Question about Garden
Old wizard rototiller; need help with reverse belt pulleys
5 hp ? horizontal shaft engine. engine has 2 groove pulley, but one must have had a ''rubber o-ring'' that drove the back side of the reverse belt? the belt and idler pulley do not come close enough to the engine pulley slot to drive the back side of the belt without something in the engine pulley groove. Any ''oldtimers'' out there that know what they used?
This is a front tine tiller using a horizontal shaft and worm gear to drive the tine shaft.
3 Suggested Answers
Typus
  • 69 Answers
SOURCE: Roper tiller 26 inch front tine Pulley/belt diagram
I am not sure either, but I think that it would be alot cheeper to buy a new tiller, than to use your strenght fixing a old tiller that you didn't bother to keep the instructions for (no, I am not trying to be harsh. I am trying to be nice. and I am not sure about it coming with instructions, they usually do.)
29259605.jpgSorry, that is the closest picture that I can get.
Here is a link that may help. (IDK, because it is blocked where I am at.) http://www.google.com/aclk?sa=l&ai=CqcKEPGEMSvvXJJyotgeEiOyLB_jqoUWYtdrOBMib0rsYEAMoB1DU-N7X_P____8BYMmOo4qkpMQRoAGUt9H9A8gBAaoEIU_Q6ppHU85NtRLlGbCSz8M4YQ7k6yZkGAMPo_XJ9i4rSQ&num=3&sig=AGiWqtyvlB5FasgaU109ezFuPnc-65WzHg&q=http://www.fixya.com/support/roper%3Fcmpid%3DG3372595023
Posted on May 14, 2009
SOURCE: sears rear tine rototiller 32-29978 manual
I have a sears rear tine rototiller 7 horse 17" and the left side tines do not turn but the right side does
Posted on Apr 10, 2011
How to replace fan belt on a Mitsubishi pajero
Instructions
  1. 1 Open the bonnet of the Pajero, and turn the bolt on the centre of the tension pulley with a socket wrench two full rotations. The tension pulley is the pulley directly behind the fan in the upper portion of the front of the engine.
  2. 2 Loosen the adjuster bolt on the tension pulley bracket. This bolt is on the left-hand side, situated in a long horizontal groove.
  3. 3 Slip the fan belt off of the engine. Draw a diagram of the path of the fan belt if the factory printed sticker diagram is no longer in the front of your engine on your Pajero.
  4. 4 Insert the new fan belt, winding it through the various pulleys according to your diagram. Put it on the tensioner pulley last.
  5. 5 Place the tension belt tool on the tension pulley bolt and pull until the slack in the belt is gone. When there is no slack, keep the pressure on the pulley, and tighten the adjuster bolt with the wrench. Tighten the lock bolt on the pulley.
Jun 17, 2015 | 2006 Mitsubishi Pajero 3.2
1996 toyota camry 2.2 5s- too manny timing marks crank shaft,cam shaft and cam shaft gears
Hi there:I dont have this diagram for 2S-ELC, 3S-FE and 5S-FE Engines, but pay attention at this...
To install:
  1. Align the cutouts of the oil pump pulley and shaft, and slide the pulley on. Retain the pulley while tightening the nut to 21 ft. lbs. (28 Nm).
  2. Align the crankshaft timing pulley set key with the key groove of the crankshaft pulley, then slide the pulley on.
  3. Install the No. 2 idler pulley with the bolt and tighten to 31 ft. lbs. (42 Nm). Be sure the pulley moves smoothly.
Remove any oil or water on the idler pulley and keep it clean.
  1. Temporarily install the No. 1 idler pulley with the retaining bolt. Hint: use a 1.65 inch (42mm) bolt in length. Do not tighten the bolt yet. Install the tension spring. Pry the pulley toward the left as far as it will go, then tighten the bolt.
  2. Turn the crankshaft until the key groove in the crankshaft timing pulley is facing upward. Install the timing belt on the crankshaft timing, oil pump, No. 2 idler and water pump pulleys.
If the old timing belt is being reinstalled, make sure the directional arrow is facing in the original direction and that the belt and crankshaft gear matchmarks are properly aligned.
  1. Install the lower (No. 1) timing belt cover and new gasket with the four bolts.
  2. Align the crankshaft pulley set key with the pulley key groove. Install the pulley. Tighten the pulley bolt to 80 ft. lbs. (108 Nm).
