Question about Sharp AR-168D Copier
Copier wont print
I am trying to print from my computer but it wont , theerror message is "add paper to by pass." this is inspite of the fact that both trays are full of papers, and there is no misfeed detected. What do I do now the printer is just about two years old.
  • 161 Answers
Your unit is fine. Check the paper setting in your word processor and you will find that you are selecting either: (1) special paper type or (2) special paper size.
Posted on Sep 25, 2007
SX415 Error message A printer error has occurred - switching off and on again results in the same message.
Diagnosing the Problem - Epson
https://files.support.epson.com/htmldocs/rx620_/.../trble_1.htm
EpsonAn error has occurred in the printer parts. Turn this product off, and then back on. If theerror message still appears, contact your dealer. Scanner error occurred.
Epson printer sx415 printing problems/paper jam - Forum Thread ...
www.pcadvisor.co.uk > Forums > Tech Helproom
Jun 30, 2010 - Epson printer sx415 printing problems/paper jam ... before it will work correctly again otherwise you will continue to get the error message.
Oct 08, 2015 | Epson Stylus Office Equipment & Supplies
Unable to print from canon imagerunner 3100
Select the paper source(paper tray) on the computer,select paper size.
Jan 03, 2012 | Canon Diplomat Office Equipment & Supplies
We have a Canon Image Runner 3235 that is hooked up to a network. Every time we try to send more than one document to print off we get the error message to load paper and it doesn't need any paper. ...
if the message add paper related with specific paper size i.e. add A4 paper in drawer, first you need to check is the paper senzor in drawer set to correct paper size - it is blue circle with markins of paper size. Second thing under printer driver properties on PC check if the correct paper size is choosen.
Hope that helps!
Aug 15, 2011 | Canon iR 2016i Black and White Copier
Printer showing error message ...."printing
This means that your machine has received a print job that is teling it to print on paper that is loaded or supposed to be loaded in the bypass feed tray. You will either need to delete the print job using the operation panel or simple load some letter size paper in the bypass tray over on the right side of the machine.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 18, 2010 | Panasonic Workio DP-3030 Printer
Media is not picked up from the media tray
save the document to your desktop or copy and paste into word or notepad..
tell ya printer settings to clean nozzles.
remove paper.
place paper into tray area but not a whole lot....15-20 sheets...
now print...hows that..:-)
Sep 15, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Canon Image Runner C2058: Paper keeps being jammed at the same location. It happens at the last exit of the copier. When I clear the jammed paper, the image is printed on the paper. It simply could not...
Two ways. The First, you should consider the condition of the sensor of the output block. He can be conks or falls out, sticks. Possible correct the tweezers, however better apply to service. If he faulty, follows its change. Can try.
Jun 29, 2009 | Canon Office Equipment & Supplies
I can send faxes but I cant recieve any.
Follow the steps given below:
1. Snap the cartridges in and out three times.
2. On the operator panel, press Options to indicate which cartridges were changed.
3. Press Start / Yes.
4. Press Options to indicate the type of cartridge you installed.
5. Press Start / Yes.
If the problem persists, do the following:
1. With the printer powered on, remove both cartridges.
2. Unplug the power cable from the back of the printer
3. With the printer disconnected, insert the cartridges and reconnect the power cable.
Apr 09, 2009 | Lexmark X125 All-In-One InkJet Printer
Hp 2355 all in one error message
open the rear access door and clean the rollers with a cloth, dam it with little water and unplug the machine and press and hold the ON button for 1 min and release the button and plug in the power cord, it should resolve the issue.
Regards,  raj_p5983
Jan 21, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Our customer has a Canon Laser fax L800, Error message of Jammed paper displays, despite the fact that there is no paper jammed in the machine, paper path looks ok. Any ideas !!
Is it a jam or an add paper message (same light)? Sometimes you have to press the start button after you add paper on this machine.
Nov 27, 2008 | Office Equipment & Supplies
Failed to print
At the head you said 'paper thickness position'and then you seems to have ignored that and did all the other things. Is there an adjustment for paper thickness, a lever perhaps. It does seem to be with the paper feed or paper presence detection. Take a look around, is there something stuck in the paper feed track? Can you have pass a piece of paper through without it rucking up? Do these things see what happens Take a look also at www.fixyourownprinter.com
May 26, 2007 | Canon BubbleJet i550 InkJet Printer
Sharp AR-168D Copier Logo
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
Ed
Ed
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
