Question about SAMTRON 55V 15" CRT Monitor
Mugen MC1524D horizontal line shake on upside
I have Mugen CRT Monitor MC1524D 15"
My Problem is
when i start up my monitor
for some minutes showing black horizontal line shake on upside
and then gone
probably what's my problem
i have resoldering monitor board
but still no result
  • RafaDimitri Apr 23, 2009
    i have try what that whitebirch say
    but the solution still can't fix it
    is there anyone can help me....
  • 433 Answers
Find the button that says DEGAUSS push it...
next try to increase your refresh rate of the monitor which is controlled by the video software in you computer...right click in a blank area go to properties at the bottom click-> on that hit the Settings tab look for ->advanced box towards the bottom right->click on the Monitor tab -> in the middle it will say "Screen refresh rate" use the drop down arrow and select at least 70-75 Hertz.
this just may stop it from jumping about...good luck and hope this help...
Posted on Apr 23, 2009
HP 7540 crt monitor shrinks to a horizontal line
It would be more economical to purchase a new or used LED/LCD display rather than wasting money on an old CRT monitor.
Feb 22, 2012 | HP COMPAQ 7540 CRT Monitor
Monitor disply movable horizontal lines.
yes you first check the supply at vertical ic 12v if present then replace that vertical ic if supply is not present then check the regulator ic in smps if faulty then replace it
Nov 20, 2008 | SAMTRON 55V 15" CRT Monitor
Screen displaying a thin white very bright horizontal line.... plz help
Remove dry solder at Vertical IC if problem not solves replace VERTICAL IC and pf104
Darshan
Jul 05, 2008 | LG Studioworks 552V 15" CRT Monitor
Crt monitor problem
try to check the pincusion...
Jun 27, 2008 | AOC LM729 17" LCD Monitor
Shows half screen only!
if you can't expand your screen size from the pulldown menu or vertically or horizontally center the picture one or two of the centering coils could be partially burned out. the monitor uses electromagnets around the crt neck to center the picture. varying the center controls apply or take away voltage from the coils to center the image. may be time for a new monitor
Jun 08, 2008 | Compaq MV 540 15" CRT Monitor
Monitor displays only horizontal line
hey bro.
you try to re solder the vertical section and the color section.
Oct 16, 2007 | SAMTRON 55V 15" CRT Monitor
Horizontal lines are appearing and moving acrosss the screen of my View Sonic E50C Monitor...
What is wrong with your monitor is that the Horizontal section is going faulty, the lines you are seeing are the Horizontal Retrace lines, usually invisable in a working unit. It is often a faulty capacitor(s) OR a Diode breaking down.. in the area of the Flyback Transformer. Probably time for a new one unless ya can fix it yaself.
Jun 11, 2007 | ViewSonic E50C 15" CRT Monitor
LG L1520B
This sounds like either a loose lead connection or a corrupt driver, if its looking like a driver fault you can click Start>Run then type 'dxdiag' then hit enter for windows to check drivers. If it's a driver fault unistall driver in add/remove programmes and restart pc, when it finds your graphics card on startup insert your Graphic card cd rom to install driver again.
Dec 16, 2006 | LG L1520B 15" LCD Monitor
56 V - faint horizontal lines across the display
u can search problem in vertical section may be sum IC component was dry resold them .
Aug 02, 2006 | SAMTRON 55V 15" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
116 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
pankaj rautela
pankaj rautela
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