  3. On 2S-ELC engines, turn the crankshaft pulley and align the 0 mark on the lower (No. 1) timing belt cover.
  4. Align the camshaft knock pin with the matchmarks on the oil seal retainer.
  5. On 2S-ELC/USA engines, align the knock pin with the pin hole on the timing pulley E mark side. On 2S-ELC/Canadian engines, align the knock pin with the pin hole on the timing pulley. On 3S-FE and 5S-FE engines, align the knock pin with the groove of the pulley, and slide the pulley onto the camshaft with the plate washer and set bolt.
On 2S-ELC engines, make sure that the Matchmark on the oil seal retainer and center hole of the small hole on the camshaft timing pulley are aligned.
  1. Using the removal tool to hold the pulley stationary, install and tighten the pulley set bolt to 40 ft. lbs. (54 Nm) on the 2S-ELC and the 3S-FE. On the 5S-FE, tighten the set bolt to 27 ft. lbs. (37 Nm).
  2. On 3S-FE and 5S-FE engines, turn the crankshaft pulley and align the 0 mark on the lower (No. 1) timing belt cover.
  3. Install the timing belt and check the valve timing as follows:
    1. Align the matchmarks that you made previously, and install the timing belt onto the camshaft pulley.
    2. Loosen the No. 1 idler pulley set bolt 1 / 2 turn.
    3. Turn the crankshaft pulley two complete revolutions TDC to TDC. ALWAYS turn the crankshaft CLOCKWISE. Check that the pulleys are still in alignment with the timing marks.
    4. Tighten the No. 1 idler pulley set bolt to 31 ft. lbs. (42 Nm).
    5. Make sure there is belt tension between the crankshaft and camshaft timing pulleys.
  4. Install the upper (No. 2) timing cover with a new gasket(s). On the 5S-FE, align the two clamps for the engine wiring harness with the cover mounting bolts.
  5. Install the spark plugs.
  6. Install the right mounting insulator with bracket. Tighten the bracket bolts to 38 ft. lbs. (52 Nm), insulator nuts to 38 ft. lbs. (52 Nm) and thru-bolt to 52 ft. lbs. (71 Nm). On the 5S-FE, install the No. 2 engine mount bracket and tighten to 38 ft. lbs. (52 Nm); install the control rod and tighten the bolts to 47 ft. lbs. (64 Nm).
  7. Lower the engine.
  8. On 3S-FE and 5S-FE engines, install the alternator and alternator bracket. On 2S-ELC engines, install the power steering reservoir tank.
  9. Install the drive belt and adjust the tension.
  10. Install the cruise control actuator with bracket.
  11. Install the fender apron seal and right engine under cover.
  12. Install the right front wheel.
Hope this helps.
Jun 12, 2012 | Toyota Cars & Trucks
I have a very old Wizard (Western Auto) Front Tine Rototiller Model gis 6990 A27 with power reverse. I am looking for a manual or a diagram of the drive belt routing. (Patent #2903077). Any assistance...
Hi and welcome to FixYa, I am Kelly
Here is a picture of the belts installed.
http://photos.cubfest.com/albums/userpics/10231/Belt_Routing.jpg
NOTE the front fwd direction drive belt / closest to the motor is installed like any other belt. The rear belt for REVERSE direction has 1/2 twist. The idler pulley presses in for foward driving and pulls out against the reverse drive belt.
This should be what you need.
Thanks for choosing FixYa,
Kelly
Jun 20, 2011 | Garden
Where is the tension pully on a 1993 ford taurus 3.0 motor
there is no spring tensioner on some of the 3.0 engines. See instructions below. I will paste a pic on the version that DOES have a tensioner at the bottom of this post.
3.0L Engine-Except SHO
ALTERNATOR BELT WITHOUT AUTOMATIC TENSIONER
  1. Loosen the adjusting arm and pivot bolts.
  2. Turn the alternator belt adjusting screw counterclockwise until the old belt can be removed.
  3. Remove the belt.
To install:
  1. Install the new belt over the pulleys. Check that all the V-grooves make proper contact with the pulleys.
  2. Adjust the belt tension, then tighten the adjusting arm and pivot bolts.
3.0L SHO Engine
ALTERNATOR BELT
See Figure 2
  1. Loosen the nut in the center of the idler pulley.
  2. Loosen the idler adjusting screw until the old belt can be removed, then remove the belt.
To install:
  1. Install the new belt over the pulleys in proper contact with the pulleys.
  2. Adjust the new belt to specifications as follows: Turn the idler pulley nut to the right to tighten the belt to a specification of 220-265 lbs. (980-1180 N). Torque the idler pulley nut to 25-37 ft. lbs. (34-50 Nm).
