon as i started the laptop, the power on light came & after a minute while booting the there were three long beeps heard from the laptop & the screen became dark. the power on indicator started blinking . repeated off & on had not proved any result.
  • dukesonu Sep 26, 2008
    hi i hav v5000 series v5207tu model laptop i was using it in the past night perfectly but on this morning when i tryied 2 start it,it failed power indicator orange colour light is blinking constantaly and screen is black even charging indicitor is not showing some times processor lights come on and some times not even i checked the charger its ok,i haved removed the battery and reinstalled it even press power button 4 60 seconds with out battery and charger abd tryied to restart but it all failed plz help!
    Brigadier General:
  • 6,966 Answers
Hi, Try re-seating your memories. They may be located at the bottom of your laptop covered by a lid or panel held by a screw or 2. Once the memories are exposed, move the retaining clips slightly away from the memories moving sideways. The memory will slightly pop out and you can proceed to remove them. Use a pencil eraser to rub/clean on the little gold contact strips. Re-insert and lock in place. In some models the memories are underneath the keyboard. If this does not solve your problem, your next best move perhaps is to seek professional qualified services to diagnose/repair you laptop. In some instances, the repair could include video card or even memory replacement. Hop[t this be of some idea/help. Post back how things went or should you need further information. Good luck and kind regards.
Posted on Sep 24, 2007
Compaq Presario V5000 does not come on
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
http://www.chargerbuy.com/replacement-compaq-presario-v5000-ac-adapter-65w-18-5v-3-5a.html
Nov 20, 2012 | Compaq Computers & Internet
I have a compaq presario v5000 that gives me white screen help!!?
have you remembered to reconnect that small wire under the screw on the hinge?
hope this helps
Jun 06, 2010 | Compaq Armada 1700 Notebook
My compaq presario v5000 a 5240NR was working fine
Fn+F1 Decreases the display brightness. Fn+F2 Increases the display brightness
Oct 01, 2009 | HP Compaq Presario V5000T Notebook
My compaq presario v5000 does not power on?
Please try to plug the power cord into the source and used DC power source. Let the laptop charge for 5 - 10 minutes then after the given time please turn on the laptop. If it does not work extend the time from5 -10 to 15 - 30 minutes then repeat the stpes again. If it does not turn on then please try to check if the battery is charging. Then if all the procedure you have already perform and still no positive result then i advice you to please find a computer technician in your please and let that person fix the problem for you.
Thanks
Aug 04, 2009 | Toshiba Satellite M40-S417TD Notebook
Compaq presario v5000
Boot into Setup and run the TOOLS / PRIMARY HDD TEST / SHORT TEST.
If it fails, try another HDD.
If OK, verify Boot Order is Floppy, CD-ROM, HDD. Exit Setup.
Print Table 1 Low Level Format instructions from http://support.microsoft.com/kb/106419
Boot with a DOS disk that contains Debug. Run the Table 1 script. Turn V5000 Off.
Boot with the HP Operating System CD. XP install should now proceed normally.
Good luck.
Sep 12, 2008 | Compaq Presario V5005us Notebook
Laptop isn't working
have the charger tested, the original battery may have been flat, because of charger failure rather than battery failure. try an automotive connector if one is available
2c worth
Jul 11, 2008 | HP Compaq Presario V5000Z Notebook
Could be a stuck key somewhere, has anything been wasted on the keypad, tap the keys one by one to refresh is. Could also be that the keyboard is broken.
Fixya me ... thanks!
Feb 20, 2008 | Compaq Presario 2170US Notebook
This series of compaq laptops have an issue with current draw on the mainboard, you will need to send it to compaq for a new mainboard.
Feb 18, 2008 | HP Compaq Presario V5000Z Notebook
Compaq Armada M700 Notebook Logo
350 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