POWER STEERING AND AIR CONDITIONING BELT
See Figure 2
  1. Remove the alternator belt.
  2. Loosen the nut on the tensioner pulley.
  3. Turn the belt adjusting screw on the tensioner counterclockwise until the belt can be removed, then remove the belt.
To install:
  1. Position the new belt over the proper pulleys, making sure the V-grooves are properly seated.
  2. Install the alternator belt.
  3. Adjust the power steering and air conditioning belt to a specification of 154-198 lbs. (690-980 N) with a belt tension gauge.
  4. Adjust the alternator belt.
3.0L Engine (Except SHO) and 3.8L Engine
VEHICLES THROUGH 1993 WITH AUTOMATIC TENSIONER
See Figures 4 and 5
  1. Insert a 1 / 2 in. breaker bar into the square hole in the tensioner.
On the 3.8L engine, the tensioner has a1/2in. square hole cast into the rear of the tension arm directly behind the pulley. On the 3.0L engine, the1/2in. square hole is cast into the spring housing on the front of the tensioner.
  1. Rotate the tensioner clockwise and remove the belt.
Fig. Fig. 5: 3.8L belt schematic-1993 shown
To install:
  1. Install the drive belt over all the pulleys, except for the alternator pulley on the 3.0L engine for vehicles through 1992, or the idler pulley for 1993 3.0L vehicles.
  2. Rotate tensioner counterclockwise and install the belt over the alternator pulley. Make sure that all the V-grooves make proper contact with the pulleys.
  3. On the 3.0L engine, install the alternator belt for vehicles through 1992.
  4. For 1993 3.0L vehicles, install the drive belt over the idler pulley.
Oct 01, 2010 | 1993 Ford Taurus
Procedure in changing timing belt
Timing Belt and Sprockets REMOVAL & INSTALLATION 2S-ELC, 3S-FE and 5S-FE Engines
  1. Remove the timing belt covers as previously detailed.
  2. Raise the engine just enough to remove the weight from the engine mount on the right side.
  3. Remove the thru-bolt, two nuts, and right hand mounting insulator.
  4. Remove the retaining bolts and remove the right hand mounting bracket (from the side the alternator was removed from).
  5. Remove the timing belt and timing belt guide. If the timing belt is to be reused, draw a directional arrow on the timing belt in the direction of engine rotation (clockwise) and place matchmarks on the timing belt and crankshaft gear.
  6. Remove the bolt retaining the No. 1 idler pulley and tension spring.
  7. Remove the No. 2 idler pulley.
  8. Remove the crankshaft timing gear , if it can not be removed by hand, use two flat bladed tools to pry it off. Make sure to position shop rags to prevent damages to the components.
  9. Remove the nut retaining the oil pump pulley. To install:
  10. Align the cutouts of the oil pump pulley and shaft, and slide the pulley on. Retain the pulley while tightening the nut to 21 ft. lbs. (28 Nm).
  11. Align the crankshaft timing pulley set key with the key groove of the crankshaft pulley, then slide the pulley on.
  12. Install the No. 2 idler pulley with the bolt and tighten to 31 ft. lbs. (42 Nm). Be sure the pulley moves smoothly. NOTE: Remove any oil or water on the idler pulley and keep it clean.
  13. Temporarily install the No. 1 idler pulley with the retaining bolt. Hint: use a 1.65 inch (42mm) bolt in length. Do not tighten the bolt yet. Install the tension spring. Pry the pulley toward the left as far as it will go, then tighten the bolt.
  14. Turn the crankshaft until the key groove in the crankshaft timing pulley is facing upward. Install the timing belt on the crankshaft timing, oil pump, No. 2 idler and water pump pulleys. NOTE: If the old timing belt is being reinstalled, make sure the directional arrow is facing in the original direction and that the belt and crankshaft gear matchmarks are properly aligned.
  15. Install the lower (No. 1) timing belt cover and new gasket with the four bolts.
  16. Align the crankshaft pulley set key with the pulley key groove. Install the pulley. Tighten the pulley bolt to 80 ft. lbs. (108 Nm).
  17. On 2S-ELC engines, turn the crankshaft pulley and align the 0 mark on the lower (No. 1) timing belt cover.
  18. Align the camshaft knock pin with the matchmarks on the oil seal retainer.
  19. On 2S-ELC/USA engines, align the knock pin with the pin hole on the timing pulley E mark side. On 2S-ELC/Canadian engines, align the knock pin with the pin hole on the timing pulley. On 3S-FE and 5S-FE engines, align the knock pin with the groove of the pulley, and slide the pulley onto the camshaft with the plate washer and set bolt. NOTE: On 2S-ELC engines, make sure that the Matchmark on the oil seal retainer and center hole of the small hole on the camshaft timing pulley are aligned.
  20. Using the removal tool to hold the pulley stationary, install and tighten the pulley set bolt to 40 ft. lbs. (54 Nm) on the 2S-ELC and the 3S-FE. On the 5S-FE, tighten the set bolt to 27 ft. lbs. (37 Nm).
  21. On 3S-FE and 5S-FE engines, turn the crankshaft pulley and align the 0 mark on the lower (No. 1) timing belt cover.
  22. Install the timing belt and check the valve timing as follows:
    2. Loosen the No. 1 idler pulley set bolt 1⁄2 turn.
  23. Install the upper (No. 2) timing cover with a new gasket(s). On the 5S-FE, align the two clamps for the engine wiring harness with the cover mounting bolts.
  24. Install the spark plugs.
  25. The remainder of installation is the reverse of removal. Tighten each component to specifications.
Aug 04, 2010 | 1996 Toyota Camry
RPM OK here we go: motor 1725 3/4 shaft..arbor 4" pulley dedicated prefer to leave on,,old line shaft type..has 2 -3 1/2 pulleys and flat belt works too, up to 3" wide..1/2 " V-belt..all on a...
Have you ever thought of a Motor Speed Controller, sort of a "Dimmer" for a motor? That way you could simply adjust your motor speed to what you want and compensate the error out?
Feb 14, 2010 | Air Tools & Compressors
I need to replace the serpentine belt on a 1995 Saab 900 s
Use a 6 or 8 inch 1/2 socket extension bar and place it in the top of the tensioner pulley, there is a notch in pulley for this. The tensioner pulley is near the firewall at the top of the engine....make a diagram of the belt routing and note which side( smooth or grooved) is lying on the pulley(usually grooved side of belt). Next you would pull tensioner pulley forward and slip the old belt off....you would route your new belt the same way and slip it on the tensioner pulley last.....you will need to pull the tensioner pulley forward again to get the slack you need to slide the belt over the pulley. I have found the Saab to be one of the easiest cars to change the serpentine belt on. I hope this helps.
Nov 28, 2009 | 1995 Saab 900
Motor pulley for an old Ingersoll Rand type 30 compressor
Here is a link to Ingersoll-Rand (compressed air division) where you can find a local distributor. I think a call to a parts tech might provide the original motor sheave outside diameter and belt size (I'm suspecting "A" or "B" size).
http://www.ingersollrandproducts.com/contact/air/index.aspx
With that info, here is a link to a good industrial source for your new motor sheave (McMaster-Carr):
http://www.mcmaster.com/#v-belt-sheaves/=3fwz7b
Their prices aren't so bad.
You may also have a local industrial sales in your area.
I hope this helps you... Nice compressor!
Sep 01, 2009 | Ingersoll Rand Type 30 Fully Packaged Ir...
My huqvana won't go in reverse or forward
if the leaver moves freely but wont move first check belt is on pulley and if so you have sheared off keyway on the pulley on top of drive axle remove pully replace keyway reinstall
Jul 26, 2009 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
Looking for owners manual
I have a manual for the Wizard 5HP tiller. The reverse belt basically makes a figure 8
The belt goes over the motor pulley and over the idler pulley then makes a twist in the middle and around the bottom pulley. This cause it to basically rotate the opposite direction from the rotation of the drive pulley
Apr 05, 2009 | Garden
Garden Logo
1,073 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
